Need suggetion foR a smart GUI. Where I can manage Standalone OR cluster LXD. Thanks in advance.
Ill promote my own LXDMosaic
It can manage standalone & clusters among other things (user restrictions, VM GUI access, backups & metrics)
There are others but im not sure how they compare!
I have installed mosaic in a container. But when I am going add lxd server in mosaic it show this message
Can’t connect to x.x.x.x is lxd running and the port open? /var/www/LxdMosaic/src/classes/Tools/Hosts/AddHosts.php 93
N.B: I have run those command in my lxd server
lxc config set core.https_address [::]
lxc config set core.trust_password Open1234
are you using a macvlan network?
yes
On macvlan’s containers cant access the host so that configuration wont work!
Instead you could also install with snap on your host along side LXD
If I create a container without macvlan then I can access LXD server? If i can then can operate macvlans container also?
Yep that will work
But containers dynamic IP I cant access from network. What can I do?
Suppose my pc IP : 192.168.1.2
LXD IP: 192.168.1.3
But mosaic container’s shows this IP : https://10.84.149.243
Now how can I access mosaic web from my PC?
You could use a proxy device to map the ports needed to access LXDMosaic
On the host with the LXDMosaic container (replace LXDMOSAIC_CONTAINER with your container name)
lxc config device add LXDMOSAIC_CONTAINER lxdMosaicHttps proxy listen=tcp:0.0.0.0:443 connect=tcp:127.0.0.1:443
Then in your browser you could go https://192.168.1.3
(im fairly certain that’s all the ports you need, I haven’t tested this setup)
This is an issue when running backups manually, it has been fixed (here) but is yet to be released.
You can schedule a backup to work around the issue or will have to wait for next version (this week or next)
I can take backup by script in a remote mount point .But those backup does not show in Mosaic. Ok wait for release. Thnx
LXDMosaic wont be able to manage backups created by a script, instead it can do the scheduling of the backups for you!
Then where the location to schedule backup store? /root ?
You can change the backup location here: Settings -> LXDMosaic Settings -> Backup Directory
If you are using snap you can’t change the backup location!
I have install lxd on ubuntu 20.04 . I think it is by default snap lxd and I can change Backup directory. How?
Sorry, it doesnt matter which LXD version is matters which LXDMosaic version you use!
Container move work as copy command in ur GUI. But when I am move by command from terminal container full move
Does it show an error?
To avoid cluttering the forums, can you start opening questions / issues on Github?
