Oz_Dror
(Oz Dror)
April 22, 2021, 1:07am
1
Hi
I have lxd running on Ubuntu 21.04 with zfs. Since 4/13/21 no container snapshots are being taken. My lxd is a snap package, which updates automatically. Was there any change in the last update that affected snapshot taking. Currently my snapshot setup is as follows:
snapshots.expiry: 2w
snapshots.pattern: arch-snapshot-%d
snapshots.schedule: 0 6,12-22/2 * * *
snapshots.schedule.stopped: "no"
Any Ideas how to restore snapshot taking?
I can take manual snapshots with the command “lxc snapshot” The scheduled snapshots do not work.
stgraber
(Stéphane Graber)
April 22, 2021, 1:53am
2
Anything in lxd.log that would point to what’s wrong with the snapshot scheduling?
stgraber
(Stéphane Graber)
April 22, 2021, 1:54am
3
I’ve checked on mine and my daily snapshots are still happening but I don’t have as complex a pattern as yours.
Oz_Dror
(Oz Dror)
April 22, 2021, 2:49pm
4
Looking at the lxd.log
I am just getting messages about pruning old snapshots not about creating ones as follows:
t=2021-04-21T19:13:21-0700 lvl=info msg="Started container" action=start created=2021-04-19T11:49:05-0700 ephemeral=false instance=manjaro instanceType=container project=default stateful=false used=2021-04-21T18:13:43-0700
t=2021-04-21T19:22:31-0700 lvl=info msg="Shut down container" action=stop created=2021-04-19T11:49:05-0700 ephemeral=false instance=manjaro instanceType=container project=default stateful=false used=2021-04-21T19:13:21-0700
t=2021-04-21T19:22:35-0700 lvl=info msg="Starting container" action=start created=2021-04-19T11:49:05-0700 ephemeral=false instance=manjaro instanceType=container project=default stateful=false used=2021-04-21T19:13:21-0700
t=2021-04-21T19:22:35-0700 lvl=info msg="Started container" action=start created=2021-04-19T11:49:05-0700 ephemeral=false instance=manjaro instanceType=container project=default stateful=false used=2021-04-21T19:13:21-0700
t=2021-04-21T19:24:14-0700 lvl=info msg="Shut down container" action=stop created=2021-04-19T11:49:05-0700 ephemeral=false instance=manjaro instanceType=container project=default stateful=false used=2021-04-21T19:22:35-0700
t=2021-04-21T19:31:59-0700 lvl=info msg="Pruning expired instance backups"
t=2021-04-21T19:31:59-0700 lvl=info msg="Updating images"
t=2021-04-21T19:31:59-0700 lvl=info msg="Done pruning expired instance backups"
t=2021-04-21T19:31:59-0700 lvl=info msg="Done updating images"
t=2021-04-21T20:00:25-0700 lvl=info msg="Pruning expired instance snapshots"
t=2021-04-21T20:00:25-0700 lvl=info msg="Deleting container" created=2021-04-07T20:00:06-0700 ephemeral=false instance=arch/arch-snapshot-130 instanceType=container project=default used=0001-01-01T00:00:00+0000
t=2021-04-21T20:00:25-0700 lvl=info msg="Done pruning expired instance snapshots"
t=2021-04-21T20:00:25-0700 lvl=info msg="Deleted container" created=2021-04-07T20:00:06-0700 ephemeral=false instance=arch/arch-snapshot-130 instanceType=container project=default used=0001-01-01T00:00:00+0000
t=2021-04-21T20:31:59-0700 lvl=info msg="Updating images"
t=2021-04-21T20:31:59-0700 lvl=info msg="Pruning expired instance backups"
t=2021-04-21T20:31:59-0700 lvl=info msg="Done updating images"
t=2021-04-21T20:31:59-0700 lvl=info msg="Done pruning expired instance backups"
t=2021-04-21T21:31:59-0700 lvl=info msg="Pruning expired instance backups"
t=2021-04-21T21:31:59-0700 lvl=info msg="Updating images"
t=2021-04-21T21:31:59-0700 lvl=info msg="Done updating images"
t=2021-04-21T21:31:59-0700 lvl=info msg="Done pruning expired instance backups"
t=2021-04-21T21:50:39-0700 lvl=info msg="Starting container" action=start created=2021-04-19T11:49:05-0700 ephemeral=false instance=manjaro instanceType=container project=default stateful=false used=2021-04-21T19:22:35-0700
t=2021-04-21T21:50:40-0700 lvl=info msg="Started container" action=start created=2021-04-19T11:49:05-0700 ephemeral=false instance=manjaro instanceType=container project=default stateful=false used=2021-04-21T19:22:35-0700
t=2021-04-21T21:55:14-0700 lvl=info msg="Starting container" action=start created=2021-04-19T11:49:05-0700 ephemeral=false instance=manjaro instanceType=container project=default stateful=false used=2021-04-21T21:50:39-0700
t=2021-04-21T21:55:15-0700 lvl=info msg="Started container" action=start created=2021-04-19T11:49:05-0700 ephemeral=false instance=manjaro instanceType=container project=default stateful=false used=2021-04-21T21:50:39-0700
t=2021-04-21T22:08:05-0700 lvl=info msg="Starting container" action=start created=2021-04-19T11:49:05-0700 ephemeral=false instance=manjaro instanceType=container project=default stateful=false used=2021-04-21T21:55:14-0700
t=2021-04-21T22:08:05-0700 lvl=info msg="Started container" action=start created=2021-04-19T11:49:05-0700 ephemeral=false instance=manjaro instanceType=container project=default stateful=false used=2021-04-21T21:55:14-0700
t=2021-04-22T07:10:42-0700 lvl=info msg="Updating images"
t=2021-04-22T07:10:42-0700 lvl=info msg="Pruning expired instance backups"
t=2021-04-22T07:10:42-0700 lvl=info msg="Done updating images"
t=2021-04-22T07:10:42-0700 lvl=info msg="Done pruning expired instance backups"
Where is the script for generating the snapshots may be I can run manually and see what is the issue.
