LXD: Dhcp-hosts in dnsmasq doesn't work. What I am doing wrong?
I tried to set:
lxc network set lxdbr0 raw.dnsmasq=“dhcp-hostsfile=/var/lib/snapd/hostfs/etc/hosts.dnsmasq”
or
lxc network set lxdbr0 raw.dnsmasq=“dhcp-host=11:22:33:44:55:66,hostname,nn.nn.nn.nn”
The container using dhcp with the correct mac address never get the IP.
What I am missing here?
Instead of using dhcp-host I did different:
The container was configured to acquire the ip using “dhcp” and in the host I did the command:
lxc config device set rem-db eth0 ipv4.address 10.250.1.10
The static ip assignment was using lxc config device.
Doing that, the container get the address 10.250.1.10 using dhcp and the dnsmasq assign the name rem-db to that ip.
Is this the way it was designed to work?
