Im trying to get into the GO API for LXD but I can’t get the example code execution to run.
Im on a VM with Ubuntu 20.04 and LXD version 4.22 installed with snap. Im testing with a ubuntu focal container Alias 20.04 from the image source Ubuntu Cloud Images
I’m able to do other API Commands so i know connection to the unix socket works.
// Connect to LXD over the Unix socket
c, err := lxd.ConnectLXDUnix("/var/snap/lxd/common/lxd/unix.socket", nil)
if err != nil {
return err
// Setup the exec request
req := api.ContainerExecPost{
Command: []string{"bash"},
WaitForWS: true,
Interactive: true,
Width: 80,
Height: 15,
// Setup the exec arguments (fds)
args := lxd.ContainerExecArgs{
Stdin: os.Stdin,
Stdout: os.Stdout,
Stderr: os.Stderr,
// Setup the terminal (set to raw mode)
if req.Interactive {
cfd := int(syscall.Stdin)
oldttystate, err := termios.MakeRaw(cfd)
if err != nil {
return err
defer termios.Restore(cfd, oldttystate)
// Get the current state
op, err := c.ExecContainer("c1", req, &args)
if err != nil {
return err
// Wait for it to complete
err = op.Wait()
if err != nil {
return err
The function runs to the point op, err := c.ExecContainer("c1", req, &args)
When it enters err = op.Wait() it takes a few seconds and i get the output “Timed out waiting for websockets to connect”
Good to know. I would suggest updating the example in the LXD GO documentation lxd package - github.com/lxc/lxd/client - pkg.go.dev it is misleading. So generally i should use the Instance Commands instead of the container commands?
Could you help me out once more?
I don’t know what connection to use in the InstanceExecArgs. In the github code you sent me the GetOperationWebsocket returns a connection that is used. But the Instance server that i get returned after using c, err := lxd.ConnectLXDUnix("/var/snap/lxd/common/lxd/unix.socket", nil) doesnt have the GetOperationWebsocket function. What Do i have to do to get the connection required by the InstanceExecArgs ?
Just wanted to let you know. It got it working. I keep getting the error “Timed out waiting for websockets to connect” on my Ubuntu 20.04 Desktop VM trying to run the ExecInstance code example. So i tried out a Ubuntu Server 20.04 VM. There the ExecInstance code example ran fine. If anybody should have the same weird issue as me: Try Ubuntu Server.
One more detail: on the Ubuntu Server VM where it worked lxd version got 4.0.7
On the Ubuntu 20.04 Desktop VM where it gets the error lxd version got 4.22
I will test out the older lxd version on my ubuntu Desktop VM aswell and give you an Update if it will run when using the older LXD Version.
Update: When using the snap install from sudo snap install lxd --channel=4.0/stable
it does work. So i suspect that there is an error in the lxd release newer than 4.0 stable.
I will open an issue in the github on this.
The more recent LXD versions introduced a timeout for waiting for the client to connect.
We expect the control socket, plus at least 1 websocket for interactive, and 3 (stdin, stdout and stderr) for non-interactive.
Could you provide me with a working code example for more recent LXD versions? (Sorry i just started using go for the lxd api. So i’m at loss how to alter the code example from the Go documentation to work with lxc 4.22.)