stgraber
(Stéphane Graber)
April 22, 2021, 7:51pm
5
Ok, can you run lxc monitor --type=logging --pretty in a terminal and let it run until at least the next scheduled snapshot should happen? That may give us some more details on what’s going on.
LXD doesn’t run scripts to do this kind of stuff, we have an internal scheduler which interprets those cron patterns and then triggers the snapshot when needed. I suspect we may have broken something when adding the new alias logic.
My gut feeling is that the comma in the pattern is the issue but maybe I’m wrong
Oz_Dror
(Oz Dror)
April 23, 2021, 1:04am
6
at 6pm a snapshot of the arch container was supposed to be created. It deleted on old snapshot, but no new snapshot was created. Here is The log.
DBUG[04-22|18:01:19] New task Operation: 9169cae9-2207-4b89-bf10-88021289c8d3
INFO[04-22|18:01:19] Pruning expired instance snapshots
DBUG[04-22|18:01:19] Started task operation: 9169cae9-2207-4b89-bf10-88021289c8d3
INFO[04-22|18:01:19] Deleting container used="0001-01-01 00:00:00 +0000 UTC" created="2021-04-08 18:00:41.181594745 -0700 PDT" ephemeral=false instance=arch/arch-snapshot-131 instanceType=container project=default
INFO[04-22|18:01:19] Done pruning expired instance snapshots
DBUG[04-22|18:01:19] DeleteInstanceSnapshot started pool=lxd project=default driver=zfs instance=arch/arch-snapshot-131
DBUG[04-22|18:01:19] Deleting instance snapshot volume pool=lxd project=default snapshotName=arch-snapshot-131 volName=arch driver=zfs instance=arch/arch-snapshot-131
DBUG[04-22|18:01:19] DeleteInstanceSnapshot finished driver=zfs instance=arch/arch-snapshot-131 pool=lxd project=default
DBUG[04-22|18:01:19] UpdateInstanceBackupFile started instance=arch pool=lxd project=default driver=zfs
DBUG[04-22|18:01:19] Skipping unmount as in use driver=zfs pool=lxd refCount=1
DBUG[04-22|18:01:19] Success for task operation: 9169cae9-2207-4b89-bf10-88021289c8d3
DBUG[04-22|18:01:19] UpdateInstanceBackupFile finished driver=zfs instance=arch pool=lxd project=default
INFO[04-22|18:01:19] Deleted container created="2021-04-08 18:00:41.181594745 -0700 PDT" ephemeral=false instance=arch/arch-snapshot-131 instanceType=container project=default used="0001-01-01 00:00:00 +0000 UTC"
Oz_Dror
(Oz Dror)
April 23, 2021, 3:16am
7
I have a temporary workaround
I changed
to
snapshots.schedule: ‘@hourly ’
Now I am getting snapshots. There is an issue with the old syntax.
stgraber
(Stéphane Graber)
April 23, 2021, 4:07am
8
stgraber@castiana:~$ lxc list a -c n,snapshots.schedule,S
| NAME | SNAPSHOTS SCHEDULE | SNAPSHOTS |
| a1 | 0 6,12-22/2 * * * | 0 |
| a2 | 0 6-22/2 * * * | 0 |
| a3 | 0 6,12-22 * * * | 0 |
| a4 | 0 6-22 * * * | 0 |
| a5 | 0 6,7,8,9,10 * * * | 0 |
Running this here, let’s see if any of them trigger here.
stgraber
(Stéphane Graber)
April 23, 2021, 1:44pm
9
Confirmed that the comma is the issue, it’s breaking the cron pattern.
stgraber
(Stéphane Graber)
April 23, 2021, 2:31pm
10
https://github.com/lxc/lxd/pull/8711 should fix your issue and also properly allow for multiple schedules.
