Hey all!
I’m setting up an LXD cluster on a fresh install of Ubuntu 20.04 I run LXD init and after some time of playing with the REST APi creating instances etc… the lxd instance just loses the storage pool IE when i call /1.0/cluster
I see
"metadata": {
"server_name": "lxd-experiment",
"enabled": true,
"member_config": [
"entity": "storage-pool",
"name": "local",
"key": "source",
"value": "",
"description": "\"source\" property for storage pool \"local\""
"name": "local",
"key": "zfs.pool_name",
"value": "",
"description": "\"zfs.pool_name\" property for storage pool \"local\""
"name": "local",
"key": "size",
"value": "",
"description": "\"size\" property for storage pool \"local\""
However after a while of playing the member_config returns: [] and i can’t see any containers i created.
"type": "sync",
"status": "Success",
"status_code": 200,
"operation": "",
"error_code": 0,
"error": "",
"metadata": {
"server_name": "",
"enabled": false,
"member_config": []
