I’m having some issues with the workflow that I’m attempting with a LXD VM on s390x architecture. At a high level, I’m attempting to Livepatch a test kernel. This requires me to build a kernel on the LXD VM, install it on the LXD VM, then attempt to build a Livepatch with kpatch-build using a copy of the kernel source code. This boils down to running the following commands on the linked LXD VM instance export:
Looks like you created the export without syncing or shutting down the VM:
lxc start jammy-ibm-gt --console
Begin: Will now check root file system ... fsck from util-linux 2.37.2
[/usr/sbin/fsck.ext4 (1) -- /dev/sda1] fsck.ext4 -a -C0 /dev/sda1
cloudimg-rootfs: Superblock needs_recovery flag is clear, but journal has data.
cloudimg-rootfs: Run journal anyway
cloudimg-rootfs: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY.
(i.e., without -a or -p options)
fsck exited with status code 4
done.
Failure: File system check of the root filesystem failed
The root filesystem on /dev/sda1 requires a manual fsck
It looks like I was likely bumping up into the installed memory limit on the host machine with the LXD instance. I re-imported the LXD image on another machine with more memory, and things are working much better.
