I’m not 100% sure if this should be here on snapcraft forum, but the latest snap refresh has locked up my LXD service and the snap daemon has been thrashing my disk for hours seemingly in infinite loop. I’m on Ubuntu 20.04 and use LXD every day.
According to the logs below the LXD daemon is active, however snapd doesn’t think it started, and likewise lxc cli command just hangs indefinitely.
Hoping for some advice before attempting to kill/restart things. Thank you.
➜ snap changes
ID Status Spawn Ready Summary
116 Doing today at 10:38 EST - Auto-refresh snaps "lxd", "snap-store", "gtk-common-themes"
➜ snap tasks 116
Done today at 10:38 EST today at 10:38 EST Ensure prerequisites for "lxd" are available
Done today at 10:38 EST today at 10:39 EST Download snap "lxd" (18402) from channel "latest/stable"
Done today at 10:38 EST today at 10:39 EST Fetch and check assertions for snap "lxd" (18402)
Done today at 10:38 EST today at 10:39 EST Mount snap "lxd" (18402)
Done today at 10:38 EST today at 10:39 EST Run pre-refresh hook of "lxd" snap if present
Done today at 10:38 EST today at 10:39 EST Stop snap "lxd" services
Done today at 10:38 EST today at 10:39 EST Remove aliases for snap "lxd"
Done today at 10:38 EST today at 10:39 EST Make current revision for snap "lxd" unavailable
Done today at 10:38 EST today at 10:39 EST Copy snap "lxd" data
Done today at 10:38 EST today at 10:39 EST Setup snap "lxd" (18402) security profiles
Done today at 10:38 EST today at 10:39 EST Make snap "lxd" (18402) available to the system
Done today at 10:38 EST today at 10:39 EST Automatically connect eligible plugs and slots of snap "lxd"
Done today at 10:38 EST today at 10:39 EST Set automatic aliases for snap "lxd"
Done today at 10:38 EST today at 10:39 EST Setup snap "lxd" aliases
Done today at 10:38 EST today at 10:39 EST Run post-refresh hook of "lxd" snap if present
Doing today at 10:38 EST - Start snap "lxd" (18402) services
Do today at 10:38 EST - Remove data for snap "lxd" (18251)
Do today at 10:38 EST - Remove snap "lxd" (18251) from the system
Do today at 10:38 EST - Clean up "lxd" (18402) install
Do today at 10:38 EST - Run configure hook of "lxd" snap if present
Do today at 10:38 EST - Run health check of "lxd" snap
Done today at 10:38 EST today at 10:38 EST Ensure prerequisites for "snap-store" are available
Done today at 10:38 EST today at 10:39 EST Download snap "snap-store" (498) from channel "latest/stable/ubuntu-20.04"
Done today at 10:38 EST today at 10:39 EST Fetch and check assertions for snap "snap-store" (498)
Done today at 10:38 EST today at 10:39 EST Mount snap "snap-store" (498)
Done today at 10:38 EST today at 10:39 EST Run pre-refresh hook of "snap-store" snap if present
Done today at 10:38 EST today at 10:39 EST Stop snap "snap-store" services
Done today at 10:38 EST today at 10:39 EST Remove aliases for snap "snap-store"
Done today at 10:38 EST today at 10:39 EST Make current revision for snap "snap-store" unavailable
Done today at 10:38 EST today at 10:39 EST Copy snap "snap-store" data
