Hi! Since upgrading from Ubuntu 20.04 to 22.04, LXD does not start anymore:
lxd.daemon[16762]: => Starting LXD
lxd.daemon[16899]: time="2022-09-01T08:43:34+03:00" level=warning msg="Unsupported CGroup setup detected, V1 controllers on top of V2 root"
lxd.daemon[16899]: time="2022-09-01T08:43:34+03:00" level=warning msg=" - Couldn't find the CGroup network priority controller, network priority will be ignored"
lxd.daemon[16899]: time="2022-09-01T08:43:34+03:00" level=error msg="Failed to start the daemon" err="listen vsock: open /dev/vsock: no such file or directory"
lxd.daemon[16899]: Error: listen vsock: open /dev/vsock: no such file or directory
lxd.daemon[16762]: => LXD failed to start
Indeed, the /dev/vhost file is not there. I do have vhost-net and vhost-vsock, though. The vhost kernel module is loaded, and if I unload it (after unloading a couple of modules depending on it) and reload it, then /dev/vhost appears and LXD can start.
So this is most likely not an issue with LDX itself, but hopefully here in the forums there are some experts that can help me understand what’s happening? I’m a bit at a loss, since searching in the internet for similar issues didn’t lead to many results, so it looks like this is a rare case. FWIW, in the same machine I do also have VirtualBox installed.
I’m using 5.4/stable, but previously I was running 5.5/stable and it had the same issue. I’ll now try to disable the virtualbox.service and reboot, to see if anything changes.
EDIT: nope, no luck, the virtualbox service did not start, but still no /dev/vhost is present.
Oh, it looks like I had one intallation of vmware-player from a few years ago. After removing that, and rebooting, that module is gone (yet, there’s still a vmw_* module left; is that normal?):
I removed open-vm-tools (details in another post here and rebooted).
Of course that’s not ideal, but at least it works. It’d be good if LXD could coexist without problems. It seems if some modules can’t be loaded by open-vm-tools that can create other issues for the VM.
