nothing really nothing. I install oracle on my lxd and just connect and work with it.
how to do it online.
i run
ls -l /dev/disk/by-id/
total 0
lrwxrwxrwx 1 root root 9 Sep 5 09:54 ata-VMware_Virtual_SATA_CDRW_Drive_01000000000000000001 → …/…/sr0
lrwxrwxrwx 1 root root 10 Sep 5 09:54 dm-name-ubuntu–vg-ubuntu–lv → …/…/dm-0
lrwxrwxrwx 1 root root 10 Sep 5 09:54 dm-uuid-LVM-kxlKZP0mGB1pWknQstpKeqnT8xC1RmcKaLwQXOTmuN2CZKNc6CjeFpKNY1bPnZzi → …/…/dm-0
lrwxrwxrwx 1 root root 10 Sep 5 09:54 lvm-pv-uuid-SQsl7w-Bg0s-bm9Q-3A0c-hgdK-JSKX-zCnzNJ → …/…/sda4
lrwxrwxrwx 1 root root 10 Sep 5 09:54 lvm-pv-uuid-VRtxxJ-nJgd-LJDl-MsCX-U0qe-uvDh-iC9YLJ → …/…/sda3
then i try to import it
zpool import -a -f -d /dev/disk/by-id/ata
no pools available to import
reload and status of
systemctl reload snap.lxd.daemon systemctl status snap.lxd.daemon
show exit status 1
i try to open it says
cannot import ‘mirapool’: I/O error
Recovery is possible, but will result in some data loss.
Returning the pool to its state as of Mon 05 Sep 2022 01:54:53 AM CEST
should correct the problem. Approximately 20 seconds of data
must be discarded, irreversibly. After rewind, at least
one persistent user-data error will remain. Recovery can be attempted
by executing ‘zpool import -F mirapool’. A scrub of the pool
is strongly recommended after recovery.
Then i try to open with -F
and its op and running now.
I don’t know what going here?
Seems you are trying to mount a VMware CD ROM device as your zfs pool. That won’t work. You are probably should try to mount your LVM disk instead (as per your output). What does the command “lvscan” show?
@ rkeiieyrtp: no this just show that disk to my pool is absent. This is a simple ls by disk id
“ls -l /dev/disk/by-id/” @tmp: i don’t no what was reason but it working now after force start on my zpool
