lxd version 4.0.4
storage zfs
1、create container
2、create snapshot
3、lxc move instance --target ***
Error: Migration operation failure: Copy instance operation failed: Failed instance creation: Error transferring instance data: Create instance: Invalid devices: Failed detecting root disk device: No root device could be found
Please can you show the output of lxc config show <instance>
as well as lxc profile show <profile>
from the source and the target?
lxc config show ins-9a354e59064c40d0a49ba8845a8707ed
architecture: aarch64
image.architecture: arm64
image.description: Centos 8-Stream arm64 (20220316_07:08)
image.os: Centos
image.release: 8-Stream
image.serial: "20220316_07:08"
image.type: squashfs
limits.cpu: "2"
limits.memory: 2048MB
security.privileged: "true"
user.meta-data: "#cloud-config\nlocal-hostname: "
user.name: test
user.user-data: |-
#cloud-config
chpasswd:
list: |
root:P@ssw0rd
expire: false
ssh_pwauth: true
volatile.base_image: b56c78ff2d6232260af95b519e29277930415206b91042f74ed4b9d4cc09c59c
volatile.idmap.base: "0"
volatile.idmap.current: '[]'
volatile.idmap.next: '[]'
'Bus 003 Device 004: ID 1d6b:0104':
productid: "0104"
type: usb
vendorid: 1d6b
pool: zfspool
profiles: []
lxc profile show default
config: {}
description: Default LXD profile for project 02b16d224a5e4710a3fbc0bcce8a27dc
devices: {}
used_by: []
i m try to set lxc profile add default root disk path=/ pool=zfspool,but Not effective
Can you show output of lxc config show <instance>/<snapshot>
Also does it work if there is no snapshot on the instance?
of course
lxc config show ins-ed974686be4a4b2984db083fbeab92c5/zzz
image.os: Centos
limits.cpu: "1"
limits.memory: 1024MB
user.name: ttt
user.user-data: |-
#cloud-config
chpasswd:
list: |
root:P@ssw0rd
expire: false
ssh_pwauth: true
volatile.tap4110b5fd-b0.host_name: tin4110b5fd-b0
volatile.tap4110b5fd-b0.last_state.created: "false"
volatile.tap4110b5fd-b0.last_state.hwaddr: 0e:c8:19:80:c9:e7
volatile.tap4110b5fd-b0.last_state.mtu: "1500"
volatile.tap4110b5fd-b0.name: eth0
pool: zfspool
profiles: []
expires_at: 0001-01-01T00:00:00Z
no snapshot can move success,have snapshot Most cases are failed
ps -ef |grep ins-fe39e9ac24c84010967dc1b460c10c7b
root 2132812 2131748 0 18:30 pts/15 00:00:00 grep ins-fe39e9ac24c84010967dc1b460c10c7b
root 2787137 94630 0 3月17 ? 00:00:00 zfs send -c -L zfspool/containers/02b16d224a5e4710a3fbc0bcce8a27dc_ins-fe39e9ac24c84010967dc1b460c10c7b@snapshot-rtrt
this process will always exist,The snapshot cannot be deleted
Thanks, it shouldn’t be needed as you’re container has its own root disk (shown from lxc config show
without the --expanded
flag).
Can you try refreshing to the latest 4.0 LTS release, LXD 4.0.9
snap refresh lxd --channel=4.0/stable
Which should get you:
4.0/stable: 4.0.9 2022-02-25 (22526) 71MB -
That will rule out if the issue has already been fixed in a later release.
thanks,i’ll try it
