lk7777
November 8, 2019, 5:28pm
1
host: Ubuntu 18.04 LXD/LXC 3.0.3
I am trying to use ALSA in my ubuntu 18.04 container. ALSA on host works. I have seen this post but it doesn’t work for me.
My configuration:
lxc config set mycontainer raw.lxc "lxc.cgroup.devices.allow = c 116:* rwm"
lxc config set mycontainer raw.lxc "lxc.mount.entry = /dev/snd dev/snd none bind,optional,create=dir 0 0"
aplay: aplay -l aplay: device_list:270: no soundcards found…
ALSA on the host works perfectly well.
I need it for a home automation text-to-speech functionality.
What else do I need to do to get it working?
Thank you in advance.
simos
(Simos Xenitellis)
November 8, 2019, 5:51pm
2
Hi!
Does your host have Pulseaudio?
If the software can use Pulseaudio instead, then you can share the Pulseaudio’s Unix socket. It’s a single thing to do. See more on this at https://blog.simos.info/how-to-easily-run-graphics-accelerated-gui-apps-in-lxd-containers-on-your-ubuntu-desktop/
lk7777
November 8, 2019, 6:02pm
3
@simos ,
Thank you for this info. I would prefer not to install pulseaudio on my host/server, it would be much simpler to use ALSA if it is possible of course.
lk7777
November 8, 2019, 7:00pm
4
I guess, I have managed to get it working.
Found this post
lxc config device add <container> pcmC0D2c unix-char path=/dev/snd/pcmC0D2c
I have added all devices listed in /dev/snd:
controlC0 hwC0D0 hwC0D2 pcmC0D0c pcmC0D0p pcmC0D10p pcmC0D1p pcmC0D2c pcmC0D3p pcmC0D7p pcmC0D8p pcmC0D9p seq timer
It is important to add seq and timer, as well.
abcfy2
(Feng Yu)
March 10, 2020, 3:52am
5
It seems that /dev/snd/pcmXXXX are random. When reboot the host, all /dev/snd/pcmXXXX changes. So I think mount /run/user/<uid>/pulse/native to container is easier.
Have you managed to find “permanent” flexible solution for it, if pcmXXX are indeed random as mentioned by @abcfy2 ?
lk7777
March 3, 2021, 10:10pm
7
I do not think that they are random. Check this article. I have restarted my server numerous times and those pcm’s have never been changed.
@lk7777 , have you had to manualy change group for container’s /dev/snd/* devices? Mine were owned by root and not audio so I couldn’t get aplay to work till I reworked my audio profile to include gid.
Also, it appeared that lxc config set mycontainer raw.lxc is not required, at lest speaker-test works without it.
So for anyone interested (I’m using RaspberryPi 4, so it probably should work for others)
user.user-data: |
#cloud-config
packages:
- alsa-utils
description: ALSA LXD profile
controlC0:
gid: "29"
path: /dev/snd/controlC0
type: unix-char
controlC1:
gid: "29"
path: /dev/snd/controlC1
type: unix-char
pcmC0D0p:
gid: "29"
path: /dev/snd/pcmC0D0p
type: unix-char
pcmC1D0p:
gid: "29"
path: /dev/snd/pcmC1D0p
type: unix-char
seq:
gid: "29"
path: /dev/snd/seq
type: unix-char
timer:
gid: "29"
path: /dev/snd/timer
type: unix-char
lk7777
March 5, 2021, 8:46pm
9
On my host /dev/snd root:audio and I do use mounting:
One thing that I added to the configuration is mode: "0666"
So it looks like this:
seq:
mode: "0666"
path: /dev/snd/seq
type: unix-char
"mode: “0666” - that explains.
It works, but, probably, not inline with recommendations, as host’s policy is “0660” for those. Ok, tnx!
lk7777
March 5, 2021, 11:05pm
11
I know it is dirty but I trust my container, there is nothing to worry about, it is just a /snd
