Sure!
The output of lxc start aqua-golive --debug is
DBUG[09-03|00:43:58] Connecting to a local LXD over a Unix socket
DBUG[09-03|00:43:58] Sending request to LXD method=GET url=http://unix.socket/1.0 etag=
DBUG[09-03|00:43:58] Got response struct from LXD
"config": {},
"api_extensions": [
"storage_zfs_remove_snapshots",
"container_host_shutdown_timeout",
"container_stop_priority",
"container_syscall_filtering",
"auth_pki",
"container_last_used_at",
"etag",
"patch",
"usb_devices",
"https_allowed_credentials",
"image_compression_algorithm",
"directory_manipulation",
"container_cpu_time",
"storage_zfs_use_refquota",
"storage_lvm_mount_options",
"network",
"profile_usedby",
"container_push",
"container_exec_recording",
"certificate_update",
"container_exec_signal_handling",
"gpu_devices",
"container_image_properties",
"migration_progress",
"id_map",
"network_firewall_filtering",
"network_routes",
"storage",
"file_delete",
"file_append",
"network_dhcp_expiry",
"storage_lvm_vg_rename",
"storage_lvm_thinpool_rename",
"network_vlan",
"image_create_aliases",
"container_stateless_copy",
"container_only_migration",
"storage_zfs_clone_copy",
"unix_device_rename",
"storage_lvm_use_thinpool",
"storage_rsync_bwlimit",
"network_vxlan_interface",
"storage_btrfs_mount_options",
"entity_description",
"image_force_refresh",
"storage_lvm_lv_resizing",
"id_map_base",
"file_symlinks",
"container_push_target",
"network_vlan_physical",
"storage_images_delete",
"container_edit_metadata",
"container_snapshot_stateful_migration",
"storage_driver_ceph",
"storage_ceph_user_name",
"resource_limits",
"storage_volatile_initial_source",
"storage_ceph_force_osd_reuse",
"storage_block_filesystem_btrfs",
"resources",
"kernel_limits",
"storage_api_volume_rename",
"macaroon_authentication",
"network_sriov",
"console",
"restrict_devlxd",
"migration_pre_copy",
"infiniband",
"maas_network",
"devlxd_events",
"proxy",
"network_dhcp_gateway",
"file_get_symlink",
"network_leases",
"unix_device_hotplug",
"storage_api_local_volume_handling",
"operation_description",
"clustering",
"event_lifecycle",
"storage_api_remote_volume_handling",
"nvidia_runtime",
"candid_authentication",
"candid_config",
"candid_config_key",
"usb_optional_vendorid",
"id_map_current"
"api_status": "stable",
"api_version": "1.0",
"auth": "trusted",
"public": false,
"auth_methods": [
"tls"
"environment": {
"addresses": [],
"architectures": [
"x86_64",
"i686"
"certificate": "-----BEGIN CERTIFICATE-----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\n5/O2uRDy4Iguy+/oIrtQive63wLmaABpFdfV6gRA0tQ1A7d8suNd+2Y=\n-----END CERTIFICATE-----\n",
"certificate_fingerprint": "a2a2f2afa3d6bb312feca2349aadf3eb34ec5de6b005237ef10c6fa71b4ff3d9",
"driver": "lxc",
"driver_version": "3.0.4",
"kernel": "Linux",
"kernel_architecture": "x86_64",
"kernel_features": null,
"kernel_version": "5.11.0-27-generic",
"lxc_features": null,
"project": "",
"server": "lxd",
"server_clustered": false,
"server_name": "aquaworld-HVM-domU",
"server_pid": 7569,
"server_version": "3.0.4",
"storage": "",
"storage_version": ""
DBUG[09-03|00:43:58] Sending request to LXD method=GET url=http://unix.socket/1.0/containers/aqua-golive etag=
"architecture": "x86_64",
"config": {
"image.architecture": "x86_64",
"image.description": "Ubuntu 18.04 LTS server (20190424)",
"image.os": "ubuntu",
"image.release": "bionic",
"volatile.base_image": "b20f0cac0892cee029e5c65e8a36c7684e0d685bd0b22f839af5fd81a51b5f16",
"volatile.eth0.hwaddr": "00:16:3e:cb:59:03",
"volatile.idmap.base": "0",
"volatile.idmap.current": "[{\"Isuid\":true,\"Isgid\":false,\"Hostid\":1000000,\"Nsid\":0,\"Maprange\":1000000000},{\"Isuid\":false,\"Isgid\":true,\"Hostid\":1000000,\"Nsid\":0,\"Maprange\":1000000000}]",
"volatile.idmap.next": "[{\"Isuid\":true,\"Isgid\":false,\"Hostid\":1000000,\"Nsid\":0,\"Maprange\":1000000000},{\"Isuid\":false,\"Isgid\":true,\"Hostid\":1000000,\"Nsid\":0,\"Maprange\":1000000000}]",
"volatile.last_state.idmap": "[{\"Isuid\":true,\"Isgid\":false,\"Hostid\":1000000,\"Nsid\":0,\"Maprange\":1000000000},{\"Isuid\":false,\"Isgid\":true,\"Hostid\":1000000,\"Nsid\":0,\"Maprange\":1000000000}]",
"volatile.last_state.power": "STOPPED"
"devices": {},
"ephemeral": false,
"profiles": [
"default"
"stateful": false,
"description": "",
"created_at": "2021-06-27T21:50:45+05:45",
"expanded_config": {
"expanded_devices": {
"eth0": {
"name": "eth0",
"nictype": "bridged",
"parent": "lxdbr0",
"type": "nic"
"root": {
"path": "/",
"pool": "default",
"type": "disk"
"name": "aqua-golive",
"status": "Stopped",
"status_code": 102,
"last_used_at": "2021-06-27T21:52:26.80536393+05:45",
"location": ""
DBUG[09-03|00:43:58] Connected to the websocket
DBUG[09-03|00:43:58] Sending request to LXD method=PUT url=http://unix.socket/1.0/containers/aqua-golive/state etag=
"action": "start",
"timeout": 0,
"force": false,
"stateful": false
DBUG[09-03|00:43:58] Got operation from LXD
"id": "671fdc50-cfd9-4b7c-a389-59ac47f70dc2",
"class": "task",
"description": "Starting container",
"created_at": "2021-09-03T00:43:58.659531156+05:45",
"updated_at": "2021-09-03T00:43:58.659531156+05:45",
"status": "Running",
"status_code": 103,
"resources": {
"containers": [
"/1.0/containers/aqua-golive"
"metadata": null,
"may_cancel": false,
"err": "",
"location": "none"
DBUG[09-03|00:43:58] Sending request to LXD method=GET url=http://unix.socket/1.0/operations/671fdc50-cfd9-4b7c-a389-59ac47f70dc2 etag=
"class": "task",
"status_code": 103,
"resources": {
"containers": [
"metadata": null,
"err": "",
"location": "none"
Error: Common start logic: The "zfs" tool is not enabled
Try `lxc info --show-log aqua-golive` for more info
