Lxd 3.21: more ceph issues
(the cluster from Issues with Ceph cluster and lxd has been upgraded to 3.21)
Currently experiencing new issues, now unable to create a VM…which worked last week.
The command is:
lxc launch ubuntu some-vm-name --vm
Output:
Creating the instance
The local image ‘ubuntu’ couldn’t be found, trying ‘ubuntu:’ instead.
Error: Failed instance creation: Create instance from image: Failed to run: rbd --id lxd –
cluster ceph --image-feature layering clone rbd-lxc-
aa0.a1f/image_8bac6546bbc5cfbe5c490f2c991cff8cff1428b57fb9a74d33a64cb6dff66601.
block@readonly rbd-lxc-aa0.a1f/virtual-machine_perfect-goldfish.block: 2020-02-20
20:52:14.788395 7f79f77fe700 -1 librbd::image::OpenRequest: failed to set image
snapshot: (2) No such file or directory 2020-02-20 20:52:14.788599 7f7a224f4100 -1
librbd: error opening parent image: (2) No such file or directory
rbd: clone error: (2) No such file or directory
Poking ceph directly (rbd du) shows it exists:
image_8bac6546bbc5cfbe5c490f2c991cff8cff1428b57fb9a74d33a64cb6dff66601.block
23 GiB 558 MiB
image_8c4e87e53c024e0449003350f0b0626b124b68060b73c0a7ad9547670e00d4b3
@readonly 23 GiB 1.2 GiB
23 GiB 0 B
image_8c6b98199f45cf67548efa795e4f40fe20d1e16438253fed411bc83d905b19c3
48 MiB 28 MiB
image_8c6b98199f45cf67548efa795e4f40fe20d1e16438253fed411bc83d905b19c3.block
SQL desync again, maybe?
Nope, that’s a different one and we fixed that one already.
snap refresh lxd should get you past this one.
No change after refresh - it said it had no updates available.
Hmm, what does snap info lxd show you?
And can you show lxd sql global "SELECT * FROM storage_pools_config;"
3.21 has the new ceph implementation so I suspect it’s a different issue.
I first suspected it was a bug related to ceph credentials, but looking again above, that seems unlikely to be the case.
snap-id: J60k4JY0HppjwOjW8dZdYc8obXKxujRu
tracking: latest/stable
refresh-date: today at 03:38 UTC
(let me know if you need more of the output)
| id | storage_pool_id | node_id |           key           |      value      |
| 6  | 4               | 2       | source                  | rbd-lxc-aa0.a1f |
| 7  | 4               | 3       | source                  | rbd-lxc-aa0.a1f |
| 8  | 4               | 4       | source                  | rbd-lxc-aa0.a1f |
| 9  | 4               | 5       | source                  | rbd-lxc-aa0.a1f |
| 10 | 4               | 6       | source                  | rbd-lxc-aa0.a1f |
| 11 | 4               | 7       | source                  | rbd-lxc-aa0.a1f |
| 12 | 4               | 8       | source                  | rbd-lxc-aa0.a1f |
| 43 | 4               | 9       | source                  | rbd-lxc-aa0.a1f |
| 44 | 4               | 9       | volatile.initial_source | rbd-lxc-aa0.a1f |
| 45 | 4               | <nil>   | ceph.user.name          | lxd             |
| 46 | 4               | <nil>   | ceph.cluster_name       | ceph            |
| 47 | 4               | <nil>   | volatile.pool.pristine  | false           |
| 48 | 4               | <nil>   | volume.size             | 25GB            |
| 49 | 4               | <nil>   | ceph.osd.force_reuse    | true            |
| 50 | 4               | <nil>   | ceph.osd.pg_num         | 32              |
| 51 | 4               | <nil>   | ceph.osd.pool_name      | rbd-lxc-aa0.a1f |
Do you see more in ceph?
In your output above, I only see image_8bac6546bbc5cfbe5c490f2c991cff8cff1428b57fb9a74d33a64cb6dff66601.block which is lacking its snapshot (@readonly) and also appears to be lacking the non-block part of the image.
For a VM image, I would have expected to see:
  • image_8bac6546bbc5cfbe5c490f2c991cff8cff1428b57fb9a74d33a64cb6dff66601
  • image_8bac6546bbc5cfbe5c490f2c991cff8cff1428b57fb9a74d33a64cb6dff66601@readonly
  • image_8bac6546bbc5cfbe5c490f2c991cff8cff1428b57fb9a74d33a64cb6dff66601.block
  • image_8bac6546bbc5cfbe5c490f2c991cff8cff1428b57fb9a74d33a64cb6dff66601.block@readonly
These are all we’re seeing in ceph:
48 MiB   28 MiB
23 GiB  558 MiB
Ok, so you have the images but not the associated readonly snapshot.
Manually creating it with rbd will likely fix the situation.
I’m provisioning a test system here to stress test the image management part of the Ceph driver as there’s clearly something odd going on here.
I’ve found a number of bugs in the Ceph handling code, including what may be your issue (I hope).
https://github.com/lxc/lxd/pull/6920
Alright. I’ll need to think of a way to test a newer build as we have semi-production stuff running currently on the cluster so generally need to wait for a new release to hit snap.
Ah - looks like snap refreshed and pulled the fixes. Seems happier now.
Excellent! Anything still behaving weird?
Seems mostly fixed aside from this desync:
root@aa1-cptef101-n2:/home/ubuntu# lxc launch ubuntu ubuntu-vm --vm
Creating ubuntu-vm
The local image 'ubuntu' couldn't be found, trying 'ubuntu:' instead.
Error: Failed instance creation: Locate image
8bac6546bbc5cfbe5c490f2c991cff8cff1428b57fb9a74d33a64cb6dff66601 in the cluster:
image not available on any online node
The image is in lxc image ls, however:
Error: failed to notify peer 10.224.1.13:8443: Failed to delete image from peer node: Failed
to run: rbd --id lxd --cluster ceph --pool rbd-lxc-aa0.a1f children --image
_ext4.block --snap readonly: rbd: error opening image
_ext4.block: (2) No such file or directory
Can you show rbd du --pool rbd-lxc-aa0.a1f? It may be a pre-fix image and so be misisng the _ext4 part or has it all the way at the end, so may just need a quick rename to line it up.
Only two files matching that hash exist:
48 MiB   28 MiB
23 GiB  558 MiB
Ok, so to make things consistent with the pattern expected by my fix, you’d want to rename:
  • image_8bac6546bbc5cfbe5c490f2c991cff8cff1428b57fb9a74d33a64cb6dff66601 to image_8bac6546bbc5cfbe5c490f2c991cff8cff1428b57fb9a74d33a64cb6dff66601_ext4
  • image_8bac6546bbc5cfbe5c490f2c991cff8cff1428b57fb9a74d33a64cb6dff66601.block to image_8bac6546bbc5cfbe5c490f2c991cff8cff1428b57fb9a74d33a64cb6dff66601_ext4.block
This should then fix the no such file or directory error.