Done today at 10:38 EST today at 10:39 EST Setup snap "snap-store" (498) security profiles
Done today at 10:38 EST today at 10:39 EST Make snap "snap-store" (498) available to the system
Done today at 10:38 EST today at 10:39 EST Automatically connect eligible plugs and slots of snap "snap-store"
Done today at 10:38 EST today at 10:39 EST Set automatic aliases for snap "snap-store"
Done today at 10:38 EST today at 10:39 EST Setup snap "snap-store" aliases
Done today at 10:38 EST today at 10:39 EST Run post-refresh hook of "snap-store" snap if present
Done today at 10:38 EST today at 10:39 EST Start snap "snap-store" (498) services
Done today at 10:38 EST today at 10:39 EST Remove data for snap "snap-store" (481)
Done today at 10:38 EST today at 10:39 EST Remove snap "snap-store" (481) from the system
Done today at 10:38 EST today at 10:39 EST Clean up "snap-store" (498) install
Done today at 10:38 EST today at 10:39 EST Run configure hook of "snap-store" snap if present
Done today at 10:38 EST today at 10:39 EST Run health check of "snap-store" snap
Done today at 10:38 EST today at 10:38 EST Ensure prerequisites for "gtk-common-themes" are available
Done today at 10:38 EST today at 10:38 EST Download snap "gtk-common-themes" (1513) from channel "latest/stable/ubuntu-20.04"
Done today at 10:38 EST today at 10:38 EST Fetch and check assertions for snap "gtk-common-themes" (1513)
Done today at 10:38 EST today at 10:38 EST Mount snap "gtk-common-themes" (1513)
Done today at 10:38 EST today at 10:38 EST Run pre-refresh hook of "gtk-common-themes" snap if present
Done today at 10:38 EST today at 10:38 EST Stop snap "gtk-common-themes" services
Done today at 10:38 EST today at 10:38 EST Remove aliases for snap "gtk-common-themes"
Done today at 10:38 EST today at 10:38 EST Make current revision for snap "gtk-common-themes" unavailable
Done today at 10:38 EST today at 10:38 EST Copy snap "gtk-common-themes" data
Done today at 10:38 EST today at 10:38 EST Setup snap "gtk-common-themes" (1513) security profiles
Done today at 10:38 EST today at 10:38 EST Make snap "gtk-common-themes" (1513) available to the system
Done today at 10:38 EST today at 10:38 EST Automatically connect eligible plugs and slots of snap "gtk-common-themes"
Done today at 10:38 EST today at 10:38 EST Set automatic aliases for snap "gtk-common-themes"
Done today at 10:38 EST today at 10:38 EST Setup snap "gtk-common-themes" aliases
Done today at 10:38 EST today at 10:38 EST Run post-refresh hook of "gtk-common-themes" snap if present
Done today at 10:38 EST today at 10:38 EST Start snap "gtk-common-themes" (1513) services
Done today at 10:38 EST today at 10:38 EST Clean up "gtk-common-themes" (1513) install
Done today at 10:38 EST today at 10:38 EST Run configure hook of "gtk-common-themes" snap if present
Done today at 10:38 EST today at 10:38 EST Run health check of "gtk-common-themes" snap
Doing today at 10:38 EST - Consider re-refresh of "lxd", "snap-store", "gtk-common-themes"
Done today at 10:39 EST today at 10:39 EST Connect snap-store:opengl to snapd:opengl
