I’ve been trying to get LXD running on a fresh Oracle cloud machine running Ubuntu 22.04 as a way to learn LXD.
I have however been running into issues with my LXD instances not getting IPV4 addresses. It seems to be due to nftables not properly allowing ports 67 and 53. It seems like a conflict between the rules injected by oracle-cloud for the 169.254.0.0/16 range and the automatic LXD rules.
I note that the Oracle firewall rules are coming from /etc/iptables/rules.v4 via netfilter-persistent but I can’t tell where the LXD rules are coming from.
Although many others seem to have similar issues with firewalls (conflicts in UFW or with Docker) I am surprised I can’t find others online who’ve previously had the same problems as here.
Can someone on this forum point me in the right direction on how to resolve this?
Is the solution to remove the automatic firewalls from LXD and add them myself into the Oracle tables?
The MRE is very basic:
Spinning up my first LXD machine on a fresh install does not get an IPV4 address.
USER@ORACLE:~$ lxd init
Would you like to use LXD clustering? (yes/no) [default=no]:
Name of the storage backend to use (cephobject, dir, lvm, zfs, btrfs, ceph) [default=zfs]:
Create a new ZFS pool? (yes/no) [default=yes]:
Would you like to use an existing empty block device (e.g. a disk or partition)? (yes/no) [default=no]:
Size in GiB of the new loop device (1GiB minimum) [default=8GiB]:
Would you like to create a new local network bridge? (yes/no) [default=yes]:
What should the new bridge be called? [default=lxdbr0]:
Would you like the LXD server to be available over the network? (yes/no) [default=no]:
Would you like stale cached images to be updated automatically? (yes/no) [default=yes]:
Would you like a YAML "lxd init" preseed to be printed? (yes/no) [default=no]:
USER@ORACLE:~$ lxc launch ubuntu:22.04 first
Creating first
Starting first
USER@ORACLE:~$ lxc list
| first | RUNNING | | fd42:b915:76ff:9282:216:3eff:fe09:b203 (eth0) | CONTAINER | 0 |
The ip settings for the host are
USER@ORACLE:~$ ip a
inet6 ::1/128 scope host
2: enp0s6: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 9000 qdisc mq state UP group default qlen 1000
link/ether 02:00:17:00:cc:9f brd ff:ff:ff:ff:ff:ff
inet 10.0.0.230/24 metric 100 brd 10.0.0.255 scope global enp0s6
inet6 fe80::17ff:fe00:cc9f/64 scope link
3: lxdbr0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:f2:14:8b brd ff:ff:ff:ff:ff:ff
inet 10.117.179.1/24 scope global lxdbr0
inet6 fd42:b915:76ff:9282::1/64 scope global
inet6 fe80::216:3eff:fef2:148b/64 scope link
5: veth3a9d62a8@if4: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
link/ether d2:9f:b7:f5:2c:c8 brd ff:ff:ff:ff:ff:ff link-netnsid 0
USER@ORACLE:~$ ip r
default via 10.0.0.1 dev enp0s6
default via 10.0.0.1 dev enp0s6 proto dhcp src 10.0.0.230 metric 100
10.0.0.0/24 dev enp0s6 proto kernel scope link src 10.0.0.230 metric 100
10.0.0.1 dev enp0s6 proto dhcp scope link src 10.0.0.230 metric 100
10.117.179.0/24 dev lxdbr0 proto kernel scope link src 10.117.179.1
169.254.0.0/16 dev enp0s6 scope link
169.254.0.0/16 dev enp0s6 proto dhcp scope link src 10.0.0.230 metric 100
169.254.169.254 via 10.0.0.1 dev enp0s6 proto dhcp src 10.0.0.230 metric 100
And the LXD config
USER@ORACLE:~$ lxc config show first --expanded
architecture: aarch64
