TL;DR: With LXD on a non-ubuntu host, what would cause containers using ubuntu images to get an ipv6 dhcp address, but not ipv4, and yet alpine images do get an ipv4 address?
I run LXD-3.3 packaged to build from source on Gentoo Linux ~amd64. Sometime after LXD-2.0.x (on my Gentoo laptop host), containers using ubuntu images stopped getting ipv4 addresses from DHCP, but do get ipv6 addresses. Alpine images do get ipv4 dhcp addresses, so dnsmasq is working properly.
I don’t have this problem on Ubuntu LXD hosts. Is there a post-install configuration step by Ubuntu LXD .deb packaging that enables dhcp ipv4 for ubuntu images from the ubuntu: or images: remotes? Some default cloud-init config perhaps? I haven’t been able to find any relevant configuration when examining ubuntu lxd hosts.
$ lxc list
| NAME | STATE | IPV4 | IPV6 | IMAGE |
| a001 | RUNNING | 10.81.25.83 (eth0) | fd42:f9b3:165c:1ca3:216:3eff:fe68:f2b6 (eth0) | alpine |
| b001 | RUNNING | | fd42:f9b3:165c:1ca3:216:3eff:feff:4cb (eth0) | bionic |
| s001 | RUNNING | | fd42:f9b3:165c:1ca3:216:3eff:fe7c:df1b (eth0) | suseleap15 |
| x001 | RUNNING | | fd42:f9b3:165c:1ca3:216:3eff:fea0:7c94 (eth0) | xenial |
LXD configuration from lxd init is mostly defaults (thanks, LXD-3.3 for the init dump feature!):
$ sudo lxd init --dump
config: {}
networks:
- config:
ipv4.address: 10.81.25.1/24
ipv4.nat: "true"
ipv6.address: fd42:f9b3:165c:1ca3::1/64
managed: true
type: bridge
storage_pools:
- config:
source: lxd
volatile.initial_source: /dev/sda2
zfs.pool_name: lxd
driver: zfs
- config: {}
nictype: bridged
parent: lxdbr0
pool: lxd
The host laptop has the default network bridge configuration:
$ lxc network list
| NAME | TYPE | MANAGED | DESCRIPTION | USED BY |
| eth0 | physical | NO | | 0 |
| lxdbr0 | bridge | YES | | 4 |
| wlan0 | physical | NO | | 0 |
lxd init uses default network configuration:
$ lxc network show lxdbr0 --verbose
ipv4.nat: "true"
type: bridge
- /1.0/containers/a001
- /1.0/containers/b001
- /1.0/containers/s001
- /1.0/containers/x001
managed: true
status: Created
locations:
- none
The lxd-managed dnsmasq instance seems normally configured (via ps listing):
dnsmasq
--strict-order
--bind-interfaces
--pid-file=/var/lib/lxd/networks/lxdbr0/dnsmasq.pid
--except-interface=lo
--interface=lxdbr0
--quiet-dhcp
--quiet-dhcp6
--quiet-ra
--listen-address=10.81.25.1
--dhcp-no-override
--dhcp-authoritative
--dhcp-leasefile=/var/lib/lxd/networks/lxdbr0/dnsmasq.leases
--dhcp-hostsfile=/var/lib/lxd/networks/lxdbr0/dnsmasq.hosts
--dhcp-range 10.81.25.2,10.81.25.254,1h
--listen-address=fd42:f9b3:165c:1ca3::1
--enable-ra
--dhcp-range ::,constructor :lxdbr0,ra-stateless,ra-names
-s lxd
-S /lxd/
--conf-file=/var/lib/lxd/networks/lxdbr0/dnsmasq.raw
-u nobody
The ubuntu images are from remote ubuntu:, alpine and openSUSE are from remote images:, all are set to auto-update:
$ lxc image list
| ALIAS | FINGERPRINT | PUBLIC | DESCRIPTION | ARCH | SIZE | UPLOAD DATE |
| alpine | 1bb67d6f1b29 | no | Alpine 3.8 amd64 (20180727_13:00) | x86_64 | 2.34MB | Jul 27, 2018 at 3:08pm (UTC) |
| bionic | 38219778c2cf | no | ubuntu 18.04 LTS amd64 (release) (20180724) | x86_64 | 173.75MB | Jul 25, 2018 at 2:50pm (UTC) |
| suseleap15 | d7a2900a93b8 | no | Opensuse 15.0 amd64 (20180728_00:53) | x86_64 | 62.11MB | Jul 28, 2018 at 3:09am (UTC) |
| xenial | 2a7896bae0f2 | no | ubuntu 16.04 LTS amd64 (release) (20180724) | x86_64 | 157.79MB | Jul 25, 2018 at 2:51pm (UTC) |
If I execute a dhcp client command on ubuntu containers, they do get an ipv4 dhcp address:
$ lxc exec x001 -- dhclient eth0
$ lxc exec b001 -- dhclient eth0
$ lxc list
| a001 | RUNNING | 10.81.25.83 (eth0) | fd42:f9b3:165c:1ca3:216:3eff:fe68:f2b6 (eth0) | PERSISTENT | 0 |
| b001 | RUNNING | 10.81.25.87 (eth0) | fd42:f9b3:165c:1ca3:216:3eff:feff:4cb (eth0) | PERSISTENT | 0 |
| s001 | RUNNING | | fd42:f9b3:165c:1ca3:216:3eff:fe7c:df1b (eth0) | PERSISTENT | 0 |
| x001 | RUNNING | 10.81.25.33 (eth0) | fd42:f9b3:165c:1ca3:216:3eff:fea0:7c94 (eth0) | PERSISTENT | 0 |
Containers using the openSUSE image exhibit the same symptom, but the image doesn’t have dhclient. I’m not clear how it is getting an ipv6 dhcp address, for the same reasons as ubuntu images. Until I investigate that further on openSUSE, manually setting the ipv4 address works:
$ lxc exec s001 -- ip link set eth0 up
$ lxc exec s001 -- ip address add 10.81.25.128/24 dev eth0
$ lxc list
| s001 | RUNNING | 10.81.25.128 (eth0) | fd42:f9b3:165c:1ca3:216:3eff:fe7c:df1b (eth0) | PERSISTENT | 0 |
Thanks for any insights you might be able to provide. Feel free to ask for more information about this particular system configuration.
