lxc exec hangs on my system, the host is running ArchLinux. lxc console works fine. Any idea what could be the issue?
Here is the LXD log
# cat /var/snap/lxd/common/lxd/logs/lxd.log
t=2020-03-27T07:35:15+0530 lvl=info msg="LXD 3.23 is starting in normal mode" path=/var/snap/lxd/common/lxd
t=2020-03-27T07:35:15+0530 lvl=info msg="Kernel uid/gid map:"
t=2020-03-27T07:35:15+0530 lvl=info msg=" - u 0 0 4294967295"
t=2020-03-27T07:35:15+0530 lvl=info msg=" - g 0 0 4294967295"
t=2020-03-27T07:35:15+0530 lvl=info msg="Configured LXD uid/gid map:"
t=2020-03-27T07:35:15+0530 lvl=info msg=" - u 0 1000000 1000000000"
t=2020-03-27T07:35:15+0530 lvl=info msg=" - g 0 1000000 1000000000"
t=2020-03-27T07:35:15+0530 lvl=warn msg="AppArmor support has been disabled because of lack of kernel support"
t=2020-03-27T07:35:15+0530 lvl=info msg="Kernel features:"
t=2020-03-27T07:35:15+0530 lvl=info msg=" - netnsid-based network retrieval: yes"
t=2020-03-27T07:35:15+0530 lvl=info msg=" - uevent injection: yes"
t=2020-03-27T07:35:15+0530 lvl=info msg=" - seccomp listener: yes"
t=2020-03-27T07:35:15+0530 lvl=info msg=" - seccomp listener continue syscalls: no"
t=2020-03-27T07:35:15+0530 lvl=info msg=" - unprivileged file capabilities: yes"
t=2020-03-27T07:35:15+0530 lvl=info msg=" - cgroup layout: hybrid"
t=2020-03-27T07:35:15+0530 lvl=warn msg=" - Couldn't find the CGroup blkio.weight, I/O weight limits will be ignored"
t=2020-03-27T07:35:15+0530 lvl=info msg=" - shiftfs support: disabled"
t=2020-03-27T07:35:15+0530 lvl=info msg="Initializing local database"
t=2020-03-27T07:35:16+0530 lvl=info msg="Starting /dev/lxd handler:"
t=2020-03-27T07:35:16+0530 lvl=info msg=" - binding devlxd socket" socket=/var/snap/lxd/common/lxd/devlxd/sock
t=2020-03-27T07:35:16+0530 lvl=info msg="REST API daemon:"
t=2020-03-27T07:35:16+0530 lvl=info msg=" - binding Unix socket" inherited=true socket=/var/snap/lxd/common/lxd/unix.socket
t=2020-03-27T07:35:16+0530 lvl=info msg=" - binding TCP socket" socket=[::]:8443
t=2020-03-27T07:35:16+0530 lvl=info msg="Initializing global database"
t=2020-03-27T07:35:21+0530 lvl=info msg="Firewall loaded driver \"nftables\""
t=2020-03-27T07:35:21+0530 lvl=info msg="Initializing storage pools"
t=2020-03-27T07:35:22+0530 lvl=info msg="Initializing daemon storage mounts"
t=2020-03-27T07:35:22+0530 lvl=info msg="Initializing networks"
t=2020-03-27T07:35:23+0530 lvl=info msg="Pruning leftover image files"
t=2020-03-27T07:35:23+0530 lvl=info msg="Done pruning leftover image files"
t=2020-03-27T07:35:23+0530 lvl=info msg="Loading daemon configuration"
t=2020-03-27T07:35:23+0530 lvl=info msg="Started seccomp handler" path=/var/snap/lxd/common/lxd/seccomp.socket
t=2020-03-27T07:35:23+0530 lvl=info msg="Pruning expired images"
t=2020-03-27T07:35:23+0530 lvl=info msg="Done pruning expired images"
t=2020-03-27T07:35:23+0530 lvl=info msg="Pruning expired instance backups"
t=2020-03-27T07:35:23+0530 lvl=info msg="Done pruning expired instance backups"
t=2020-03-27T07:35:23+0530 lvl=info msg="Expiring log files"
t=2020-03-27T07:35:23+0530 lvl=info msg="Done expiring log files"
t=2020-03-27T07:35:23+0530 lvl=info msg="Updating instance types"
t=2020-03-27T07:35:23+0530 lvl=info msg="Done updating instance types"
t=2020-03-27T07:35:23+0530 lvl=info msg="Starting container" action=start created=2019-01-21T06:49:25+0530 ephemeral=false name=dbserver project=default stateful=false used=2020-03-15T19:06:19+0530
