I’ve got a box I setup about 8 months ago, and starting to realize I never documented the full end-to-end steps to recreate (not good if I have an issue with the box)
sources :
I was trying at first to start with just a cleaner setup than my first post… but getting stuck. Once I setup the basic bridge.. and modify the yaml file my VM running kubuntu 20.04 loses all internet connectivity.. Should I have run the lxd init and THEN added a bridge for my containers?
Hi. Networking is not my thing, but I am wondering why you have no ip address (with dhcp set to ‘no’) and no gateway listed - it’s no wonder you can’t find the internet if there’s no gateway? I have these entries in my network file (but I use networkd not NetworkManager):
in my original attempt (which is still up and running) I never entered a gateway.. but you’ve rightly pointed out an error.. I’ve updated that file now to the following
vim /etc/netplan/01-network-manager-all.yaml
# Let NetworkManager manage all devices on this system
network:
version: 2
renderer: NetworkManager
ethernets:
enp0s2:
dhcp4: no
bridges:
br0:
dhcp4: yes
interfaces:
- enp0s2
The second line restores the internet to my host .. not sure why exactly but .. now trying to modify my default LXC profile to use that bridge instead..
Hopefully I am almost there..! thanks for checking in
Hmmm unfortunately I’ve seemed to have created a bridge which still just grabs a private NAT address under 10.0.1.19/24 CIDR
not my expected 192.168.0.0…
but at least I can reach from the host of the LXD machine now .. and the internet works.. but might need to redo the configuration to get full DHCP working
beeng googling and fiddling… does it help to say I am hosting this linux host within a QEMU VM?? I’ve tried moving things around in the 01-network-manager-all.yaml
it seems I never can get a IP from my router … could my host OS (mac mini) be blocking something here?
Soyou likely need more help than I can give. Acouple of points: LXD will create abridge that uses a virtual lan it controls. There are several ways you can make yourcontainers accessible via your router and/or visible on your lan. A simple one is usign macvlan on lxd. It’s easy (google it), but it has a snag: containers will not be able to talk to the host via this method (it’s a feature I think - but sometimes an inconveneient one). Another way is to create your own bridge and assign that to containers as you need. Here’s mine, conveniently or confusingly called br0:
lxc profile show br0
config: {}
description: “”
nictype: bridged
parent: br0
pool: default
That’s what I do. So I keep the default br0 bridge as some of my containers do not need lan access (so I keep them isolated by using the lxd bro), but those that do need easy access via the lan, I just assign my new br0 bridge to it using a single comnand:
lxc profile assign container-name br0
restart the container, and it will grab an ip from dhcp - my lan. And in this case, it can be accessed from the lan or even the host (unlike the macvlan method).
Keep going and good luck - you will get there. Lots of postings on here which google will find for you with some patience.
Andrew
I’ve infact created a bridge yes… and it seems to be okay some of the time, all except for the fact it’s not getting IPs from the router… and according to a link there’s a snag with macvlan when you’re hosted inside of a VM (which my linux LXD host is)
but I will try again… maybe I just need to get qemu/kvm host to allow promiscious mode and I will be through… thanks @Andrew_Wilson
I think I will try in the next few weeks to reinstall my base OS from scratch… and on bare metal re-attempt the macvlan bridge when outside of a VM… if it works I will be happy… if not well I at least can confirm that the issue is not my being in a vm …
I can confirm in fact the bare metal box I installed LXD on… never got IP’s from the DHCP router either… I was mistaken in my original assumption…