image.architecture: arm64
image.description: ubuntu 22.04 LTS arm64 (release) (20240223)
image.label: release
image.os: ubuntu
image.release: jammy
image.serial: "20240223"
image.type: squashfs
image.version: "22.04"
volatile.base_image: f7bdd63df04bbe88411ee9e114ead65bd19ab30d03797ba05c03dc5bb132f87b
volatile.cloud-init.instance-id: 8cc37382-de54-4071-b42e-6c3b481c6376
volatile.eth0.host_name: veth3a9d62a8
volatile.eth0.hwaddr: 00:16:3e:09:b2:03
volatile.idmap.base: "0"
volatile.uuid: d20ddb8b-caf9-40db-b523-5a27b2b65aef
volatile.uuid.generation: d20ddb8b-caf9-40db-b523-5a27b2b65aef
network: lxdbr0
pool: default
USER@ORACLE:~$ lxc network show lxdbr0
ipv4.address: 10.117.179.1/24
ipv4.nat: "true"
ipv6.address: fd42:b915:76ff:9282::1/64
ipv6.nat: "true"
type: bridge
- /1.0/instances/first
- /1.0/profiles/default
managed: true
status: Created
locations:
- none
and finally the firewall settings
USER@ORACLE:~$ lxc info | grep firewall
- network_firewall_filtering
- firewall_driver
firewall: nftables
USER@ORACLE:~$ sudo nft list ruleset
table ip filter {
chain INPUT {
type filter hook input priority filter; policy accept;
ct state related,established counter packets 18032 bytes 400067863 accept
meta l4proto icmp counter packets 0 bytes 0 accept
iifname "lo" counter packets 38 bytes 3290 accept
meta l4proto udp udp sport 123 counter packets 0 bytes 0 accept
meta l4proto tcp ct state new tcp dport 22 counter packets 2 bytes 104 accept
counter packets 11 bytes 3272 reject with icmp type host-prohibited
chain FORWARD {
type filter hook forward priority filter; policy accept;
counter packets 0 bytes 0 reject with icmp type host-prohibited
chain OUTPUT {
type filter hook output priority filter; policy accept;
ip daddr 169.254.0.0/16 counter packets 235 bytes 18899 jump InstanceServices
chain InstanceServices {
meta l4proto tcp ip daddr 169.254.0.2 skuid 0 tcp dport 3260 counter packets 0 bytes 0 accept
meta l4proto tcp ip daddr 169.254.2.0/24 skuid 0 tcp dport 3260 counter packets 0 bytes 0 accept
meta l4proto tcp ip daddr 169.254.4.0/24 skuid 0 tcp dport 3260 counter packets 0 bytes 0 accept
meta l4proto tcp ip daddr 169.254.5.0/24 skuid 0 tcp dport 3260 counter packets 0 bytes 0 accept
meta l4proto tcp ip daddr 169.254.0.2 tcp dport 80 counter packets 0 bytes 0 accept
meta l4proto udp ip daddr 169.254.169.254 udp dport 53 counter packets 21 bytes 1973 accept
meta l4proto tcp ip daddr 169.254.169.254 tcp dport 53 counter packets 0 bytes 0 accept
meta l4proto tcp ip daddr 169.254.0.3 skuid 0 tcp dport 80 counter packets 0 bytes 0 accept
meta l4proto tcp ip daddr 169.254.0.4 tcp dport 80 counter packets 0 bytes 0 accept
meta l4proto tcp ip daddr 169.254.169.254 tcp dport 80 counter packets 211 bytes 16698 accept
meta l4proto udp ip daddr 169.254.169.254 udp dport 67 counter packets 0 bytes 0 accept
meta l4proto udp ip daddr 169.254.169.254 udp dport 69 counter packets 0 bytes 0 accept
meta l4proto udp ip daddr 169.254.169.254 udp dport 123 counter packets 3 bytes 228 accept
meta l4proto tcp ip daddr 169.254.0.0/16 counter packets 0 bytes 0 reject with tcp reset
meta l4proto udp ip daddr 169.254.0.0/16 counter packets 0 bytes 0 reject
table ip6 filter {
chain INPUT {
chain FORWARD {
chain OUTPUT {
table inet lxd {
chain pstrt.lxdbr0 {
