Now in LXD there is a nvidia.runtime key that makes LXD to put the appropriate runtime into the container so that you do not have to. Hence, you avoid the version mismatch issues.
Creating cuda
Starting cuda
Error: Failed to run: /snap/lxd/current/bin/lxd forkstart cuda /var/snap/lxd/common/lxd/containers /var/snap/lxd/common/lxd/logs/cuda/lxc.conf:
Try `lxc info --show-log local:cuda` for more info
lxc info --show-log cuda
Remote: unix://
Created: 2020/10/13 11:09 UTC
Status: Stopped
Type: container
Profiles: gpu-pass
Log:
lxc cuda 20201013110904.104 WARN cgfsng - cgroups/cgfsng.c:mkdir_eexist_on_last:1152 - File exists - Failed to create directory "/sys/fs/cgroup/cpuset//lxc.monitor.cuda"
lxc cuda 20201013110904.104 WARN cgfsng - cgroups/cgfsng.c:mkdir_eexist_on_last:1152 - File exists - Failed to create directory "/sys/fs/cgroup/cpuset//lxc.payload.cuda"
lxc cuda 20201013110904.189 ERROR conf - conf.c:run_buffer:324 - Script exited with status 1
lxc cuda 20201013110904.190 ERROR conf - conf.c:lxc_setup:3292 - Failed to run mount hooks
lxc cuda 20201013110904.190 ERROR start - start.c:do_start:1224 - Failed to setup container "cuda"
lxc cuda 20201013110904.190 ERROR sync - sync.c:__sync_wait:41 - An error occurred in another process (expected sequence number 5)
lxc cuda 20201013110904.192 WARN network - network.c:lxc_delete_network_priv:3185 - Failed to rename interface with index 0 from "eth0" to its initial name "vethbbb99d3b"
lxc cuda 20201013110904.192 ERROR lxccontainer - lxccontainer.c:wait_on_daemonized_start:850 - Received container state "ABORTING" instead of "RUNNING"
lxc cuda 20201013110904.192 ERROR start - start.c:__lxc_start:1999 - Failed to spawn container "cuda"
lxc cuda 20201013110904.192 WARN start - start.c:lxc_abort:1019 - No such process - Failed to send SIGKILL via pidfd 31 for process 35741
lxc 20201013110904.316 WARN commands - commands.c:lxc_cmd_rsp_recv:124 - Connection reset by peer - Failed to receive response for command "get_state"
