Hi
I can’t start lxd. There was a hard drive failure and despite my drives being mirrored lxd died and won’t restart. Here are the debug logs. Please advise?
DBUG[10-21|09:57:52] Connecting to a local LXD over a Unix socket
DBUG[10-21|09:57:52] Sending request to LXD method=GET url=http://unix.socket/1.0 etag=
INFO[10-21|09:57:52] LXD 4.0.3 is starting in normal mode path=/var/snap/lxd/common/lxd
INFO[10-21|09:57:52] Kernel uid/gid map:
INFO[10-21|09:57:52] - u 0 0 4294967295
INFO[10-21|09:57:52] - g 0 0 4294967295
INFO[10-21|09:57:52] Configured LXD uid/gid map:
INFO[10-21|09:57:52] - u 0 1000000 1000000000
INFO[10-21|09:57:52] - g 0 1000000 1000000000
INFO[10-21|09:57:52] Kernel features:
INFO[10-21|09:57:52] - closing multiple file descriptros efficiently: no
INFO[10-21|09:57:52] - netnsid-based network retrieval: yes
INFO[10-21|09:57:52] - pidfds: yes
INFO[10-21|09:57:52] - uevent injection: yes
INFO[10-21|09:57:52] - seccomp listener: yes
INFO[10-21|09:57:52] - seccomp listener continue syscalls: yes
INFO[10-21|09:57:52] - seccomp listener add file descriptors: no
INFO[10-21|09:57:52] - safe native terminal allocation : no
INFO[10-21|09:57:52] - unprivileged file capabilities: yes
INFO[10-21|09:57:52] - cgroup layout: hybrid
WARN[10-21|09:57:52] - Couldn't find the CGroup blkio.weight, I/O weight limits will be ignored
WARN[10-21|09:57:52] - Couldn't find the CGroup memory swap accounting, swap limits will be ignored
INFO[10-21|09:57:52] - shiftfs support: yes
INFO[10-21|09:57:52] Initializing local database
DBUG[10-21|09:57:52] Initializing database gateway
DBUG[10-21|09:57:52] Start database node id=6 address=10.3.0.60:8443 role=spare
EROR[10-21|09:57:52] Failed to start the daemon: Failed to start dqlite server: raft_start(): io: load closed segment 0000000000077825-0000000000079365: entries batch 58 starting at byte 3071496: entries count in preamble is zero
INFO[10-21|09:57:52] Starting shutdown sequence
DBUG[10-21|09:57:52] Not unmounting temporary filesystems (containers are still running)
Error: Failed to start dqlite server: raft_start(): io: load closed segment 0000000000077825-0000000000079365: entries batch 58 starting at byte 3071496: entries count in preamble is zero
