Hi, lxdbr0 use the default host’s ip, for internet access. what would be the way to configure lxdbr0 to use another ip than the host is using for internet access?
You can set the ipv4.nat.address and/or the ipv6.nat.address options on the managed network in LXD to change this, see:
https://linuxcontainers.org/lxd/docs/master/networks#bridges
@tomp hi, been playing with this options for hours, 1 thing tho. say my ISP provide me with 1 eth card. and multiple public ips.
host machine using public_ip_1 .
my provider will allow public_ip_2 3 4 …etc from my eth card.
after adding the ipv4.nat.address nothing happen. well. the question here. do i need to add the public_ip_4 which i wish to use, as additional ip to me eth at first? and do i need any routing or firewalld rules?
Yes absolutely you do, as otherwise the return packets will not arrive.
Unless your ISP has routed you a block of IPs (as opposed to just assigning a range on the same subnet as your main IP).
Ok, bare with me please. what exactly needs to be done here?
am using hetzner. they give random public ips. they provide me ip’s with its own gateway and broadcast and netmask. and an mac address.
if i create a contaner using eth0 source. macvlan then change the mac with hetznet provided mac. i get the public_ip_4 wanted.
but that setup will work only for 1 container.
i wish to use public_ip_4 for nat on multiple containers.
Is your aim to get the extra public IPs inside the containers or to use them as the outbound NAT address for the LXD bridge?
the aim here. well. let me put it this way.
hetzner provides me with list of public ip’s other than the host public ip.
host ip = public_ip_1
another ip = public_ip_2
if we forget i ahve extra public ips for a second.
#1 create lxdbr0 with no additional configs.
#2 create containers. now they have internet access.
#3 create anotehr 4 containers. they ahve different internal ips and still have inernet.
#4 exec all 4 containers curl ifconfig.me
the result they all use the host public_ip_1
my aim for these containers to use another ip. than the hose use. we could say.
So to confirm, you would like to use a different public IP for just some containers, and others still use the host’s IP?
Yes. if that works. i can add anotehr lxdbr{#}. add it to profile depending on my services and public ips.
edit: or i can completely forget about using host_ip . and keep host ip only for host as i ahve additional ips.
Yes adding another managed LXD bridge, and then setting the NAT IP on that one to one of the additional ISP assigned IPs would work, but you would still need to ensure that the additional IP is setup as an alias on the host’s public interface too.
Then, as you say, you can connect the containers you want to the new bridge using either manual per-container config or additional profiles.
all that sound good. am not sure what do you mean by setting up alias.
please ask me to provide any info. ifcfg-eth0 . or any other things.
and will i need firewalld rule? or routes? maybe not. because lxdbr0 by default works on the host. maybe am wrong if so. what should be done please?
So setting up an IP alias is not LXD specific, it would be the same process to just use the additional IP on your host machine. Your ISP probably provides specific instructions for their network to do it.
Unless you have a firewall on your host that is blocking traffic to/from those additional IPs, then I wouldn’t expect you’d need any new firewall rules. LXD will add the necessary outbound NAT firewall rules for you as part of creating the 2nd managed bridge.
As for routing, you shouldn’t need to change any routing, but I’m not familiar with Hetzner’s network setup.
@tomp I managed to add additional ips using hetzner guide.
https://wiki.hetzner.de/index.php/Zusätzliche_IP-Adressen_Suse/en
now create lxdbr1. add ipv4.nat.address for the added ip in previous step.
add lxdbr1 to profile.
create c1 using profile in prev step.
PING google.com (172.217.23.174) 56(84) bytes of data.
^C
--- google.com ping statistics ---
9 packets transmitted, 0 received, 100% packet loss, time 8191ms
root@c1:~# exit```
note: i disabled firewalld while testing.
Please show output of the following commands on host:
ip a
ip r
lxc network show lxdbr1
iptables -L -v -n -t nat
nfw list ruleset
Thanks
@tomp offcourse.
