ubuntu 16.04 lts
snap-version
LXD 3.8
after apt-update && apt-upgrade && a restart lxd isn’t coming up anymore.
lxd --debug --group lxd results in hanging
DBUG[12-21|14:12:22] Connecting to a local LXD over a Unix socket
DBUG[12-21|14:12:22] Sending request to LXD method=GET url=http://unix.socket/1.0 etag=
lxd sql ‘SELECT * FROM containers;’ results
Description:
Execute a SQL query against the LXD local or global database
The local database is specific to the LXD cluster member you target the
command to, and contains member-specific data (such as the member network
address).
The global database is common to all LXD members in the cluster, and contains
cluster-specific data (such as profiles, containers, etc).
If you are running a non-clustered LXD instance, the same applies, as that
instance is effectively a single-member cluster.
If is the special value “-”, then the query is read from
standard input.
If is the special value “.dump”, the the command returns a SQL text
dump of the given database.
If is the special value “.schema”, the the command returns the SQL
text schema of the given database.
This internal command is mostly useful for debugging and disaster
recovery. The LXD team will occasionally provide hotfixes to users as a
set of database queries to fix some data inconsistency.
This command targets the global LXD database and works in both local
and cluster mode.
Usage:
lxd sql <local|global> [flags]
Global Flags:
-d, --debug Show all debug messages
-h, --help Print help
–logfile Path to the log file
–syslog Log to syslog
–trace Log tracing targets
-v, --verbose Show all information messages
–version Print version number
Error: Missing required arguments
journalctl -u snap.lxd.daemon results:
Dez 21 12:11:19 q101010 systemd[1]: Started Service for snap application lxd.daemon.
Dez 21 12:11:19 q101010 lxd.daemon[12347]: => Preparing the system
Dez 21 12:11:19 q101010 lxd.daemon[12347]: ==> Loading snap configuration
Dez 21 12:11:19 q101010 lxd.daemon[12347]: ==> Setting up mntns symlink (mnt:[4026532495])
Dez 21 12:11:20 q101010 lxd.daemon[12347]: ==> Setting up persistent shmounts path
Dez 21 12:11:20 q101010 lxd.daemon[12347]: ====> Making LXD shmounts use the persistent path
Dez 21 12:11:20 q101010 lxd.daemon[12347]: ====> Making LXCFS use the persistent path
Dez 21 12:11:20 q101010 lxd.daemon[12347]: ==> Setting up kmod wrapper
Dez 21 12:11:20 q101010 lxd.daemon[12347]: ==> Preparing /boot
Dez 21 12:11:20 q101010 lxd.daemon[12347]: ==> Preparing a clean copy of /run
Dez 21 12:11:20 q101010 lxd.daemon[12347]: ==> Preparing a clean copy of /etc
Dez 21 12:11:21 q101010 lxd.daemon[12347]: ==> Setting up ceph configuration
Dez 21 12:11:21 q101010 lxd.daemon[12347]: ==> Setting up LVM configuration
Dez 21 12:11:21 q101010 lxd.daemon[12347]: ==> Rotating logs
Dez 21 12:11:22 q101010 lxd.daemon[12347]: ==> Setting up ZFS (0.7)
Dez 21 12:11:22 q101010 lxd.daemon[12347]: ==> Escaping the systemd cgroups
Dez 21 12:11:22 q101010 lxd.daemon[12347]: ==> Escaping the systemd process resource limits
Dez 21 12:11:22 q101010 lxd.daemon[12347]: ==> Increasing the number of inotify user instances
Dez 21 12:11:22 q101010 lxd.daemon[12347]: => Starting LXCFS
Dez 21 12:11:22 q101010 lxd.daemon[12347]: mount namespace: 6
Dez 21 12:11:22 q101010 lxd.daemon[12347]: hierarchies:
Dez 21 12:11:22 q101010 lxd.daemon[12347]: 0: fd: 7: pids
Dez 21 12:11:22 q101010 lxd.daemon[12347]: 1: fd: 8: cpuset
Dez 21 12:11:22 q101010 lxd.daemon[12347]: 2: fd: 9: hugetlb
Dez 21 12:11:22 q101010 lxd.daemon[12347]: 3: fd: 10: rdma
Dez 21 12:11:22 q101010 lxd.daemon[12347]: 4: fd: 11: net_cls,net_prio
Dez 21 12:11:22 q101010 lxd.daemon[12347]: 5: fd: 12: freezer
Dez 21 12:11:22 q101010 lxd.daemon[12347]: 6: fd: 13: perf_event
Dez 21 12:11:22 q101010 lxd.daemon[12347]: 7: fd: 14: cpu,cpuacct
Dez 21 12:11:22 q101010 lxd.daemon[12347]: 8: fd: 15: memory
Dez 21 12:11:22 q101010 lxd.daemon[12347]: 9: fd: 16: blkio
Dez 21 12:11:22 q101010 lxd.daemon[12347]: 10: fd: 17: devices
Dez 21 12:11:22 q101010 lxd.daemon[12347]: 11: fd: 18: name=systemd
Dez 21 12:11:22 q101010 lxd.daemon[12347]: => Starting LXD
Dez 21 12:11:22 q101010 lxd.daemon[12347]: t=2018-12-21T12:11:22+0100 lvl=warn msg="CGroup memory swap ac
Dez 21 12:11:26 q101010 lxd.daemon[12347]: t=2018-12-21T12:11:26+0100 lvl=eror msg="Failed to start the d
Dez 21 12:11:26 q101010 lxd.daemon[12347]: Error: ZFS storage pool “LXD-qbit” could not be imported: cann
Dez 21 12:11:26 q101010 systemd[1]: Started Service for snap application lxd.daemon.
Dez 21 12:11:27 q101010 lxd.daemon[12347]: => LXD failed to start
Dez 21 12:11:27 q101010 systemd[1]: snap.lxd.daemon.service: Main process exited, code=exited, status=137
Dez 21 12:11:28 q101010 lxd.daemon[14083]: => Stop reason is: crashed
Dez 21 12:11:28 q101010 systemd[1]: snap.lxd.daemon.service: Unit entered failed state.
Dez 21 12:11:28 q101010 systemd[1]: snap.lxd.daemon.service: Failed with result ‘exit-code’.
Dez 21 12:11:28 q101010 systemd[1]: snap.lxd.daemon.service: Service hold-off time over, scheduling resta
Dez 21 12:11:28 q101010 systemd[1]: Stopped Service for snap application lxd.daemon.
Dez 21 12:11:28 q101010 systemd[1]: Started Service for snap application lxd.daemon.
Dez 21 12:11:28 q101010 lxd.daemon[14227]: => Preparing the system
Dez 21 12:11:28 q101010 lxd.daemon[14227]: ==> Loading snap configuration
Dez 21 12:11:28 q101010 lxd.daemon[14227]: ==> Setting up mntns symlink (mnt:[4026532495])
Dez 21 12:11:28 q101010 lxd.daemon[14227]: ==> Setting up kmod wrapper
Dez 21 12:11:28 q101010 lxd.daemon[14227]: ==> Preparing /boot
Dez 21 12:11:28 q101010 lxd.daemon[14227]: ==> Preparing a clean copy of /run
any idea to solve this ?
