LXD demo on AWS with Ubuntu fan networking
I have been experimenting with LXD clustering on AWS. The idea is to use AWS as a simple way to spin up demos and proof of concept environments.
A few days I ago I spun up a cluster like in the YouTube video about the Ubuntu fan.
https://youtu.be/5cwd0vZJ5bw
I was not able to get the containers to see each other.
So, I am thinking I will write some Terraform to create the VPC, subnets, security groups, instances, etc. If I can get the Ubuntu fan to work, I will write a tutorial about it and post here with the howto tag.
Before I start working on this, are there any details about running an LXD cluster on AWS I should know about? Has anyone seen a tutorial like this anywhere else?
Thanks for the help.
Have you checked that the intra-EC2 network is allowing VXLAN?
Saw a similar issue on Oracle cloud the other day, see:
Oh, cool. I bet that is it.
I will rebuild the cluster and check. If I remember correctly, I allowed all TCP traffic between nodes within the VPC. That sounds like the problem. I should have also allowed UDP.
When I get it rebuilt, I will let you know.
As it turns out, I was allowing all traffic.
This might be the issue.
Would you like to create a new Fan overlay network? (yes/no) [default=yes]:
What subnet should be used as the Fan underlay? [default=auto]:
Invalid input: The auto-detected underlay (172.31.0.0/20) isn't a /16 or /24, please specify manually
What subnet should be used as the Fan underlay? [default=auto]: 172.31.0.0/16
I just guessed when I put in 172.31.0.0/16 and then tested to see if it worked.
Now I have three containers on three different nodes.
u1 and u2 can communicate but u3 can’t communicate with u1 or with u2.
I bet it has to do with the CIDR ranges. I will try again later in the week. I am going to tear the cluster down again.
Any idea why I could not use 173.21.0.0/20? That is the CIDR for the subnet that all of the instances are in.
The fan network provides an overlay subnet, and it requires a /16 or /24 underlay to operate.
See FanNetworking - Ubuntu Wiki
This might help too.
Thanks for your help so far.
I promise I will write up a tutorial once I get this working. :smile:
Quick update.
I created a new VPC with a CIDR of 10.0.0.0/16 and single public subnet with the same CIDR. I then created a three node cluster with a fan network.
This time everything worked. For demos, this could work. It is not likely to work for a production setup since only one availability zone is being used and there are no private subnets.
I will try again some time soon with a more realistic VPC.
