LXD losts iptables rules with docker
I installed LXD into my Ubuntu 20.04 by
sudo snap install lxd
sudo lxd init # create bridge lxdbr0
and launched Ubuntu 20.04 container by
sudo lxc launch ubuntu:20.04 focal
sudo lxc exec focal ping <outside ip>
But it failed to ping.
I find that iptables rules are not initiailized.
iptables-save | grep lxdbr0 # No lxdbr0 related rules are found
lxc info | grep -i firewall:
  firewall: nftables
sudo nft list ruleset
table ip nat {
	chain DOCKER {
		iifname "docker0" counter packets 0 bytes 0 return
		iifname "br-c21941e8d811" counter packets 0 bytes 0 return
	chain POSTROUTING {
		type nat hook postrouting priority srcnat; policy accept;
		oifname != "docker0" ip saddr 172.17.0.0/16 counter packets 0 bytes 0 masquerade
		oifname != "br-c21941e8d811" ip saddr 172.19.0.0/16 counter packets 6 bytes 360 masquerade
	chain PREROUTING {
		type nat hook prerouting priority dstnat; policy accept;
		fib daddr type local counter packets 16 bytes 804 jump DOCKER
	chain OUTPUT {
		type nat hook output priority -100; policy accept;
		ip daddr != 127.0.0.0/8 fib daddr type local counter packets 0 bytes 0 jump DOCKER
table ip filter {
	chain DOCKER {
	chain DOCKER-ISOLATION-STAGE-1 {
		iifname "docker0" oifname != "docker0" counter packets 0 bytes 0 jump DOCKER-ISOLATION-STAGE-2
		iifname "br-c21941e8d811" oifname != "br-c21941e8d811" counter packets 929 bytes 472940 jump DOCKER-ISOLATION-STAGE-2
		counter packets 1416 bytes 593650 return
	chain DOCKER-ISOLATION-STAGE-2 {
		oifname "docker0" counter packets 0 bytes 0 drop
		oifname "br-c21941e8d811" counter packets 0 bytes 0 drop
		counter packets 929 bytes 472940 return
	chain FORWARD {
		type filter hook forward priority filter; policy drop;
		counter packets 1416 bytes 593650 jump DOCKER-USER
		counter packets 1416 bytes 593650 jump DOCKER-ISOLATION-STAGE-1
		oifname "docker0" ct state related,established counter packets 0 bytes 0 accept
		oifname "docker0" counter packets 0 bytes 0 jump DOCKER
		iifname "docker0" oifname != "docker0" counter packets 0 bytes 0 accept
		iifname "docker0" oifname "docker0" counter packets 0 bytes 0 accept
		oifname "br-c21941e8d811" ct state related,established counter packets 487 bytes 120710 accept
		oifname "br-c21941e8d811" counter packets 0 bytes 0 jump DOCKER
		iifname "br-c21941e8d811" oifname != "br-c21941e8d811" counter packets 929 bytes 472940 accept
		iifname "br-c21941e8d811" oifname "br-c21941e8d811" counter packets 0 bytes 0 accept
	chain DOCKER-USER {
table inet lxd {
	chain pstrt.lxdbr0 {
		ip saddr 10.69.246.0/24 ip daddr != 10.69.246.0/24 masquerade
		ip6 saddr fd42:8469:f67b:3303::/64 ip6 daddr != fd42:8469:f67b:3303::/64 masquerade
	chain fwd.lxdbr0 {
		type filter hook forward priority filter; policy accept;
		ip version 4 oifname "lxdbr0" accept
		ip version 4 iifname "lxdbr0" accept
		ip6 version 6 oifname "lxdbr0" accept
		ip6 version 6 iifname "lxdbr0" accept
	chain in.lxdbr0 {
		type filter hook input priority filter; policy accept;
		iifname "lxdbr0" tcp dport 53 accept
		iifname "lxdbr0" udp dport 53 accept
		iifname "lxdbr0" icmp type { destination-unreachable, time-exceeded, parameter-problem } accept
		iifname "lxdbr0" udp dport 67 accept
		iifname "lxdbr0" icmpv6 type { destination-unreachable, packet-too-big, time-exceeded, parameter-problem, nd-router-solicit, nd-neighbor-solicit, nd-neighbor-advert, mld2-listener-report } accept
		iifname "lxdbr0" udp dport 547 accept
	chain out.lxdbr0 {
		type filter hook output priority filter; policy accept;
		oifname "lxdbr0" tcp sport 53 accept
		oifname "lxdbr0" udp sport 53 accept
		oifname "lxdbr0" icmp type { destination-unreachable, time-exceeded, parameter-problem } accept
		oifname "lxdbr0" udp sport 67 accept
		oifname "lxdbr0" icmpv6 type { destination-unreachable, packet-too-big, time-exceeded, parameter-problem, echo-request, nd-router-advert, nd-neighbor-solicit, nd-neighbor-advert, mld2-listener-report } accept
		oifname "lxdbr0" udp sport 547 accept
How to solve it ?
