Hello
I have difficulties to create LXD containers on an Ubuntu VM using QEMU/KVM. My installation of LXD under the vm is from snap.
beroots@qemukvm:~$id beroots
uid=1000(beroots) gid=1000(beroots) groupes=1000(beroots),4(adm),24(cdrom),27(sudo),30(dip),46(plugdev),120(lpadmin),131(lxd),132(sambashare)
beroots@qemukvm:~$lxc profile show virtbazx-default
config: {}
description: Default LXD profile used by virtbazx
network: lxdbr0
pool: default
used_by: []
beroots@qemukvm:~$ lxc init images:debian/10/cloud/amd64 d10-cloud
Creating d10-cloud
Error: Failed instance creation: Create instance: Create instance: Invalid devices: Failed detecting root disk device: No root device could be found
If someone has an idea ?
