blem
March 25, 2020, 7:59pm
1
Hello Linux Containers community,
I’m trying to set-up an LXC server on Ubuntu and I have an issue with LXC proxy.
My inputs:
Ubuntu 20.04 last daily live image (alpha)
LXD’s network is initialized with the following parameters:
networks:
description: “”
type: bridge
managed: false
ipv4.address: 10.0.1.1/24
ipv4.nat: “true”
ipv6.address: none
description: “Default LXD profile”
nictype: bridged
parent: lxdbr0
LXD container’s network is initialized with the following commands:
lxc network attach lxdbr0 lxc-c7 eth0 eth0
lxc config device set lxc-c7 eth0 ipv4.address 10.0.1.100
lxc config set lxc-c7 volatile.eth0.host_name veth-c7
And finally, the SSH proxy is configured with the following command:
lxc config device add lxc-c7 ssh proxy listen=tcp:0.0.0.0:2222 connect=tcp:127.0.0.1:22
But the LXC proxy looks stopped.
No LXD service is listed with the lsof -i -n
command.
Should have I to add an additional daemon?
Regards.
simos
(Simos Xenitellis)
March 25, 2020, 8:28pm
2
Hi!
If the LXD proxy did not get created, you will see in in the logs, at /var/snap/lxd/common/lxd/logs/lxc-c7/
. There is a file there for the proxy device.
If you do not see any error in the logfile for the proxy device, then the proxy device is likely running.
Use ss -tuna
to check that the port is in LISTEN mode. I noticed that lsof
does not show open ports in some cases.
blem
March 26, 2020, 12:48pm
3
I definitely have a issue with proxy:
# cat proxy.ssh.log
Error: remove 0.0.0.0:2222: read-only file system
panic: runtime error: invalid memory address or nil pointer dereference
[signal SIGSEGV: segmentation violation code=0x1 addr=0x0 pc=0x5a3398]
goroutine 1 [running]:
os.(*File).Name(...)
/snap/go/4098/src/os/file.go:50
net.FileListener(0x0, 0x0, 0x0, 0x0, 0x0)
/snap/go/4098/src/net/file.go:36 +0x88
main.(*cmdForkproxy).Run(0xc000010260, 0xc0002d9b80, 0xc00014b800, 0x6, 0x6, 0x0, 0x0)
/build/lxd/parts/lxd/go/src/github.com/lxc/lxd/lxd/main_forkproxy.go:352 +0x2de
github.com/spf13/cobra.(*Command).execute(0xc0002d9b80, 0xc00014b6e0, 0x6, 0x6, 0xc0002d9b80, 0xc00014b6e0)
/build/lxd/parts/lxd/go/src/github.com/spf13/cobra/command.go:826 +0x465
github.com/spf13/cobra.(*Command).ExecuteC(0xc000260f00, 0xc000257f60, 0x1, 0x1)
/build/lxd/parts/lxd/go/src/github.com/spf13/cobra/command.go:914 +0x2fc
github.com/spf13/cobra.(*Command).Execute(...)
/build/lxd/parts/lxd/go/src/github.com/spf13/cobra/command.go:864
main.main()
/build/lxd/parts/lxd/go/src/github.com/lxc/lxd/lxd/main.go:164 +0xd32
More context:
I’m sorry; I don’t know the Go language so it will be difficult for me to debug it.
Thanks for your help!
stgraber
(Stéphane Graber)
March 26, 2020, 1:22pm
4
Hmm, you shouldn’t really be using 3.0.4
on 20.04.
You may want to switch over to the current release with snap refresh lxd --channel=latest
blem
March 26, 2020, 1:44pm
5
And the snap refresh --channel=3.23 lxd
makes it work!
Thanks to both of you.
More generally, thanks Stéphane for your work on LXD and all your community support (I have seen so many messages from you on many Internet boards about virtualization)
I really appreciate your work.
