I have been trying to benchmark LXD container and VM creation cycles and have come accross a few issues. The script looks something like this:
UBUNTU_VM_IMAGE='ubuntu:20.04'
UBUNTU_VM_NAME='ubuntu-vm-test'
NUM_VMS=5
TOTAL_CREATE_RUNTIME=0
TOTAL_SHUTDOWN_RUNTIME=0
TOTAL_BOOT_RUNTIME=0
TOTAL_REBOOT_RUNTIME=0
TOTAL_DELETE_RUNTIME=0
echo "Started VM creation"
i=0
while [ "$i" -lt "$NUM_VMS" ]; do
CREATE_START=`date +%s.%N`
lxc launch $UBUNTU_VM_IMAGE $UBUNTU_VM_NAME-$i --vm
CREATE_END=`date +%s.%N`
TOTAL_CREATE_RUNTIME=$( echo "$CREATE_END - $CREATE_START + $TOTAL_CREATE_RUNTIME" | bc -l )
i=$(($i + 1))
done
echo "Ended VM creation"
# This sleep makes it so that the first iteration of lxc stop on the following loop gets stuck
# sleep 20
echo "Started VM shutdown"
i=0
SHUTDOWN_START=`date +%s.%N`
lxc stop $UBUNTU_VM_NAME-$i --verbose
SHUTDOWN_END=`date +%s.%N`
TOTAL_SHUTDOWN_RUNTIME=$( echo "$SHUTDOWN_END - $SHUTDOWN_START + $TOTAL_SHUTDOWN_RUNTIME" | bc -l )
i=$(($i + 1))
done
echo $TOTAL_SHUTDOWN_RUNTIME
echo "Ended VM shutdown"
echo "Started VM boot"
i=0
BOOT_START=`date +%s.%N`
lxc start $UBUNTU_VM_NAME-$i
BOOT_END=`date +%s.%N`
TOTAL_BOOT_RUNTIME=$( echo "$BOOT_END - $BOOT_START + $TOTAL_BOOT_RUNTIME" | bc -l )
i=$(($i + 1))
done
echo "Ended VM boot"
echo "Started VM reboot"
i=0
REBOOT_START=`date +%s.%N`
lxc restart $UBUNTU_VM_NAME-$i
REBOOT_END=`date +%s.%N`
TOTAL_REBOOT_RUNTIME=$( echo "$REBOOT_END - $REBOOT_START + $TOTAL_REBOOT_RUNTIME" | bc -l )
i=$(($i + 1))
done
echo "Ended VM reboot"
i=0
i=$(($i + 1))
done
echo "Started VM deletion"
i=0
DELETE_START=`date +%s.%N`
lxc delete $UBUNTU_VM_NAME-$i
DELETE_END=`date +%s.%N`
TOTAL_DELETE_RUNTIME=$( echo "$DELETE_END - $DELETE_START + $TOTAL_DELETE_RUNTIME" | bc -l )
i=$(($i + 1))
done
echo "Ended VM deletion"
I noticed that when an LXD stop event was issued right after an lxc launch/start sometimes LXD would hang on a stop operation until I Ctrl+C out of it.
I have attempted to place an artificial wait time using sleep, however it seems that when sleep is placed before the stop loop, the first iteration always hangs on lxc stop for some reason until manually stopped, after which it executes the following loops with no issues.
Note that this issue only occurs on VM instances, I have the same script used for containers and the sleep prior to the stop loop does not affect its execution.
I am running LXD 4.8, though have also tested on a machine that’s tracking the latest/edge channel and the same problem occurs.
Any help is greatly appreciated.
