I have noticed that under lxc storage info, the reported capacity of the pool differs from ceph df:
$ lxc storage info remote
info:
driver: ceph
space used: 176.58GB
total space: 8.10TB
used by:
images:
- 46701fa2d99c72583f858c50a25f9f965f06a266b997be7a57a8e66c72b5175b
- 961fe898000818bd2d8262ba9cb5037defe8c08cce5f85246e97429c2f927a2f
instances:
- container
- vm
- vm
$ ceph df
--- RAW STORAGE ---
CLASS SIZE AVAIL USED RAW USED %RAW USED
hdd 22 TiB 21 TiB 130 GiB 138 GiB 0.63
ssd 346 GiB 310 GiB 36 GiB 37 GiB 10.57
TOTAL 22 TiB 22 TiB 166 GiB 175 GiB 0.78
--- POOLS ---
POOL ID PGS STORED OBJECTS USED %USED MAX AVAIL
device_health_metrics 1 1 0 B 9 0 B 0 6.2 TiB
lxd-storage 2 256 64 GiB 18.48k 164 GiB 0.86 7.2 TiB
cephfs_metadata 3 32 2.6 MiB 23 8.0 MiB 0 7.1 TiB
The pool I used in this case was lxd-storage. My question is how does LXD fetch the capacity of a Ceph storage pool given that the values differ by nearly a full TB?