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 5000
link/ether hidden_mac brd ff:ff:ff:ff:ff:ff
inet host_pulic_ip/26 brd xyz scope global eth0
inet public_ip_4/29 brd new_xyz scope global eth0:lxdbr1
9: lxdbr1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UNKNOWN group default qlen 1000
link/ether 3a:2b:12:5b:e0:60 brd ff:ff:ff:ff:ff:ff
inet 10.172.55.1/24 scope global lxdbr1
default via xx.xx.xx.xx dev eth0
10.172.55.0/24 dev lxdbr1 proto kernel scope link src 10.172.55.1
xx.xx.xx.xx/26 dev eth0 proto kernel scope link src host_pulic_ip
xx.xx.xx.yy/29 dev eth0 proto kernel scope link src public_ip_4
ipv4.address: 10.172.55.1/24
ipv4.nat: "true"
ipv4.nat.address: public_ip_4
type: bridge
- /1.0/instances/c1
managed: true
status: Created
locations:
- none
[sudo] password for admin:
Chain PREROUTING (policy ACCEPT 55 packets, 3280 bytes)
pkts bytes target prot opt in out source destination
150 8453 PREROUTING_direct all -- * * 0.0.0.0/0 0.0.0.0/0
150 8453 PREROUTING_ZONES_SOURCE all -- * * 0.0.0.0/0 0.0.0.0/0
150 8453 PREROUTING_ZONES all -- * * 0.0.0.0/0 0.0.0.0/0
Chain INPUT (policy ACCEPT 3 packets, 446 bytes)
Chain OUTPUT (policy ACCEPT 66 packets, 5002 bytes)
294 21842 OUTPUT_direct all -- * * 0.0.0.0/0 0.0.0.0/0
Chain POSTROUTING (policy ACCEPT 66 packets, 5002 bytes)
0 0 SNAT all -- * * 10.172.55.0/24 !10.172.55.0/24 /* generated for LXD network lxdbr1 */ to:public_ip_4
294 21842 POSTROUTING_direct all -- * * 0.0.0.0/0 0.0.0.0/0
294 21842 POSTROUTING_ZONES_SOURCE all -- * * 0.0.0.0/0 0.0.0.0/0
294 21842 POSTROUTING_ZONES all -- * * 0.0.0.0/0 0.0.0.0/0
Chain OUTPUT_direct (1 references)
Chain POSTROUTING_ZONES (1 references)
0 0 POST_public all -- * eth0 0.0.0.0/0 0.0.0.0/0 [goto]
0 0 POST_mailer all -- * br0 0.0.0.0/0 0.0.0.0/0
0 0 POST_internal all -- * br1 0.0.0.0/0 0.0.0.0/0 [goto]
294 21842 POST_public all -- * + 0.0.0.0/0 0.0.0.0/0 [goto]
Chain POSTROUTING_ZONES_SOURCE (1 references)
Chain POST_internal (1 references)
0 0 POST_internal_log all -- * * 0.0.0.0/0 0.0.0.0/0
0 0 POST_internal_deny all -- * * 0.0.0.0/0 0.0.0.0/0
0 0 POST_internal_allow all -- * * 0.0.0.0/0 0.0.0.0/0
Chain POST_internal_allow (1 references)
Chain POST_internal_deny (1 references)
Chain POST_internal_log (1 references)
Chain POST_mailer (1 references)
0 0 POST_mailer_log all -- * * 0.0.0.0/0 0.0.0.0/0
0 0 POST_mailer_deny all -- * * 0.0.0.0/0 0.0.0.0/0
0 0 POST_mailer_allow all -- * * 0.0.0.0/0 0.0.0.0/0
Chain POST_mailer_allow (1 references)
0 0 MASQUERADE all -- * !lo 0.0.0.0/0 0.0.0.0/0
Chain POST_mailer_deny (1 references)
Chain POST_mailer_log (1 references)
Chain POST_public (2 references)
294 21842 POST_public_log all -- * * 0.0.0.0/0 0.0.0.0/0
294 21842 POST_public_deny all -- * * 0.0.0.0/0 0.0.0.0/0
294 21842 POST_public_allow all -- * * 0.0.0.0/0 0.0.0.0/0
Chain POST_public_allow (1 references)
Chain POST_public_deny (1 references)
Chain POST_public_log (1 references)
Chain PREROUTING_ZONES (1 references)
69 3683 PRE_public all -- eth0 * 0.0.0.0/0 0.0.0.0/0 [goto]
18 1712 PRE_public all -- + * 0.0.0.0/0 0.0.0.0/0 [goto]
Chain PREROUTING_ZONES_SOURCE (1 references)
Chain PREROUTING_direct (1 references)
Chain PRE_internal (1 references)
0 0 PRE_internal_log all -- * * 0.0.0.0/0 0.0.0.0/0
0 0 PRE_internal_deny all -- * * 0.0.0.0/0 0.0.0.0/0
0 0 PRE_internal_allow all -- * * 0.0.0.0/0 0.0.0.0/0
Chain PRE_internal_allow (1 references)
Chain PRE_internal_deny (1 references)
Chain PRE_internal_log (1 references)
Chain PRE_mailer_allow (1 references)
Chain PRE_mailer_deny (1 references)
Chain PRE_mailer_log (1 references)
Chain PRE_public (2 references)
150 8453 PRE_public_log all -- * * 0.0.0.0/0 0.0.0.0/0
150 8453 PRE_public_deny all -- * * 0.0.0.0/0 0.0.0.0/0
150 8453 PRE_public_allow all -- * * 0.0.0.0/0 0.0.0.0/0
Chain PRE_public_allow (1 references)
Chain PRE_public_deny (1 references)
Chain PRE_public_log (1 references)
nfw list ruleset
sudo: nfw: command not found
Great thanks.
