Hello all
I have ubuntu machine with lxd installed and I am playing with containers and I want to test some apps like docker or k8s inside LXD environment that require the br_netfilter module in network namespaces
because I was not able to enable it inside running container I cant install k8s and other applications which require this module
/proc/sys/net/bridge dir is missing inside container network namespace, however it is enabled and loaded on the host machine
here are my configurations:
HOSTMACHINE:~$ lxc profile show default
linux.kernel_modules: bridge,ip_tables,nf_nat,overlay,br_netfilter
security.privileged: βtrueβ
br0:
nictype: bridged
parent: br0
pool: lxd
src:
path: /usr/src/
source: /usr/src/
- /1.0/containers/tmp
- /1.0/containers/kubetmp
- /1.0/containers/kubemastertmp
- /1.0/containers/centosTMPL
- /1.0/containers/centest
HOSTMACHINE:~# modinfo br_netfilter
filename: /lib/modules/4.18.0-16-generic/kernel/net/bridge/br_netfilter.ko
description: Linux ethernet netfilter firewall bridge
author: Bart De Schuymer <bdschuym@pandora.be>
author: Lennert Buytenhek <buytenh@gnu.org>
license: GPL
srcversion: 46DE53B0B0A82CBC5B9DD7D
depends: bridge
retpoline: Y
intree: Y
vermagic: 4.18.0-16-generic SMP mod_unload
signat: PKCS#7
signer:
sig_key:
sig_hashalgo: md4
HOSTMACHINE:~$ ll /proc/sys/net/
total 0
dr-xr-xr-x 1 root root 0 ααα 19 09:52 ./
dr-xr-xr-x 1 root root 0 ααα 19 09:52 β¦/
dr-xr-xr-x 1 root root 0 ααα 19 09:52 bridge/
dr-xr-xr-x 1 root root 0 ααα 19 09:52 core/
dr-xr-xr-x 1 root root 0 ααα 19 09:52 ipv4/
dr-xr-xr-x 1 root root 0 ααα 19 09:52 ipv6/
dr-xr-xr-x 1 root root 0 ααα 19 13:00 netfilter/
-rw-rβr-- 1 root root 0 ααα 19 13:00 nf_conntrack_max
dr-xr-xr-x 1 root root 0 ααα 19 09:52 unix/
CONTAINER ~]# modinfo br_netfilter
modinfo: ERROR: Module alias br_netfilter not found.
CONTAINER ~]# ll /proc/sys/net/
total 0
dr-xr-xr-x 1 root root 0 ααα 19 08:47 core
dr-xr-xr-x 1 root root 0 ααα 19 05:53 ipv4
dr-xr-xr-x 1 root root 0 ααα 19 05:53 ipv6
dr-xr-xr-x 1 root root 0 ααα 19 05:53 netfilter
dr-xr-xr-x 1 root root 0 ααα 19 05:53 unix
Any idea? plz help
Thank you
