I am going to be running lxd to mess around on a really low storage laptop is directory backed the right choice If I want them both to share storage space for example if delete a container I gain back storage to install something else?
I use LXD on a Raspberry Pi3 with a 32 Go Sdcard and 1 Go Ram with a Btrfs storage and it works for me. Dir storage has limitations especially with snapshots, it’s to be avoided unless really necessary.
How much is your free space?
With dir
, you do not preallocate the space.
With anything else, you preallocate, and can have fancy features like copy-on-write, which really saves space.