Can you ping the public_ip_4 address from an outside host, to check that the IP alias is working.
Also, the iptables SNAT rule doesn’t appear to be being hit:
I’d expect a non-zero packet counter if your outbound pings were being NATted.
Next step is to run tcpdumps on the lxdbr1 and external interface and check where those ICMP packets are going and what source address they have.
No, i can not ping it.
6 packets transmitted, 0 received, 100% packet loss, time 5105ms
why its snat rather than masquerade. on my local machine running same commands shows lxdbr0 masquerade
am running into class, right now. anything else will be able to do it after couple of hours.
OK so don’t worry about NAT for now, if that IP alias isn’t pingable then that needs fixing. You need to use tcpdump on the external interface to check if packets are coming in or going out.
SNAT is used instead of masquerade because you are using a fixed outbound source IP, whereas masquerade just takes the first IP on the outgoing interface (which is the original problem you’re trying to avoid).
@tomp, thank you. some strange ips there tho. please test result below.
listening on eth0, link-type EN10MB (Ethernet), capture size 262144 bytes
17:37:03.560618 IP public_ip_home > public_ip_host: ICMP echo request, id 45310, seq 2467, length 64
17:37:03.560698 IP public_ip_host > public_ip_home: ICMP echo reply, id 45310, seq 2467, length 64
17:37:03.823054 IP public_ip_4 > 172.217.23.174: ICMP echo request, id 486, seq 216, length 64
17:37:04.040660 IP public_ip_home > public_ip_4: ICMP echo request, id 45406, seq 2409, length 64
17:37:04.563234 IP public_ip_home > public_ip_host: ICMP echo request, id 45310, seq 2468, length 64
17:37:04.563310 IP public_ip_host > public_ip_home: ICMP echo reply, id 45310, seq 2468, length 64
17:37:04.847046 IP public_ip_4 > 172.217.23.174: ICMP echo request, id 486, seq 217, length 64
17:37:05.064416 IP public_ip_home > public_ip_4: ICMP echo request, id 45406, seq 2410, length 64
17:37:05.563564 IP public_ip_home > public_ip_host: ICMP echo request, id 45310, seq 2469, length 64
17:37:05.563644 IP public_ip_host > public_ip_home: ICMP echo reply, id 45310, seq 2469, length 64
17:37:05.871045 IP public_ip_4 > 172.217.23.174: ICMP echo request, id 486, seq 218, length 64
17:37:06.088535 IP public_ip_home > public_ip_4: ICMP echo request, id 45406, seq 2411, length 64
17:37:06.564807 IP public_ip_home > public_ip_host: ICMP echo request, id 45310, seq 2470, length 64
17:37:06.564887 IP public_ip_host > public_ip_home: ICMP echo reply, id 45310, seq 2470, length 64
17:37:06.895048 IP public_ip_4 > 172.217.23.174: ICMP echo request, id 486, seq 219, length 64
17:37:07.112426 IP public_ip_home > public_ip_4: ICMP echo request, id 45406, seq 2412, length 64
17:37:07.566205 IP public_ip_home > public_ip_host: ICMP echo request, id 45310, seq 2471, length 64
17:37:07.566284 IP public_ip_host > public_ip_home: ICMP echo reply, id 45310, seq 2471, length 64
17:37:07.918856 IP public_ip_4 > 172.217.23.174: ICMP echo request, id 486, seq 220, length 64
17:37:08.136436 IP public_ip_home > public_ip_4: ICMP echo request, id 45406, seq 2413, length 64
17:37:08.567580 IP public_ip_home > public_ip_host: ICMP echo request, id 45310, seq 2472, length 64
