I am facing error as below while executing lxd_snapcraft --target-arch=arm64 --enable-experimental-target-arch --enable-experimental-plugin
Error: Failed add validation for device "bamboo": Missing source path "/data/" for disk "bamboo"
What could be the possible solution?
Thanks
Hi!
I am not familiar with lxd_snapcraft. I assume it is part of the building process for snap packages, and it uses LXD behind the scenes. You should direct this query to snapcraft.
lxd_snapcraft
This forum provides support for Incus, which is a continuation of LXD.
