Error: Common start logic: Set volatile.last_state.idmap config key on container “mail” (id 6): Failed to write backup file: open /var/lib/lxd/containers/mail/backup.yaml: read-only file system
Error: root@xxxxxx:~# btrfs scrub start -Bf /dev/md3
ERROR: scrubbing /dev/md3 failed for device id 1: ret=-1, errno=30 (Read-only file system)
scrub canceled for 1ab9b6cd-ccdc-422b-b185-dfe1c5f201db
scrub started at Mon Jul 1 10:49:46 2019 and was aborted after 00:00:00
total bytes scrubbed: 0.00B with 0 errors
dmesg
: [25752825.641678] BTRFS error (device md3): parent transid verify failed on 236271091712 wanted 1451217 found 1450823
[25752825.646371] BTRFS error (device md3): parent transid verify failed on 236271091712 wanted 1451217 found 1450823
