I have a container that I mount a tmpfs into to act as a cache directory:
cache:
path: /var/cache/application_name
source: /mnt/hot/lxd/cache/application_name
The tmpfs looks like:
$ stat /mnt/hot/lxd/cache/application_name
File: /mnt/hot/lxd/cache/application_name
Size: 40 Blocks: 0 IO Block: 4096 directory
Device: 0,39 Inode: 1 Links: 2
Access: (0755/drwxr-xr-x) Uid: ( 1001/lxdusers) Gid: (1000985/ UNKNOWN)
Access: 2022-07-24 20:09:57.170526652 -0700
Modify: 2022-07-24 19:54:07.383827363 -0700
Change: 2022-07-24 19:54:07.383827363 -0700
Birth: 2022-07-24 19:54:07.383827363 -0700
$ mount | grep application
applicationcache on /mnt/hot/lxd/cache/application_name type tmpfs (rw,nosuid,nodev,relatime,size=10485760k,nr_inodes=10000,mode=755,uid=1001,gid=1000985,inode64)
However when I start the container I get the following error in the logs:
lxc info --show-log application_name
Status: STOPPED
Type: container
Created: 2021/07/16 17:37 PDT
Last Used: 2022/07/24 20:08 PDT
Log:
lxc application_name 20220725030817.785 ERROR conf - ../src/lxc/conf.c:mount_entry:2459 - Operation not permitted - Failed to mount "/var/lib/lxd/devices/application_name/disk.cache--config.var-cache-application_name" on "/usr/lib/lxc/rootfs/var/cache/application_name"
lxc application_name 20220725030817.785 ERROR conf - ../src/lxc/conf.c:lxc_setup:4375 - Failed to setup mount entries
lxc application_name 20220725030817.785 ERROR start - ../src/lxc/start.c:do_start:1275 - Failed to setup container "application_name"
lxc application_name 20220725030817.785 ERROR sync - ../src/lxc/sync.c:sync_wait:34 - An error occurred in another process (expected sequence number 3)
lxc application_name 20220725030817.793 WARN network - ../src/lxc/network.c:lxc_delete_network_priv:3631 - Failed to rename interface with index 0 from "eth0" to its initial name "veth7c14d1f2"
lxc application_name 20220725030817.794 ERROR lxccontainer - ../src/lxc/lxccontainer.c:wait_on_daemonized_start:877 - Received container state "ABORTING" instead of "RUNNING"
lxc application_name 20220725030817.794 ERROR start - ../src/lxc/start.c:__lxc_start:2074 - Failed to spawn container "application_name"
lxc application_name 20220725030817.794 WARN start - ../src/lxc/start.c:lxc_abort:1039 - No such process - Failed to send SIGKILL via pidfd 17 for process 1663
lxc 20220725030822.944 ERROR af_unix - ../src/lxc/af_unix.c:lxc_abstract_unix_recv_fds_iov:218 - Connection reset by peer - Failed to receive response
lxc 20220725030822.944 ERROR commands - ../src/lxc/commands.c:lxc_cmd_rsp_recv_fds:127 - Failed to receive file descriptors for command "get_state"
The lxd daemon runs as root and the tmpfs permissions are setup to match the uid/gid of the processes in the container, so I don’t know why I’m getting permissions errors.
