Hi all,
I had a three node LXD cluster installed on KVM virtual machines
Host and guests all have Kubuntu 18.04 updated up today
I installed LXD using SNAP to have the 3.12 version (I had problems with the 3.0.3 that comes with Kubuntu 18.04 see thread)
The cluster starts and stops correctly ending in three nodes fuly operational
Then I installed JUJU on the first node (kvmnode1) with these commands:
sudo add-apt-repository -yu ppa:juju/stable
sudo apt update
sudo apt install juju
After a reboot I see that the node no more belongs to a cluster, the cluster database is empty and the LXD version is 3.0.3
sysop@kvmnode1:~$ sudo lxc cluster list
[sudo] password di sysop:
Error: LXD server isn’t part of a cluster
sysop@kvmnode1:~$ sudo systemctl status snap.lxd.daemon
● snap.lxd.daemon.service - Service for snap application lxd.daemon
Loaded: loaded (/etc/systemd/system/snap.lxd.daemon.service; static; vendor preset: enabled)
Active: active (running) since Wed 2019-05-01 19:01:41 CEST; 3min 6s ago
Main PID: 1794 (daemon.start)
Tasks: 0 (limit: 4915)
CGroup: /system.slice/snap.lxd.daemon.service
‣ 1794 /bin/sh /snap/lxd/10601/commands/daemon.start
mag 01 19:01:45 kvmnode1 lxd.daemon[1794]: 4: fd: 11: blkio
mag 01 19:01:45 kvmnode1 lxd.daemon[1794]: 5: fd: 12: hugetlb
mag 01 19:01:45 kvmnode1 lxd.daemon[1794]: 6: fd: 13: cpu,cpuacct
mag 01 19:01:45 kvmnode1 lxd.daemon[1794]: 7: fd: 14: perf_event
mag 01 19:01:45 kvmnode1 lxd.daemon[1794]: 8: fd: 15: pids
mag 01 19:01:45 kvmnode1 lxd.daemon[1794]: 9: fd: 16: rdma
mag 01 19:01:45 kvmnode1 lxd.daemon[1794]: 10: fd: 17: memory
mag 01 19:01:45 kvmnode1 lxd.daemon[1794]: 11: fd: 18: name=systemd
mag 01 19:01:45 kvmnode1 lxd.daemon[1794]: 12: fd: 19: unified
mag 01 19:01:45 kvmnode1 lxd.daemon[1794]: t=2019-05-01T19:01:45+0200 lvl=warn msg=“CGroup memory swap accounting is disabled, swap limits will be ignored.”
sysop@kvmnode1:~$ sudo -i
root@kvmnode1:~# echo “SELECT * FROM config” | sqlite3 /var/lib/lxd/database/local.db
root@kvmnode1:~# sudo lxd --version
3.0.3
root@kvmnode1:~#
Strangely on the other two nodes the first node seems active and the lxd version is 3.12
sysop@kvmnode2:~$ sudo lxc cluster list
[sudo] password for sysop:
| NAME | URL | DATABASE | STATE | MESSAGE |
| kvmnode1 | https://192.168.201.11:8443 | YES | ONLINE | fully operational |
| kvmnode2 | https://192.168.201.12:8443 | YES | ONLINE | fully operational |
| kvmnode3 | https://192.168.201.13:8443 | YES | ONLINE | fully operational |
sysop@kvmnode2:~$ sudo lxd --version
3.12
sysop@kvmnode2:~
How can I install JUJU without downgrading LXD?
