I am creating a network bridge for LXD container on ubuntu 18.04.
gpsemc@lxdtest:~$ ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen …
2: ens160: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel master br0 state UP group default qlen 1000
link/ether 00:50:56:bd:80:72 brd ff:ff:ff:ff:ff:ff
3: br0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 3e:7e:2c:a4:d9:d0 brd ff:ff:ff:ff:ff:ff
inet 10.62.90.254/24 brd 10.62.90.255 scope global br0
inet6 fe80::3c7e:2cff:fea4:d9d0/64 scope link
5: vethFQGO7Y@if4: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br0 state UP group default qlen 1000
Whenever I create a new container the network will be changed automatically
inet 10.146.226.1/24 scope global br0
inet6 fd42:f4ee:39eb:4c7e:3c7e:2cff:fea4:d9d0/64 scope global dynamic mngtmpaddr noprefixroute
valid_lft 3425sec preferred_lft 3425sec
inet6 fd42:f4ee:39eb:4c7e::1/64 scope global
I have no idea how this IP comes from: 10.146.226.1/24. And the container created will be assigned with an IP:
root@test:~# ip addr
inet6 ::1/128 scope host
4: eth0@if5: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:28:f7:45 brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet 10.146.226.108/24 brd 10.146.226.255 scope global dynamic eth0
valid_lft 2789sec preferred_lft 2789sec
inet6 fd42:f4ee:39eb:4c7e:216:3eff:fe28:f745/64 scope global deprecated dynamic mngtmpaddr noprefixroute
valid_lft 6361sec preferred_lft 0sec
inet6 fe80::216:3eff:fe28:f745/64 scope link
The bridge has issue. I need to run sudo netplan apply to recover the network on the host.
Below are the steps of how I create the host and bridge:
Host Setup:
sudo apt-get update
sudo snap install lxd
lxd init
lxd --version: 3.0.3
Refer to this article: https://www.cyberciti.biz/faq/install-lxd-pure-container-hypervisor-on-ubuntu-18-04-lts/
Refer to this article: https://linuxcontainers.org/lxd/getting-started-cli/
Create br0
sudo apt-get install bridge-utils
$ sudo nano /etc/sysctl.conf
Uncomment:
net.ipv4.ip_forward=1
Then, enable the new setting:
$ sudo sysctl -p
As our code hardcode to use a br0,
The rest: refer to https://openschoolsolutions.org/set-up-network-bridge-lxd/
Configure the NIC
Change the network configuration files under /etc/netplan/01-netcfg.yaml. It could be a difference name. Change it like this:
network:
version: 2
renderer: networkd
ethernets:
ens160:
dhcp4: no
bridges:
br0:
interfaces:
- ens160
addresses:
- 10.62.90.254/24
gateway4: 10.62.90.1
nameservers:
addresses:
- 10.254.174.10
dhcp4: no
sudo netplan generate
sudo netplan --debug apply
Refer to this page: https://fabianlee.org/2019/04/01/kvm-creating-a-bridged-network-with-netplan-on-ubuntu-bionic/
Generate the certificate
Refer to this section https://linuxcontainers.org/lxd/docs/master/security → Adding a remote with TLS client certificate authentication
lxc remote add ubuntu1 https://cloud-images.ubuntu.com/releases [This command will fail, but it will generate the certificate anyway]
Then it will generate a client certificate under ~/.config/lxc
Interacting with API
lxc config set core.https_address “[::]:8443”
lxc config set core.trust_password gpsemc
curl --unix-socket /var/lib/lxd/unix.socket s/
sudo apt install jq
curl -s --unix-socket /var/lib/lxd/unix.socket s/ | jq .
curl -s -k --cert ~/.config/lxc/client.crt --key ~/.config/lxc/client.key https://127.0.0.1:8443/1.0 | jq .metadata.auth
curl -s -k --cert ~/.config/lxc/client.crt --key ~/.config/lxc/client.key https://127.0.0.1:8443/1.0/certificates -X POST -d ‘{“type”: “client”, “password”: “gpsemc”}’ | jq .
Refer to this article: https://stgraber.org/2016/04/18/lxd-api-direct-interaction/
