This LXD server currently has the following storage pools:
- black (backend="lvm", source="black")
Would you like to recover another storage pool? (yes/no) [default=no]: yes
Name of the storage pool: bigdisk
Name of the storage backend (ceph, btrfs, cephfs, dir, lvm, zfs): zfs
Source of the storage pool (block device, volume group, dataset, path, ... as applicable): bigdisk/lxd
Additional storage pool configuration property (KEY=VALUE, empty when done): zfs.pool_name=bigdisk
The recovery process will be scanning the following storage pools:
- EXISTING: "black" (backend="lvm", source="black")
- NEW: "bigdisk" (backend="zfs", source="bigdisk/lxd")
Would you like to continue with scanning for lost volumes? (yes/no) [default=yes]:
Scanning for unknown volumes...
No unknown volumes found. Nothing to do.