17:37:08.567660 IP public_ip_host > public_ip_home: ICMP echo reply, id 45310, seq 2472, length 64
17:37:08.943042 IP public_ip_4 > 172.217.23.174: ICMP echo request, id 486, seq 221, length 64
17:37:09.160433 IP public_ip_home > public_ip_4: ICMP echo request, id 45406, seq 2414, length 64
17:37:09.568899 IP public_ip_home > public_ip_host: ICMP echo request, id 45310, seq 2473, length 64
17:37:09.568981 IP public_ip_host > public_ip_home: ICMP echo reply, id 45310, seq 2473, length 64
17:37:09.967055 IP public_ip_4 > 172.217.23.174: ICMP echo request, id 486, seq 222, length 64
17:37:10.184578 IP public_ip_home > public_ip_4: ICMP echo request, id 45406, seq 2415, length 64
17:37:10.570093 IP public_ip_home > public_ip_host: ICMP echo request, id 45310, seq 2474, length 64
17:37:10.570174 IP public_ip_host > public_ip_home: ICMP echo reply, id 45310, seq 2474, length 64
17:37:10.991047 IP public_ip_4 > 172.217.23.174: ICMP echo request, id 486, seq 223, length 64
17:37:11.208459 IP public_ip_home > public_ip_4: ICMP echo request, id 45406, seq 2416, length 64
17:37:11.479304 IP public_ip_host > 103.98.160.50: ICMP host public_ip_host unreachable - admin prohibited, length 48
17:37:11.571126 IP public_ip_home > public_ip_host: ICMP echo request, id 45310, seq 2475, length 64
17:37:11.571206 IP public_ip_host > public_ip_home: ICMP echo reply, id 45310, seq 2475, length 64
17:37:12.014969 IP public_ip_4 > 172.217.23.174: ICMP echo request, id 486, seq 224, length 64
17:37:12.232526 IP public_ip_home > public_ip_4: ICMP echo request, id 45406, seq 2417, length 64
17:37:12.572377 IP public_ip_home > public_ip_host: ICMP echo request, id 45310, seq 2476, length 64
17:37:12.572457 IP public_ip_host > public_ip_home: ICMP echo reply, id 45310, seq 2476, length 64
17:37:13.039047 IP public_ip_4 > 172.217.23.174: ICMP echo request, id 486, seq 225, length 64
17:37:13.257252 IP public_ip_home > public_ip_4: ICMP echo request, id 45406, seq 2418, length 64
17:37:13.573765 IP public_ip_home > public_ip_host: ICMP echo request, id 45310, seq 2477, length 64
17:37:13.573845 IP public_ip_host > public_ip_home: ICMP echo reply, id 45310, seq 2477, length 64
17:37:14.063054 IP public_ip_4 > 172.217.23.174: ICMP echo request, id 486, seq 226, length 64
17:37:14.280567 IP public_ip_home > public_ip_4: ICMP echo request, id 45406, seq 2419, length 64
17:37:14.575151 IP public_ip_home > public_ip_host: ICMP echo request, id 45310, seq 2478, length 64
17:37:14.575231 IP public_ip_host > public_ip_home: ICMP echo reply, id 45310, seq 2478, length 64
17:37:15.087044 IP public_ip_4 > 172.217.23.174: ICMP echo request, id 486, seq 227, length 64
17:37:15.304519 IP public_ip_home > public_ip_4: ICMP echo request, id 45406, seq 2420, length 64
17:37:15.576490 IP public_ip_home > public_ip_host: ICMP echo request, id 45310, seq 2479, length 64
17:37:15.576570 IP public_ip_host > public_ip_home: ICMP echo reply, id 45310, seq 2479, length 64
17:37:16.111052 IP public_ip_4 > 172.217.23.174: ICMP echo request, id 486, seq 228, length 64
17:37:16.328365 IP public_ip_home > public_ip_4: ICMP echo request, id 46004, seq 2421, length 64
17:37:16.577755 IP public_ip_home > public_ip_host: ICMP echo request, id 45310, seq 2480, length 64
