hey folks, I’m trying to launch an lxc container (ubuntu bionic) and I’m seeing a strange issue, the lxd is running on a virtualbox vm provisioned by vagrant. I guess the issue is Vagrant-related as I’ve not experienced this before.
errors:
ubuntu@ubuntu-bionic:~$ lxc launch ubuntu:bionic test
Creating test
Starting test
Error: Failed to run: /snap/lxd/current/bin/lxd forkstart test /var/snap/lxd/common/lxd/containers /var/snap/lxd/common/lxd/logs/test/lxc.conf:
Try `lxc info --show-log local:test` for more info
ubuntu@ubuntu-bionic:~$ lxc info --show-log local:test
Remote: unix://
Created: 2019/04/25 07:45 UTC
Status: Stopped
Type: persistent
Profiles: default
Log:
lxc test 20190425074521.897 ERROR network - network.c:lxc_ovs_attach_bridge:1887 - Failed to attach "enp0s8" to openvswitch bridge "vethVI2UKS": ovs-vsctl:
lxc test 20190425074521.897 ERROR network - network.c:instantiate_veth:172 - Operation not permitted - Failed to attach "vethVI2UKS" to bridge "enp0s8"
lxc test 20190425074521.909 ERROR network - network.c:lxc_create_network_priv:2457 - Failed to create network device
lxc test 20190425074521.909 ERROR start - start.c:lxc_spawn:1649 - Failed to create the network
lxc test 20190425074521.910 WARN network - network.c:lxc_delete_network_priv:2610 - Failed to remove interface "vethVI2UKS" from "enp0s8"
lxc test 20190425074521.910 ERROR start - start.c:__lxc_start:1975 - Failed to spawn container "test"
lxc test 20190425074521.911 WARN conf - conf.c:lxc_map_ids:2970 - newuidmap binary is missing
lxc test 20190425074521.911 WARN conf - conf.c:lxc_map_ids:2976 - newgidmap binary is missing
lxc test 20190425074521.912 ERROR lxccontainer - lxccontainer.c:wait_on_daemonized_start:864 - Received container state "ABORTING" instead of "RUNNING"
lxc 20190425074521.912 WARN commands - commands.c:lxc_cmd_rsp_recv:132 - Connection reset by peer - Failed to receive response for command "get_state"
