LXD and Snap Auto-Update
Hi everyone,
i am using LXD installed with snap. Till 5 April 22 i wasn’t aware of the fact that snapd is doing auto-updates of all installed snaps. Since the LXD update to version 5, which broke my backup strategy of ‘lxc copy --refresh’ to a remote server, i think about disabling these auto-updates.
I mean this is an Administrators nightmare, unattended updates which could break a whole infrastructure overnight. This time only backups are not possible due to a bug, next time all containers are failing.
Is there a way, you can recommend, to disable updates ? I read about setting timers on snapd which will have to be reset via cron or disabling the snap store with a firewall. How do you handle this topic ?
regards,
Robert
Actually, the cleanest way is to install and use a snap-store-proxy, where you’ll be able to override the version of snap packages for your host.
https://docs.ubuntu.com/snap-store-proxy/en/install
I believe the issue you may be hitting should be fixed now:
Also please take a look at this tutorial as it may help with managing the snap:
Thanks
You may also want to switch to the 5.0/stable LTS channel as this will receive fewer large updates.
We use a simple but effective trick. Add this to the top of your /etc/hosts file:
127.0.0.1 api.snapcraft.io
You will need to comment that out whenever you want to use snap - but this will stop snap from “phoning home” and voila, no more auto updates
Thanks, sounds like an acceptable compromise, switching to a fixed stable branch and only receiving bugfixes and security patches
Yes, simple but effective but rejecting at the firewall would be better for me since i have a dozen lxd/snap installations.