Done today at 10:39 EST today at 10:39 EST Setup snap "snap-store" (498) security profiles for auto-connections
It’s currently 12:44 EST (2 hours later) than above log.
➜ snap services lxd.daemon
Service Startup Current Notes
lxd.daemon enabled active socket-activated
➜ snap info lxd
services:
lxd.activate: oneshot, enabled, inactive
lxd.daemon: simple, enabled, active
snap-id: J60k4JY0HppjwOjW8dZdYc8obXKxujRu
tracking: latest/stable
refresh-date: today at 10:39 EST
channels:
latest/stable: 4.8 2020-11-25 (18402) 73MB -
latest/candidate: 4.8 2020-11-24 (18402) 73MB -
latest/beta: ↑
latest/edge: git-669c722 2020-11-25 (18418) 73MB -
4.8/stable: 4.8 2020-11-25 (18402) 73MB -
4.8/candidate: 4.8 2020-11-24 (18402) 73MB -
4.8/beta: ↑
4.8/edge: ↑
➜ snap logs -n 100 lxd.daemon
2020-11-20T14:34:34Z lxd.daemon[1734]: 9: fd: 14: perf_event
2020-11-20T14:34:34Z lxd.daemon[1734]: 10: fd: 15: cpuset
2020-11-20T14:34:34Z lxd.daemon[1734]: 11: fd: 16: freezer
2020-11-20T14:34:34Z lxd.daemon[1734]: 12: fd: 17: hugetlb
2020-11-20T14:34:34Z lxd.daemon[1734]: Kernel supports pidfds
2020-11-20T14:34:34Z lxd.daemon[1734]: Kernel does not support swap accounting
2020-11-20T14:34:34Z lxd.daemon[1734]: api_extensions:
2020-11-20T14:34:34Z lxd.daemon[1734]: - cgroups
2020-11-20T14:34:34Z lxd.daemon[1734]: - sys_cpu_online
2020-11-20T14:34:34Z lxd.daemon[1734]: - proc_cpuinfo
2020-11-20T14:34:34Z lxd.daemon[1734]: - proc_diskstats
2020-11-20T14:34:34Z lxd.daemon[1734]: - proc_loadavg
2020-11-20T14:34:34Z lxd.daemon[1734]: - proc_meminfo
2020-11-20T14:34:34Z lxd.daemon[1734]: - proc_stat
2020-11-20T14:34:34Z lxd.daemon[1734]: - proc_swaps
2020-11-20T14:34:34Z lxd.daemon[1734]: - proc_uptime
2020-11-20T14:34:34Z lxd.daemon[1734]: - shared_pidns
2020-11-20T14:34:34Z lxd.daemon[1734]: - cpuview_daemon
2020-11-20T14:34:34Z lxd.daemon[1734]: - loadavg_daemon
2020-11-20T14:34:34Z lxd.daemon[1734]: - pidfds
2020-11-20T14:34:36Z lxd.daemon[1328]: => Starting LXD
2020-11-20T14:34:36Z lxd.daemon[2035]: t=2020-11-20T09:34:36-0500 lvl=warn msg=" - Couldn't find the CGroup blkio.weight, disk priority will be ignored"
2020-11-20T14:34:36Z lxd.daemon[2035]: t=2020-11-20T09:34:36-0500 lvl=warn msg=" - Couldn't find the CGroup memory swap accounting, swap limits will be ignored"
2020-11-20T14:34:40Z lxd.daemon[2035]: t=2020-11-20T09:34:40-0500 lvl=warn msg="Using writeback cache I/O with \"/var/snap/lxd/common/lxd/storage-pools/default/custom/default_blkcaptdev-disk1/root.img\" as backing filesystem is \"btrfs\""
2020-11-20T14:34:40Z lxd.daemon[2035]: t=2020-11-20T09:34:40-0500 lvl=warn msg="Using writeback cache I/O with \"/var/snap/lxd/common/lxd/storage-pools/default/custom/default_blkcaptdev-disk2/root.img\" as backing filesystem is \"btrfs\""
2020-11-20T14:34:40Z lxd.daemon[2035]: t=2020-11-20T09:34:40-0500 lvl=warn msg="Using writeback cache I/O with \"/var/snap/lxd/common/lxd/storage-pools/default/custom/default_blkcaptdev-disk3/root.img\" as backing filesystem is \"btrfs\""