When i issue ‘lxd exec zmvm bash’. lxd monitor reports the following,
metadata:
context:
ip: '@'
method: GET
url: /1.0
user: ""
level: dbug
message: Handling
timestamp: "2020-03-27T08:06:37.165621984+05:30"
type: logging
metadata:
context:
ip: '@'
method: GET
url: /1.0/events
user: ""
level: dbug
message: Handling
timestamp: "2020-03-27T08:06:37.178675435+05:30"
type: logging
metadata:
context: {}
level: dbug
message: 'New event listener: e84ffed1-f481-4f6d-a059-6a2dab505efa'
timestamp: "2020-03-27T08:06:37.179137671+05:30"
type: logging
metadata:
context:
ip: '@'
method: POST
url: /1.0/instances/zmvm/exec
user: ""
level: dbug
message: Handling
timestamp: "2020-03-27T08:06:37.179956772+05:30"
type: logging
metadata:
context: {}
level: dbug
message: 'forkcheckfile: Path doesn''t exist: No such file or directory'
timestamp: "2020-03-27T08:06:37.189149779+05:30"
type: logging
metadata:
context: {}
level: dbug
message: 'New websocket Operation: 404ab451-9beb-4819-a406-54f7e101adf2'
timestamp: "2020-03-27T08:06:37.192862711+05:30"
type: logging
metadata:
class: websocket
created_at: "2020-03-27T08:06:37.18926203+05:30"
description: Executing command
err: ""
may_cancel: false
metadata:
command:
- bash
environment:
HOME: /root
LANG: C.UTF-8
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
TERM: xterm-256color
TZ: Asia/Kolkata
USER: root
fds:
"0": 1709f74180ed4773fd59aaefc36bccb25202ed6dc60781924bb2602be320c617
control: 455b6401d20092fd2641341f352f3ed3b4597debd35d9f940812ca3eccb70040
interactive: true
resources:
containers:
- /1.0/containers/zmvm
status: Pending
status_code: 105
updated_at: "2020-03-27T08:06:37.18926203+05:30"
timestamp: "2020-03-27T08:06:37.193384991+05:30"
type: operation
metadata:
context: {}
level: dbug
message: 'Started websocket operation: 404ab451-9beb-4819-a406-54f7e101adf2'
timestamp: "2020-03-27T08:06:37.193425564+05:30"
type: logging
metadata:
class: websocket
err: ""
may_cancel: false
metadata:
command:
- bash
environment:
HOME: /root
LANG: C.UTF-8
TZ: Asia/Kolkata
USER: root
fds:
interactive: true
resources:
containers:
status: Running
status_code: 103
timestamp: "2020-03-27T08:06:37.193717743+05:30"
type: operation
metadata:
context:
ip: '@'
method: GET
url: /1.0/operations/404ab451-9beb-4819-a406-54f7e101adf2/websocket?secret=455b6401d20092fd2641341f352f3ed3b4597debd35d9f940812ca3eccb70040
user: ""
level: dbug
message: Handling
timestamp: "2020-03-27T08:06:37.19550283+05:30"
type: logging
metadata:
context: {}
level: dbug
message: 'Connected websocket Operation: 404ab451-9beb-4819-a406-54f7e101adf2'
timestamp: "2020-03-27T08:06:37.19554155+05:30"
type: logging
metadata:
context: {}
level: dbug
message: 'Handled websocket Operation: 404ab451-9beb-4819-a406-54f7e101adf2'
timestamp: "2020-03-27T08:06:37.197593669+05:30"
type: logging
metadata:
context:
ip: '@'
method: GET
url: /1.0/operations/404ab451-9beb-4819-a406-54f7e101adf2/websocket?secret=1709f74180ed4773fd59aaefc36bccb25202ed6dc60781924bb2602be320c617
user: ""
level: dbug
message: Handling
timestamp: "2020-03-27T08:06:37.200110694+05:30"
type: logging
metadata:
context: {}
level: dbug
timestamp: "2020-03-27T08:06:37.200146764+05:30"
type: logging
metadata:
context: {}
level: dbug
timestamp: "2020-03-27T08:06:37.200473906+05:30"
type: logging
metadata:
context:
ip: '@'
method: GET
user: ""
level: dbug
message: Handling
timestamp: "2020-03-27T08:06:37.20147789+05:30"
type: logging
Thanks
