I’m guessing I am just missing something here but my LXD log file is not growing. Through a few different posts I reasoned that the log file belongs here /var/log/lxd/lxd.log but I did not have the path generated for me. After creating the path I was able to get the following 4 lines
e[31mERORe[0m[07-27|17:36:06] Failed to start the daemon: LXD is already running
e[32mINFOe[0m[07-27|17:36:06] Starting shutdown sequence
e[32mINFOe[0m[07-27|17:36:06] Saving simplestreams cache
e[32mINFOe[0m[07-27|17:36:06] Saved simplestreams cache
But since then nothing.
I found a post on here that highlighted a way to enable debug in the SNAP version
snap set lxd daemon.debug=true
systemctl reload snap.lxd.daemon
I deleted the log folder from above since I had manually created it thinking that the above two commands would bring it back, but they didn’t so now I am back to having no log.
Any help would be appreciated.
Thanks,
Chris