2020-11-20T14:34:40Z lxd.daemon[2035]: t=2020-11-20T09:34:40-0500 lvl=warn msg="Using writeback cache I/O with \"/var/snap/lxd/common/lxd/storage-pools/default/virtual-machines/blkcaptdev/root.img\" as backing filesystem is \"btrfs\""
2020-11-20T14:34:41Z lxd.daemon[1328]: => LXD is ready
2020-11-22T18:17:22Z lxd.daemon[2035]: t=2020-11-22T13:17:22-0500 lvl=warn msg="Using writeback cache I/O with \"/var/snap/lxd/common/lxd/storage-pools/default/custom/default_blkcaptdev-disk1/root.img\" as backing filesystem is \"btrfs\""
2020-11-22T18:17:22Z lxd.daemon[2035]: t=2020-11-22T13:17:22-0500 lvl=warn msg="Using writeback cache I/O with \"/var/snap/lxd/common/lxd/storage-pools/default/custom/default_blkcaptdev-disk2/root.img\" as backing filesystem is \"btrfs\""
2020-11-22T18:17:22Z lxd.daemon[2035]: t=2020-11-22T13:17:22-0500 lvl=warn msg="Using writeback cache I/O with \"/var/snap/lxd/common/lxd/storage-pools/default/custom/default_blkcaptdev-disk3/root.img\" as backing filesystem is \"btrfs\""
2020-11-22T18:17:22Z lxd.daemon[2035]: t=2020-11-22T13:17:22-0500 lvl=warn msg="Using writeback cache I/O with \"/var/snap/lxd/common/lxd/storage-pools/default/virtual-machines/blkcaptdev/root.img\" as backing filesystem is \"btrfs\""
2020-11-22T18:21:06Z lxd.daemon[2035]: t=2020-11-22T13:21:06-0500 lvl=warn msg="Using writeback cache I/O with \"/var/snap/lxd/common/lxd/storage-pools/default/custom/default_blkcaptdev-disk1/root.img\" as backing filesystem is \"btrfs\""
2020-11-22T18:21:06Z lxd.daemon[2035]: t=2020-11-22T13:21:06-0500 lvl=warn msg="Using writeback cache I/O with \"/var/snap/lxd/common/lxd/storage-pools/default/custom/default_blkcaptdev-disk2/root.img\" as backing filesystem is \"btrfs\""
2020-11-22T18:21:06Z lxd.daemon[2035]: t=2020-11-22T13:21:06-0500 lvl=warn msg="Using writeback cache I/O with \"/var/snap/lxd/common/lxd/storage-pools/default/custom/default_blkcaptdev-disk3/root.img\" as backing filesystem is \"btrfs\""
2020-11-22T18:21:06Z lxd.daemon[2035]: t=2020-11-22T13:21:06-0500 lvl=warn msg="Using writeback cache I/O with \"/var/snap/lxd/common/lxd/storage-pools/default/virtual-machines/blkcaptdev/root.img\" as backing filesystem is \"btrfs\""
2020-11-25T15:39:40Z systemd[1]: Stopping Service for snap application lxd.daemon...
2020-11-25T15:39:40Z lxd.daemon[519681]: => Stop reason is: snap refresh
2020-11-25T15:39:40Z lxd.daemon[519681]: => Stopping LXD
2020-11-25T15:39:42Z lxd.daemon[1328]: => LXD exited cleanly
2020-11-25T15:39:42Z lxd.daemon[519681]: ==> Stopped LXD
2020-11-25T15:39:42Z systemd[1]: snap.lxd.daemon.service: Succeeded.
2020-11-25T15:39:42Z systemd[1]: Stopped Service for snap application lxd.daemon.
2020-11-25T15:39:45Z systemd[1]: Started Service for snap application lxd.daemon.
2020-11-25T15:39:45Z lxd.daemon[519881]: => Preparing the system (18402)
2020-11-25T15:39:45Z lxd.daemon[519881]: ==> Loading snap configuration
2020-11-25T15:39:45Z lxd.daemon[519881]: ==> Setting up mntns symlink (mnt:[4026533025])
2020-11-25T15:39:45Z lxd.daemon[519881]: ==> Setting up kmod wrapper
2020-11-25T15:39:45Z lxd.daemon[519881]: ==> Preparing /boot
2020-11-25T15:39:45Z lxd.daemon[519881]: ==> Preparing a clean copy of /run