type nat hook postrouting priority srcnat; policy accept;
ip saddr 10.117.179.0/24 ip daddr != 10.117.179.0/24 masquerade
ip6 saddr fd42:b915:76ff:9282::/64 ip6 daddr != fd42:b915:76ff:9282::/64 masquerade
chain fwd.lxdbr0 {
ip version 4 oifname "lxdbr0" accept
ip version 4 iifname "lxdbr0" accept
ip6 version 6 oifname "lxdbr0" accept
ip6 version 6 iifname "lxdbr0" accept
chain in.lxdbr0 {
iifname "lxdbr0" tcp dport 53 accept
iifname "lxdbr0" udp dport 53 accept
iifname "lxdbr0" icmp type { destination-unreachable, time-exceeded, parameter-problem } accept
iifname "lxdbr0" udp dport 67 accept
iifname "lxdbr0" icmpv6 type { destination-unreachable, packet-too-big, time-exceeded, parameter-problem, nd-router-solicit, nd-neighbor-solicit, nd-neighbor-advert, mld2-listener-report } accept
iifname "lxdbr0" udp dport 547 accept
chain out.lxdbr0 {
oifname "lxdbr0" tcp sport 53 accept
oifname "lxdbr0" udp sport 53 accept
oifname "lxdbr0" icmp type { destination-unreachable, time-exceeded, parameter-problem } accept
oifname "lxdbr0" udp sport 67 accept
oifname "lxdbr0" icmpv6 type { destination-unreachable, packet-too-big, time-exceeded, parameter-problem, echo-request, nd-router-advert, nd-neighbor-solicit, nd-neighbor-advert, mld2-listener-report } accept
oifname "lxdbr0" udp sport 547 accept
Finally, my understanding is that nftables is doing the firewalling on my machine:
USER@ORACLE:~$ sudo systemctl status netfilter-persistent.service iptables.service ip6tables.service nftables.service ufw.service
● netfilter-persistent.service - netfilter persistent configuration
Loaded: loaded (/lib/systemd/system/netfilter-persistent.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/netfilter-persistent.service.d
└─iptables.conf
Active: active (exited) since Sun 2024-02-25 13:58:32 UTC; 22min ago
Docs: man:netfilter-persistent(8)
Process: 688 ExecStart=/usr/sbin/netfilter-persistent start (code=exited, status=0/SUCCESS)
Main PID: 688 (code=exited, status=0/SUCCESS)
CPU: 18ms
Feb 25 13:58:32 take-for systemd[1]: Starting netfilter persistent configuration...
Feb 25 13:58:33 take-for netfilter-persistent[694]: run-parts: executing /usr/share/netfilter-persistent/plugins.d/15-ip4tables start
Feb 25 13:58:32 take-for netfilter-persistent[694]: run-parts: executing /usr/share/netfilter-persistent/plugins.d/25-ip6tables start
Feb 25 13:58:32 take-for systemd[1]: Finished netfilter persistent configuration.
○ iptables.service - netfilter persistent configuration
Loaded: loaded (/lib/systemd/system/iptables.service; alias)
Active: inactive (dead)
○ ip6tables.service - netfilter persistent configuration
Loaded: loaded (/lib/systemd/system/ip6tables.service; alias)
○ nftables.service - nftables
Loaded: loaded (/lib/systemd/system/nftables.service; disabled; vendor preset: enabled)
Docs: man:nft(8)
http://wiki.nftables.org
● ufw.service - Uncomplicated firewall
Loaded: loaded (/lib/systemd/system/ufw.service; enabled; vendor preset: enabled)
Docs: man:ufw(8)
Process: 695 ExecStart=/lib/ufw/ufw-init start quiet (code=exited, status=0/SUCCESS)
Main PID: 695 (code=exited, status=0/SUCCESS)
CPU: 1ms
Feb 25 13:58:32 take-for systemd[1]: Starting Uncomplicated firewall...
Feb 25 13:58:32 take-for systemd[1]: Finished Uncomplicated firewall.
USER@ORACLE:~$ sudo ufw status
Status: inactive