17:37:16.577836 IP public_ip_host > public_ip_home: ICMP echo reply, id 45310, seq 2480, length 64
17:37:17.135053 IP public_ip_4 > 172.217.23.174: ICMP echo request, id 486, seq 229, length 64
17:37:17.352556 IP public_ip_home > public_ip_4: ICMP echo request, id 46004, seq 2422, length 64
17:37:17.578711 IP public_ip_home > public_ip_host: ICMP echo request, id 45310, seq 2481, length 64
17:37:17.578791 IP public_ip_host > public_ip_home: ICMP echo reply, id 45310, seq 2481, length 64
17:37:18.159056 IP public_ip_4 > 172.217.23.174: ICMP echo request, id 486, seq 230, length 64
17:37:18.376543 IP public_ip_home > public_ip_4: ICMP echo request, id 46004, seq 2423, length 64
17:37:18.580395 IP public_ip_home > public_ip_host: ICMP echo request, id 45310, seq 2482, length 64
17:37:18.580475 IP public_ip_host > public_ip_home: ICMP echo reply, id 45310, seq 2482, length 64
17:37:19.183056 IP public_ip_4 > 172.217.23.174: ICMP echo request, id 486, seq 231, length 64
17:37:19.400357 IP public_ip_home > public_ip_4: ICMP echo request, id 46004, seq 2424, length 64
17:37:19.581469 IP public_ip_home > public_ip_host: ICMP echo request, id 45310, seq 2483, length 64
17:37:19.581550 IP public_ip_host > public_ip_home: ICMP echo reply, id 45310, seq 2483, length 64
17:37:20.207045 IP public_ip_4 > 172.217.23.174: ICMP echo request, id 486, seq 232, length 64
17:37:20.424281 IP public_ip_home > public_ip_4: ICMP echo request, id 46004, seq 2425, length 64
17:37:20.582531 IP public_ip_home > public_ip_host: ICMP echo request, id 45310, seq 2484, length 64
17:37:20.582610 IP public_ip_host > public_ip_home: ICMP echo reply, id 45310, seq 2484, length 64
17:37:21.231080 IP public_ip_4 > 172.217.23.174: ICMP echo request, id 486, seq 233, length 64
17:37:21.448287 IP public_ip_home > public_ip_4: ICMP echo request, id 46004, seq 2426, length 64
17:37:21.584033 IP public_ip_home > public_ip_host: ICMP echo request, id 45310, seq 2485, length 64
17:37:21.584112 IP public_ip_host > public_ip_home: ICMP echo reply, id 45310, seq 2485, length 64
17:37:22.255045 IP public_ip_4 > 172.217.23.174: ICMP echo request, id 486, seq 234, length 64
17:37:22.472555 IP public_ip_home > public_ip_4: ICMP echo request, id 46004, seq 2427, length 64
17:37:22.585042 IP public_ip_home > public_ip_host: ICMP echo request, id 45310, seq 2486, length 64
17:37:22.585121 IP public_ip_host > public_ip_home: ICMP echo reply, id 45310, seq 2486, length 64
17:37:23.279080 IP public_ip_4 > 172.217.23.174: ICMP echo request, id 486, seq 235, length 64
17:37:23.496676 IP public_ip_home > public_ip_4: ICMP echo request, id 46004, seq 2428, length 64
17:37:23.586339 IP public_ip_home > public_ip_host: ICMP echo request, id 45310, seq 2487, length 64
17:37:23.586418 IP public_ip_host > public_ip_home: ICMP echo reply, id 45310, seq 2487, length 64
17:37:24.303045 IP public_ip_4 > 172.217.23.174: ICMP echo request, id 486, seq 236, length 64
17:37:24.520313 IP public_ip_home > public_ip_4: ICMP echo request, id 46004, seq 2429, length 64
17:37:24.587545 IP public_ip_home > public_ip_host: ICMP echo request, id 45310, seq 2488, length 64
17:37:24.587625 IP public_ip_host > public_ip_home: ICMP echo reply, id 45310, seq 2488, length 64