2020-11-25T15:39:45Z lxd.daemon[519881]: ==> Preparing /run/bin
2020-11-25T15:39:45Z lxd.daemon[519881]: ==> Preparing a clean copy of /etc
2020-11-25T15:39:45Z lxd.daemon[519881]: ==> Preparing a clean copy of /usr/share/misc
2020-11-25T15:39:45Z lxd.daemon[519881]: ==> Setting up ceph configuration
2020-11-25T15:39:45Z lxd.daemon[519881]: ==> Setting up LVM configuration
2020-11-25T15:39:45Z lxd.daemon[519881]: ==> Rotating logs
2020-11-25T15:39:45Z lxd.daemon[519881]: ==> Setting up ZFS (0.8)
2020-11-25T15:39:45Z lxd.daemon[519881]: ==> Escaping the systemd cgroups
2020-11-25T15:39:45Z lxd.daemon[519881]: ====> Detected cgroup V1
2020-11-25T15:39:45Z lxd.daemon[519881]: ==> Escaping the systemd process resource limits
2020-11-25T15:39:45Z lxd.daemon[519881]: ==> Disabling shiftfs on this kernel (auto)
2020-11-25T15:39:45Z lxd.daemon[519881]: => Re-using existing LXCFS
2020-11-25T15:39:45Z lxd.daemon[519881]: => Starting LXD
2020-11-25T15:39:45Z lxd.daemon[520000]: t=2020-11-25T10:39:45-0500 lvl=warn msg=" - Couldn't find the CGroup blkio.weight, disk priority will be ignored"
2020-11-25T15:39:45Z lxd.daemon[520000]: t=2020-11-25T10:39:45-0500 lvl=warn msg=" - Couldn't find the CGroup memory swap accounting, swap limits will be ignored"
2020-11-25T16:19:45Z lxd.daemon[1734]: Closed liblxcfs.so
2020-11-25T16:19:45Z lxd.daemon[1734]: Running destructor lxcfs_exit
2020-11-25T16:19:45Z lxd.daemon[1734]: Running constructor lxcfs_init to reload liblxcfs
2020-11-25T16:19:45Z lxd.daemon[1734]: mount namespace: 5
2020-11-25T16:19:45Z lxd.daemon[1734]: hierarchies:
2020-11-25T16:19:45Z lxd.daemon[1734]: 0: fd: 6:
2020-11-25T16:19:45Z lxd.daemon[1734]: 1: fd: 7: name=systemd
2020-11-25T16:19:45Z lxd.daemon[1734]: 2: fd: 8: cpu,cpuacct
2020-11-25T16:19:45Z lxd.daemon[1734]: 3: fd: 9: rdma
2020-11-25T16:19:45Z lxd.daemon[1734]: 4: fd: 10: pids
2020-11-25T16:19:45Z lxd.daemon[1734]: 5: fd: 11: blkio
2020-11-25T16:19:45Z lxd.daemon[1734]: 6: fd: 12: net_cls,net_prio
2020-11-25T16:19:45Z lxd.daemon[1734]: 7: fd: 13: memory
2020-11-25T16:19:45Z lxd.daemon[1734]: 8: fd: 14: devices
2020-11-25T16:19:45Z lxd.daemon[1734]: 9: fd: 15: perf_event
2020-11-25T16:19:45Z lxd.daemon[1734]: 10: fd: 16: cpuset
2020-11-25T16:19:45Z lxd.daemon[1734]: 11: fd: 17: freezer
2020-11-25T16:19:45Z lxd.daemon[1734]: 12: fd: 19: hugetlb
2020-11-25T16:19:45Z lxd.daemon[1734]: Kernel supports pidfds
2020-11-25T16:19:45Z lxd.daemon[1734]: Kernel does not support swap accounting
2020-11-25T16:19:45Z lxd.daemon[1734]: api_extensions:
2020-11-25T16:19:45Z lxd.daemon[1734]: - cgroups
2020-11-25T16:19:45Z lxd.daemon[1734]: - sys_cpu_online
2020-11-25T16:19:45Z lxd.daemon[1734]: - proc_cpuinfo
2020-11-25T16:19:45Z lxd.daemon[1734]: - proc_diskstats
2020-11-25T16:19:45Z lxd.daemon[1734]: - proc_loadavg
2020-11-25T16:19:45Z lxd.daemon[1734]: - proc_meminfo
2020-11-25T16:19:45Z lxd.daemon[1734]: - proc_stat
2020-11-25T16:19:45Z lxd.daemon[1734]: - proc_swaps
2020-11-25T16:19:45Z lxd.daemon[1734]: - proc_uptime
2020-11-25T16:19:45Z lxd.daemon[1734]: - shared_pidns
