Hi, I’ve installed Incus on Fedora 38 Server following the migration instructions. I’ve checked Incus info and lxd info run ok but when I run “lxd-to-incus” I get “command not found”
I’m running lxd 5.20-51a2393 Snap
Not sure what to do next?
@ganto ^
In the mean time, I built a static version of the current lxd-to-incus
that you can download from https://dl.stgraber.org/lxd-to-incus
Thank you Stéphane - The migration worked fine.
Note for others:-
I put the static file I downloaded in /usr/bin/lxd-to-incus then chmod +x
I could then carry out the rest of the instructions from
https://linuxcontainers.org/incus/docs/main/howto/server_migrate_lxd/
Migration worked here as well, on Fedora 39. The standalone version deserves at least a mention in the official incus docs.
Note that if your /var/lib/lxd
is a custom mount point, the migration tool actually addresses that and attempts to remount it. However since my filesystem layout is a bit of complex, after making changes to fstab I still needed to manually reboot the system once before incus can create new instances.
COPR bug is here: lxc-to-incus "TestConvertNetworkConfig" fails · Issue #23 · ganto/copr-lxc4 · GitHub
Old post but for those who would experience the problem, it is probably an incorrectly updated PATH : sudo /YourGoBin/lxc-to-incus
would do the job
$GOBIN may be by default /WhereYouInstalledGo/go/bin
