Cause I didn’t want to install snap on LM20 ulyana , I downloaded the latest, stable tarball lxd 4.4 and built it myself, following this description here: https://github.com/lxc/lxd/#installing-lxd-from-source
Everything compiled fine so far, until doing the last command:
sudo -E PATH=$PATH LD_LIBRARY_PATH=$LD_LIBRARY_PATH $GOPATH/bin/lxd --group sudo
I got this warnings below, which i definitely don’t know exactly what they mean or if they are really significant:
WARN[08-03|18:25:36] - Couldn't find the CGroup blkio.weight, I/O weight limits will be ignored
WARN[08-03|18:25:36] - Couldn't find the CGroup memory swap accounting, swap limits will be ignored
WARN[08-03|18:25:36] Firewall failed to detect any compatible driver, falling back to "xtables" (but some features may not work as expected due to: Backend command "ebtables" is an nftables shim)
Also the command doesn’t get back to prompt. I have to Ctrl-C it.
The daemon (lxd) doesn’t run (ps axf | grep lxd) is empty and typing “lxc info” i.e. get’s me this error:
Error: Get http://unix.socket/1.0: dial unix /var/lib/lxd/unix.socket: connect: no such file or directory
Really appreciating any hints, cause I don’t know how to proceed.