2020-11-25T16:19:45Z lxd.daemon[1734]: - cpuview_daemon
2020-11-25T16:19:45Z lxd.daemon[1734]: - loadavg_daemon
2020-11-25T16:19:45Z lxd.daemon[1734]: - pidfds
2020-11-25T16:19:45Z lxd.daemon[1734]: Reloaded LXCFS
All the past 2 hours snapd has been hitting my disk:
Total DISK READ: 0.00 B/s | Total DISK WRITE: 4.75 M/s
Current DISK READ: 0.00 B/s | Current DISK WRITE: 4.28 M/s
TID PRIO USER DISK READ DISK WRITE SWAPIN IO> COMMAND
1278 be/4 root 0.00 B/s 2.03 M/s 0.00 % 9.04 % snapd
1245 be/4 root 0.00 B/s 623.29 K/s 0.00 % 2.80 % snapd
1267 be/4 root 0.00 B/s 623.29 K/s 0.00 % 2.60 % snapd
1136 be/4 root 0.00 B/s 415.53 K/s 0.00 % 1.82 % snapd
520569 be/4 root 0.00 B/s 415.53 K/s 0.00 % 1.81 % snapd
1298 be/4 root 0.00 B/s 415.53 K/s 0.00 % 1.78 % snapd
542840 be/4 will 0.00 B/s 25.18 K/s 0.00 % 0.52 % chrome --password-store=basic --profile-directory=Default [ThreadPoolForeg]
➜ sudo fatrace
Failed to add watch for fuse mount /run/user/1000/doc: Permission denied
snapd(1085): O /var/lib/snapd/assertions/asserts-v0/model/16/generic/generic-classic
snapd(1085): R /var/lib/snapd/assertions/asserts-v0/model/16/generic/generic-classic
snapd(1085): RCO /var/lib/snapd/assertions/asserts-v0/model/16/generic/generic-classic/active
snapd(1085): C /var/lib/snapd/assertions/asserts-v0/model/16/generic/generic-classic
snapd(1085): O /var/lib/snapd/assertions/asserts-v0/serial/generic/generic-classic/69d3e787-2f76-4db2-aed9-bf18c2c4e95e
snapd(1085): R /var/lib/snapd/assertions/asserts-v0/serial/generic/generic-classic/69d3e787-2f76-4db2-aed9-bf18c2c4e95e
snapd(1085): O /var/lib/snapd/assertions/asserts-v0/serial/generic/generic-classic/69d3e787-2f76-4db2-aed9-bf18c2c4e95e/active
snapd(1085): RC /var/lib/snapd/assertions/asserts-v0/serial/generic/generic-classic/69d3e787-2f76-4db2-aed9-bf18c2c4e95e/active
snapd(1085): C /var/lib/snapd/assertions/asserts-v0/serial/generic/generic-classic/69d3e787-2f76-4db2-aed9-bf18c2c4e95e
snapd(1085): O /var/lib/snapd/state.json.xXpbGhyCDm6V~
snapd(1085): W /var/lib/snapd/state.json.xXpbGhyCDm6V~
snapd(1085): CW /var/lib/snapd/state.json.xXpbGhyCDm6V~
snapd(1085): O /var/lib/snapd/state.json.lTK8TMnnGDtb~
snapd(1085): W /var/lib/snapd/state.json.lTK8TMnnGDtb~
snapd(1085): CW /var/lib/snapd/state.json.lTK8TMnnGDtb~
snapd(1085): O /var/lib/snapd/assertions/asserts-v0/model/16/generic/generic-classic/active
snapd(1085): RC /var/lib/snapd/assertions/asserts-v0/model/16/generic/generic-classic/active
snapd(1085): O /var/lib/snapd/state.json.cLmnFb2vJwSW~
snapd(1085): W /var/lib/snapd/state.json.cLmnFb2vJwSW~
snapd(1085): CW /var/lib/snapd/state.json.cLmnFb2vJwSW~
snapd(1085): O /var/lib/snapd/state.json.LDr3Kcxpqh7f~
snapd(1085): W /var/lib/snapd/state.json.LDr3Kcxpqh7f~
snapd(1085): CW /var/lib/snapd/state.json.LDr3Kcxpqh7f~
snapd(1085): O /var/lib/snapd/state.json.XjTV151PvGln~
snapd(1085): W /var/lib/snapd/state.json.XjTV151PvGln~
snapd(1085): CW /var/lib/snapd/state.json.XjTV151PvGln~
snapd(1085): O /var/lib/snapd/state.json.dhVk1DrVgPFy~
snapd(1085): W /var/lib/snapd/state.json.dhVk1DrVgPFy~
