Hello.
I tried to make a random machine-id that should be a single newline-terminated, hexadecimal, 32-character, lowercase ID. 32 zero is an exception and not work.
I don’t find the error. Probably better solution exist too…
When I try to launch my image I have this message and logs: https://hastebin.com/igizisaluc.bash
I had tested to add simple quotes around letters in the array into the pongo2 file but same error… same if I try to add simple quote around all array entries
