OS & Version:
redacted@redacted:~$ cat /proc/version
Linux version 4.4.0-96-generic (buildd@lgw01-10) (gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.4) ) #119-Ubuntu SMP Tue Sep 12 14:59:54 UTC 2017
redacted@redacted:~$ lxd --version
2.0.10
redacted@redacted:~$ lxc remote add redacted redacted --password=redacted --accept-certificate --debug
DBUG[10-17|15:26:01] Raw response: {"type":"sync","status":"Success","status_code":200,"operation":"","error_code":0,"error":"","metadata":{"api_extensions":["id_map"],"api_status":"stable","api_version":"1.0","auth":"untrusted","public":false}}
DBUG[10-17|15:26:01] &{sync Success %!s(int=200) %!s(int=0) {"api_extensions":["id_map"],"api_status":"stable","api_version":"1.0","auth":"untrusted","public":false}}
DBUG[10-17|15:26:01] POST {"password":"redacted","type":"client"}
to https://redacted:8443/1.0/certificates
DBUG[10-17|15:26:02] Raw response: {"type":"sync","status":"Success","status_code":200,"operation":"","error_code":0,"error":"","metadata":null}
The communication is clearly happening. The trust certificate is also in the remote LXD server during execution, however this command just hangs here.
There are proxies in the environment, but the general domain is set to be ignored in both system and lxc config.
core.https_address: redacted:8443
core.proxy_ignore_hosts: redacted-ip,redacted-hostname
core.trust_password: true
Any thoughts?
