Any recommendations as whether to use LXD containers or LXD VMs as hosts for Kubernetes nodes?
Or Maybe just don’t use LXD at all? (The setup I’m planning is permanent, not test nor dev, so maybe, even if I like the idea of it, it is best not to use LXD for such a setup).
I have found several blogs and videos explaining how to run K8S on top of LXD containers but not much about running it on top of LXD VMs
I’m guessing using VMs is so straight forward that nobody felt the need to make a blog post or a video…
When using LXD VMs, do you still have to take care about the special parameters required for LXD containers?
Specifically, can you use ZFS? And if not, what’s the recommended option, Ext4?
Thank you!
@tomp Sorry for the direct mention, but I have seen you responding to other “K8S on top of LXD” questions before.
