Greetings,
i want to give a public ip to a container, but i can’t reach it over the internet. i’ve tried to follow this: Give public ip one container with custom bridge
my bridge looks like this:
$lxc network show lxdbr0
ipv4.address: 10.191.26.1/24
ipv4.nat: "true"
ipv4.routes: 133.123.122.222
ipv6.address: none
type: bridge
- /1.0/containers/guest99
managed: true
the interfaces file on the container:
$cat /etc/network/interfaces
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet dhcp
post-up ip -4 addr add dev eth0 133.123.122.222/32
pre-down ip -4 addr del dev eth0 133.123.122.222/32
the container can access the internet, and i can ping the container from the host. but i can’t ping the container from a different machine.
lxc list shows
| guest99 | RUNNING | 133.123.122.222 (eth0) | | PERSISTENT | 0 |
| | | 10.191.26.120 (eth0) | | | |
ip route list on the host shows:
133.123.122.222 dev lxdbr0 proto static scope link
$lxc config device show guest99
bridge:
nictype: bridged
parent: lxdbr0
full config:
lxc config show guest99 --expanded
image.architecture: amd64
image.description: Debian stretch amd64 (20171207_22:42)
image.os: Debian
image.release: stretch
image.serial: "20171207_22:42"
volatile.base_image: 8251f73695dafe002d700e4560a60f0a30641c39e93de12988682aa917b3231f
volatile.bridge.hwaddr: 00:16:3e:d1:6b:5c
volatile.eth0.hwaddr: 00:16:3e:09:8a:43
volatile.eth0.name: eth1
volatile.idmap.base: "0"
volatile.idmap.next: '[{"Isuid":true,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":1000000000}]'
volatile.last_state.idmap: '[{"Isuid":true,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":1000000000}]'
bridge:
nictype: bridged
parent: lxdbr0
nictype: bridged
parent: lxdbr0
pool: lxdPool
weirdly there ist an eth1 interface and i have no idea where it came from.
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
inet6 ::1/128 scope host
122: eth0@if123: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:d1:6b:5c brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet 10.191.26.120/24 brd 10.191.26.255 scope global eth0
inet 133.123.122.222/32 scope global eth0
inet6 fe80::216:3eff:fed1:6b5c/64 scope link
124: eth1@if125: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:09:8a:43 brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet6 fe80::216:3eff:fe09:8a43/64 scope link
am I missing something? Thanks for your help!