Regards,
Like
Please show output of sudo iptables-save
iptables-save
# Generated by iptables-save v1.8.7 on Tue Sep  6 16:32:34 2022
*filter
:INPUT ACCEPT [0:0]
:FORWARD DROP [0:0]
:OUTPUT ACCEPT [0:0]
:DOCKER - [0:0]
:DOCKER-ISOLATION-STAGE-1 - [0:0]
:DOCKER-ISOLATION-STAGE-2 - [0:0]
:DOCKER-USER - [0:0]
-A FORWARD -j DOCKER-USER
-A FORWARD -j DOCKER-ISOLATION-STAGE-1
-A FORWARD -o docker0 -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
-A FORWARD -o docker0 -j DOCKER
-A FORWARD -i docker0 ! -o docker0 -j ACCEPT
-A FORWARD -i docker0 -o docker0 -j ACCEPT
-A FORWARD -o br-c21941e8d811 -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
-A FORWARD -o br-c21941e8d811 -j DOCKER
-A FORWARD -i br-c21941e8d811 ! -o br-c21941e8d811 -j ACCEPT
-A FORWARD -i br-c21941e8d811 -o br-c21941e8d811 -j ACCEPT
-A DOCKER-ISOLATION-STAGE-1 -i docker0 ! -o docker0 -j DOCKER-ISOLATION-STAGE-2
-A DOCKER-ISOLATION-STAGE-1 -i br-c21941e8d811 ! -o br-c21941e8d811 -j DOCKER-ISOLATION-STAGE-2
-A DOCKER-ISOLATION-STAGE-1 -j RETURN
-A DOCKER-ISOLATION-STAGE-2 -o docker0 -j DROP
-A DOCKER-ISOLATION-STAGE-2 -o br-c21941e8d811 -j DROP
-A DOCKER-ISOLATION-STAGE-2 -j RETURN
-A DOCKER-USER -j RETURN
COMMIT
# Completed on Tue Sep  6 16:32:34 2022
*nat
:PREROUTING ACCEPT [0:0]
:INPUT ACCEPT [0:0]
:POSTROUTING ACCEPT [0:0]
:DOCKER - [0:0]
-A PREROUTING -m addrtype --dst-type LOCAL -j DOCKER
-A OUTPUT ! -d 127.0.0.0/8 -m addrtype --dst-type LOCAL -j DOCKER
-A POSTROUTING -s 172.17.0.0/16 ! -o docker0 -j MASQUERADE
-A POSTROUTING -s 172.19.0.0/16 ! -o br-c21941e8d811 -j MASQUERADE
-A DOCKER -i docker0 -j RETURN
-A DOCKER -i br-c21941e8d811 -j RETURN
COMMIT
So looks like you’ve got docker on the host and it has modified the firewall to drop forwarded traffic by default.
See Linux Containers - LXD - Has been moved to Canonical
According to Prevent issues with LXD and Docker
sudo iptables -I DOCKER-USER -i lxdbr0 -o eno3 -j ACCEPT
  • lxdbr0 : LXD bridge network
  • eno3 : host external network
But the container still can not access external network.
According to Fresh install of Ubuntu 22.04, LXD via snap, containers cannot reach the internet - #6 by tomp
sudo iptables -I DOCKER-USER -i lxdbr0 -j ACCEPT
sudo iptables -I DOCKER-USER -o lxdbr0 -j ACCEPT
The connectivity issue is solved.
