Running Ubuntu 18.04, I upgraded the kernel to 4.18rc2 from http://kernel.ubuntu.com/~kernel-ppa/mainline/. However since the upgrade it became impossible to launch LXD containers.
The error message shown by lxc info --show-log is:
lxc kali 20180630004334.373 ERROR lxc_utils - utils.c:open_devnull:1753 - Permission denied - Can't open /dev/null
lxc kali 20180630004334.373 ERROR lxc_sync - sync.c:__sync_wait:57 - An error occurred in another process (expected sequence number 5)
lxc kali 20180630004334.398 ERROR lxc_container - lxccontainer.c:wait_on_daemonized_start:834 - Received container state "ABORTING" instead of "RUNNING"
lxc kali 20180630004334.398 ERROR lxc_start - start.c:__lxc_start:1887 - Failed to spawn container "kali"
lxc 20180630004334.411 WARN lxc_commands - commands.c:lxc_cmd_rsp_recv:130 - Connection reset by peer - Failed to receive response for command "get_state"
The LXD installation is 3.0.1 from the Ubuntu repos. Everything worked normally with older mainline kernel, including and up to 4.17.x.
Thanks in advance for any solution or workaround, if there are any. Unfortunately both the default Ubuntu 4.15 kernel and the 4.17 mainline kernels have other issues on my machine so upgrading to 4.18 is pretty much a necessity.
Thanks Stephane. Not to beat this thread up with an aside, but can you point me towards any kernel net discussions about how the 4.18 namespace issue is progressing. Much appreciated.
Thanks for the quick fix! Which git repo can I pick it up from? On https://github.com/lxc/lxd the latest patch available is 6160132 from 3 days ago, which doesn’t seem to be related to this.
The required fix is in liblxc not in LXD. There’s also the possibility that the 4.18 kernel and the patch causing this will be reverted. This is something we are currently discussing.
Help!! I just ran into this issue today! LXD/LXC ran has been running perfectly for me for many months in a row. Today…I run into this issue! I am on Ubuntu 16.04.4
root@localhost:/var/log/apt# uname -a
Linux localhost 4.18.8-x86_64-linode117 #1 SMP PREEMPT Tue Sep 18 18:48:25 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
I don’t know how the kernel got to 4.18.8 between last night and this afternoon!
lxc LPC1 20181015181038.960 ERROR lxc_utils - utils.c:open_devnull:1753 - Permission denied - Can’t open /dev/null
lxc LPC1 20181015181038.960 ERROR lxc_sync - sync.c:__sync_wait:57 - An error occurred in another process (expected sequence number 5)
lxc LPC1 20181015181039.202 ERROR lxc_container - lxccontainer.c:wait_on_daemonized_start:834 - Received container state “ABORTING” instead of “RUNNING”
lxc LPC1 20181015181039.205 ERROR lxc_start - start.c:__lxc_start:1887 - Failed to spawn container “LPC1”
lxc 20181015181039.299 WARN lxc_commands - commands.c:lxc_cmd_rsp_recv:130 - Connection reset by peer - Failed to receive response for command “get_state”
This is critical to me and what I am doing! How can I patch this? I don’t understand how to use the above fix?
@Rayj, @simos suggestion worked for me. I used the guide below to walk me through in changing the kernel. I selected “Grub 2”. Rebooted the linode and started the lxc containers with no problem.
