slapcat
September 1, 2022, 9:13pm
1
I am following the tutorial here , but get stuck at the step where I create the my-ovn network. I installed and configured OVN from scratch from this tutorial. I get the following error:
lxc network create my-ovn --type=ovn network=UPLINK
Error: Failed to run: ovn-nbctl --timeout=10 --db tcp:192.168.0.181:6641,tcp:192.168.0.191:6641,tcp:192.168.0.235:6641 --wait=sb ha-chassis-group-add lxd-net16: exit status 1 (2022-09-01T21:01:41Z|00003|ovsdb_idl|WARN|transaction error: {"details":"Transaction causes multiple rows in \"HA_Chassis_Group\" table to have identical values (lxd-net16) for index on column \"name\". First row, with UUID 71c74eb8-c217-4786-bb3e-55d02578d57f, existed in the database before this transaction and was not modified by the transaction. Second row, with UUID c9d989e9-c603-4b2d-8662-18803b819d45, was inserted by this transaction.","error":"constraint violation"}
ovn-nbctl: transaction error: {"details":"Transaction causes multiple rows in \"HA_Chassis_Group\" table to have identical values (lxd-net16) for index on column \"name\". First row, with UUID 71c74eb8-c217-4786-bb3e-55d02578d57f, existed in the database before this transaction and was not modified by the transaction. Second row, with UUID c9d989e9-c603-4b2d-8662-18803b819d45, was inserted by this transaction.","error":"constraint violation"})
Here are the relevant configs:
lxc network show UPLINK
dns.nameservers: 8.8.8.8
ipv4.gateway: 10.0.1.1/24
ipv4.ovn.ranges: 10.0.1.2-10.0.1.254
volatile.last_state.created: "false"
type: physical
used_by: []
managed: true
status: Created
locations:
- daphne
- yogi
- gazoo
The bridged network is configured on each node as br0 with the following netplan config:
network:
ethernets:
eno1:
dhcp4: true
version: 2
bridges:
br0:
addresses: [ 10.0.1.0/24 ]
interfaces: [ vlan0 ]
vlans:
vlan0:
link: eno1
I’m definitely an OVN n00b, so I probably made a mistake somewhere. Why is this going wrong?
tomp
(Thomas Parrott)
September 2, 2022, 10:27am
3
Please can you show me the output of:
ovn-nbctl --timeout=10 --db tcp:192.168.0.181:6641,tcp:192.168.0.191:6641,tcp:192.168.0.235:6641 --wait=sb list HA_Chassis_Group
And
slapcat
September 2, 2022, 11:19am
4
Of course. The first command returns:
_uuid : 098bd5e0-eaf6-4da9-bc6b-ad155212ce7d
external_ids : {}
ha_chassis : []
_uuid : 71c74eb8-c217-4786-bb3e-55d02578d57f
external_ids : {}
ha_chassis : []
_uuid : 65d08b90-82ff-46d3-b8c0-0cceaff8f4f4
external_ids : {}
ha_chassis : []
The second command has no output.
tomp
(Thomas Parrott)
September 2, 2022, 1:36pm
5
Please can you show lxc network list and lxc cluster list please.
Have you created other OVN networks already?
slapcat
September 2, 2022, 3:36pm
6
No, I haven’t used OVN at all other than what was asked to be done in the tutorial. Here is the requested output:
$ lxc network ls
| NAME | TYPE | MANAGED | IPV4 | IPV6 | DESCRIPTION | USED BY | STATE |
| UPLINK | physical | YES | | | | 0 | CREATED |
| br0 | bridge | NO | | | | 1 | |
| br-int | bridge | NO | | | | 0 | |
| eno1 | physical | NO | | | | 1 | |
| eno2 | physical | NO | | | | 0 | |
| eno3 | physical | NO | | | | 0 | |
| eno4 | physical | NO | | | | 0 | |
| lan | macvlan | YES | | | | 1 | CREATED |
| lxdbr0 | bridge | YES | 10.79.71.1/24 | fd42:8858:7a68:87a4::1/64 | | 11 | CREATED |
| ovnnet | ovn | YES | 10.44.0.1/24 | fd42:d36c:7b12:66ca::1/64 | | 0 | ERRORED |
| virbr0 | bridge | NO | | | | 0 | |
| vlan0 | vlan | NO | | | | 0 | |
$ lxc cluster list
| NAME | URL | ROLES | ARCHITECTURE | FAILURE DOMAIN | DESCRIPTION | STATE | MESSAGE |
| daphne | https://192.168.0.181:8443 | database | x86_64 | default | | ONLINE | Fully operational |
| gazoo | https://192.168.0.237:8443 | database | x86_64 | default | | ONLINE | Fully operational |
| yogi | https://192.168.0.191:8443 | database-leader | x86_64 | default | | ONLINE | Fully operational |
| | | database | | | | | |
Note: I used “ovnnet” instead of “my-ovn” for the network name, but used the same commands from the tutorial.
tomp
(Thomas Parrott)
September 2, 2022, 3:45pm
7
OK thanks, looks like you may have some left over/stale config in OVN, please can you show me the output of:
ovn-nbctl --timeout=10 --db tcp:192.168.0.181:6641,tcp:192.168.0.191:6641,tcp:192.168.0.235:6641 --wait=sb show
tomp
(Thomas Parrott)
September 2, 2022, 3:46pm
8
Can you try removing the ERRORED ovnnet network using:
lxc network remove ovnnet
And then show the output of:
And
slapcat
September 2, 2022, 3:49pm
9
I removed the network. The second command had no output, the last command’s output is below.
