Hi
Several non-Incus problems on a stand-alone host caused the lxd-to-incus migration process to fail near the end because it couldn’t find the devices backing the storage pools. It mainly failed when an unattended-upgrades process decided to roughly coincide with the migration and the upgrades failed, which in turn caused all the ZFS pools to disappear completely at the OS level, but a dpkg --configure -a and a reboot fixed things and got Incus running without further intervention.
Here is the last output of the migration process.
Proceed with the migration? [default=no]: yes
=> Stopping the source server
=> Stopping the target server
=> Wiping the target server
=> Migrating the data
=> Migrating database
=> Writing database patch
=> Cleaning up target paths
=> Starting the target server
Error: Failed to start the target server: Failed to run: systemctl start incus.service incus.socket: exit status 1 (Job for incus.service failed because the control process exited with error code.
See "systemctl status incus.service" and "journalctl -xeu incus.service" for details.)
What I need to know is what to do to safely remove the LXD Snap from this host without it trying to destroy anything that Incus might be using? I would normally run snap remove lxd --purge on a manual migration, but I’m too afraid to run it on this host now.
I’ve done lxc storage list and lxc list which both show nothing.
Thanks.