17:37:25.330808 IP public_ip_4 > 172.217.23.174: ICMP echo request, id 486, seq 237, length 64
17:37:25.544387 IP public_ip_home > public_ip_4: ICMP echo request, id 46004, seq 2430, length 64
17:37:25.588850 IP public_ip_home > public_ip_host: ICMP echo request, id 45310, seq 2489, length 64
17:37:25.588929 IP public_ip_host > public_ip_home: ICMP echo reply, id 45310, seq 2489, length 64
17:37:26.351045 IP public_ip_4 > 172.217.23.174: ICMP echo request, id 486, seq 238, length 64
17:37:26.568436 IP public_ip_home > public_ip_4: ICMP echo request, id 46004, seq 2431, length 64
17:37:26.589876 IP public_ip_home > public_ip_host: ICMP echo request, id 45310, seq 2490, length 64
17:37:26.589955 IP public_ip_host > public_ip_home: ICMP echo reply, id 45310, seq 2490, length 64
17:37:27.196452 IP public_ip_host > 103.72.8.7: ICMP host public_ip_host unreachable - admin prohibited, length 52
17:37:27.374821 IP public_ip_4 > 172.217.23.174: ICMP echo request, id 486, seq 239, length 64
17:37:27.591827 IP public_ip_home > public_ip_host: ICMP echo request, id 45310, seq 2491, length 64
17:37:27.591907 IP public_ip_host > public_ip_home: ICMP echo reply, id 45310, seq 2491, length 64
17:37:27.592378 IP public_ip_home > public_ip_4: ICMP echo request, id 46004, seq 2432, length 64
17:37:28.399043 IP public_ip_4 > 172.217.23.174: ICMP echo request, id 486, seq 240, length 64
17:37:28.593318 IP public_ip_home > public_ip_host: ICMP echo request, id 45310, seq 2492, length 64
17:37:28.593394 IP public_ip_host > public_ip_home: ICMP echo reply, id 45310, seq 2492, length 64
17:37:28.616202 IP public_ip_home > public_ip_4: ICMP echo request, id 46004, seq 2433, length 64
17:37:29.422799 IP public_ip_4 > 172.217.23.174: ICMP echo request, id 486, seq 241, length 64
17:37:29.594302 IP public_ip_home > public_ip_host: ICMP echo request, id 45310, seq 2493, length 64
17:37:29.594381 IP public_ip_host > public_ip_home: ICMP echo reply, id 45310, seq 2493, length 64
17:37:29.640416 IP public_ip_home > public_ip_4: ICMP echo request, id 46004, seq 2434, length 64
17:37:30.447049 IP public_ip_4 > 172.217.23.174: ICMP echo request, id 486, seq 242, length 64
17:37:30.596396 IP public_ip_home > public_ip_host: ICMP echo request, id 45310, seq 2494, length 64
17:37:30.596459 IP public_ip_host > public_ip_home: ICMP echo reply, id 45310, seq 2494, length 64
17:37:30.664291 IP public_ip_home > public_ip_4: ICMP echo request, id 46004, seq 2435, length 64
17:37:31.470941 IP public_ip_4 > 172.217.23.174: ICMP echo request, id 486, seq 243, length 64
17:37:31.598388 IP public_ip_home > public_ip_host: ICMP echo request, id 45310, seq 2495, length 64
17:37:31.598461 IP public_ip_host > public_ip_home: ICMP echo reply, id 45310, seq 2495, length 64
17:37:31.688326 IP public_ip_home > public_ip_4: ICMP echo request, id 46004, seq 2436, length 64
17:37:32.495052 IP public_ip_4 > 172.217.23.174: ICMP echo request, id 486, seq 244, length 64
17:37:32.599661 IP public_ip_home > public_ip_host: ICMP echo request, id 45310, seq 2496, length 64
17:37:32.599742 IP public_ip_host > public_ip_home: ICMP echo reply, id 45310, seq 2496, length 64
17:37:32.712736 IP public_ip_home > public_ip_4: ICMP echo request, id 46004, seq 2437, length 64