$ ovn-nbctl --timeout=10 --db tcp:192.168.0.181:6641,tcp:192.168.0.191:6641,tcp:192.168.0.235:6641 --wait=sb list HA_Chassis_Group
external_ids : {}
ha_chassis : []
external_ids : {}
ha_chassis : []
external_ids : {}
ha_chassis : []
tomp
(Thomas Parrott)
September 2, 2022, 4:01pm
10
Can you try removing them using:
ovn-nbctl --timeout=10 --db tcp:192.168.0.181:6641,tcp:192.168.0.191:6641,tcp:192.168.0.235:6641 --wait=sb destroy HA_Chassis_Group lxd-net14
ovn-nbctl --timeout=10 --db tcp:192.168.0.181:6641,tcp:192.168.0.191:6641,tcp:192.168.0.235:6641 --wait=sb destroy HA_Chassis_Group lxd-net15
ovn-nbctl --timeout=10 --db tcp:192.168.0.181:6641,tcp:192.168.0.191:6641,tcp:192.168.0.235:6641 --wait=sb destroy HA_Chassis_Group lxd-net16
And then re-run:
To confirm they are gone, and then try adding the network again, this time recording the exact commands being run on each cluster member.
slapcat
September 2, 2022, 4:38pm
11
Okay, I’m an idiot. Thank you so much for your patience Tom!
I created the OVN network entirely referencing a non-existent node: 192.168.0.235. That was an old IP it had, but it is now at .237. I updated all the OVN configs, recreated the UPLINK network, and now the LXD OVN network was created without issue.
I can ping containers on other nodes with private IP and DNS, but I noticed the IP range is different than what I set (i.e. 10.0.1.0/24):
| c1 | RUNNING | 10.154.243.2 (eth0) | fd42:4e6a:c846:1bb1:216:3eff:fee5:d61f (eth0) | CONTAINER | 0 | yogi |
| c2 | RUNNING | 10.154.243.3 (eth0) | fd42:4e6a:c846:1bb1:216:3eff:feea:851 (eth0) | CONTAINER | 0 | yogi |
| c3 | RUNNING | 10.154.243.4 (eth0) | fd42:4e6a:c846:1bb1:216:3eff:fecf:73ed (eth0) | CONTAINER | 0 | gazoo |
Not a big deal since the core functionality works, so I consider this resolved. Thanks again for your time and help.
tomp
(Thomas Parrott)
September 2, 2022, 4:59pm
12
Great!
Can you show me the create command you used for the network and “lxc network show (network)” for the resulting network as I’d like to understand why you’re getting unexpected ip subnet.
slapcat
September 2, 2022, 5:02pm
13
Of course:
$ lxc network create UPLINK --type=physical parent=br0 --target=daphne
$ lxc network create UPLINK --type=physical parent=br0 --target=yogi
$ lxc network create UPLINK --type=physical parent=br0 --target=gazoo
$ lxc network create UPLINK --type=physical ipv4.ovn.ranges=10.0.1.2-10.0.1.254 ipv4.gateway=10.0.1.1/24 dns.nameservers=8.8.8.8
$ lxc network create ovnnet --type=ovn network=UPLINK
$ lxc network show ovnnet
bridge.mtu: "1442"
ipv4.address: 10.154.243.1/24
ipv4.nat: "true"
ipv6.address: fd42:4e6a:c846:1bb1::1/64
ipv6.nat: "true"
network: UPLINK
volatile.network.ipv4.address: 10.0.1.2
type: ovn
used_by: []
managed: true
status: Created
locations:
- daphne
- yogi
- gazoo
tomp
(Thomas Parrott)
September 2, 2022, 5:09pm
14
Ah ok so this is working as designed.
You can create and connect multiple ovn networks to the same uplink network (potentially all using the same internal subnet). Each ovn network will be allocated one ip from the uplink’s ipv4.ovn.ranges for use with its own virtual ovn router as the external Nat ip. Then all egress traffic from the instances connected to that ovn network will be natted to that ip.
The volatile.network.ipv4.address setting shows the external ip on the uplink network that is allocated to each ovn network.
If you create another ovn network connected to the same uplink you will see its assigned its own ip on the uplink network.
