LXD to Incus obliges apparmor
Hey,
Just migrating from LXD to Incus using the command.
All containers didn’t start and won’t start until I put raw.lxc "lxc.apparmor.profile=unconfined"
Launching using the console to have more logs:
# incus start --console svc-owncloud
To detach from the console, press: <ctrl>+a q
File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
Failed to allocate notification socket: Permission denied
[!!!!!!] Failed to start up manager.
Exiting PID 1...
incus info is :
# incus info
  core.https_address: 192.168.2.1:8443
api_extensions:
- container_stop_priority
- container_syscall_filtering
- auth_pki
- container_last_used_at
- etag
- patch
- usb_devices
- https_allowed_credentials
- image_compression_algorithm
- directory_manipulation
- container_cpu_time
- storage_zfs_use_refquota
- storage_lvm_mount_options
- network
- profile_usedby
- container_push
- container_exec_recording
- certificate_update
- gpu_devices
- container_image_properties
- migration_progress
- id_map
- network_firewall_filtering
- network_routes
- storage
- file_delete
- file_append
- network_dhcp_expiry
- storage_lvm_vg_rename
- storage_lvm_thinpool_rename
- network_vlan
- image_create_aliases
- container_stateless_copy
- container_only_migration
- storage_zfs_clone_copy
- unix_device_rename
- storage_lvm_use_thinpool
- storage_rsync_bwlimit
- network_vxlan_interface
- storage_btrfs_mount_options
- entity_description
- image_force_refresh
- storage_lvm_lv_resizing
- id_map_base
- file_symlinks
- container_push_target
- network_vlan_physical
- storage_images_delete
- container_edit_metadata
- storage_driver_ceph
- storage_ceph_user_name
- resource_limits
- resources
- kernel_limits
- storage_api_volume_rename
- network_sriov
- console
- restrict_dev_incus
- migration_pre_copy
- infiniband
- dev_incus_events
- proxy
- network_dhcp_gateway
- file_get_symlink
- network_leases
- unix_device_hotplug
- operation_description
- clustering
- event_lifecycle
- nvidia_runtime
- container_mount_propagation
- container_backup
- dev_incus_images
- proxy_unix
- proxy_udp
- clustering_join
- network_state
- proxy_unix_dac_properties
- container_protection_delete
- unix_priv_drop
- pprof_http
- proxy_haproxy_protocol
- network_hwaddr
- proxy_nat
- network_nat_order
- container_full
- backup_compression
- nvidia_runtime_config
- storage_unmapped
- projects
- network_vxlan_ttl
- container_incremental_copy
- usb_optional_vendorid
- snapshot_scheduling
- snapshot_schedule_aliases
- container_copy_project
- clustering_server_address
- container_protection_shift
- snapshot_expiry
- snapshot_expiry_creation
- network_leases_location
- resources_cpu_socket
- resources_gpu
- resources_numa
- kernel_features
- id_map_current
- event_location
- network_nat_address
- container_nic_routes
- cluster_internal_copy
- seccomp_notify
- lxc_features
- container_nic_ipvlan
- network_vlan_sriov
- storage_cephfs
- container_nic_ipfilter
- resources_v2
- container_syscall_intercept
- container_disk_shift
- storage_shifted
- resources_infiniband
- daemon_storage
- instances
- image_types
- resources_disk_sata
- clustering_roles
- images_expiry
- resources_network_firmware
- ceph_data_pool_name
- compression_squashfs
- container_raw_mount
- container_nic_routed
- container_disk_ceph
- virtual-machines
- image_profiles
- clustering_architecture
- resources_disk_id
- storage_lvm_stripes
- vm_boot_priority
- unix_hotplug_devices
- api_filtering
- instance_nic_network
- clustering_sizing
- firewall_driver
- projects_limits
- limits_hugepages
- projects_restrictions
- volume_snapshot_scheduling
- trust_ca_certificates
- snapshot_disk_usage
- clustering_edit_roles
- resources_usb_pci
- resources_cpu_threads_numa
- resources_cpu_core_die
- api_os
- container_nic_ipvlan_mode
- resources_system
- images_push_relay
- network_dns_search
- container_nic_routed_limits
- instance_nic_bridged_vlan
- network_state_bond_bridge
- usedby_consistency
- custom_block_volumes
- clustering_failure_domains
- resources_gpu_mdev
- console_vga_type
- projects_limits_disk
- network_type_macvlan
- network_type_sriov
- network_type_ovn
- projects_networks
- custom_volume_backup
- backup_override_name
- storage_rsync_compression
- network_type_physical
- network_ovn_nat
- tpm_device_type
- gpu_mdev
- resources_pci_iommu
- resources_network_usb
- resources_disk_address
- network_ovn_dhcp
- projects_limits_instances
- network_state_vlan
- instance_bulk_state_change
- network_gvrp
- instance_pool_move
- gpu_sriov
- pci_device_type
- storage_volume_state
- network_acl
- migration_stateful
- disk_state_quota
- storage_ceph_features
- projects_compression
- certificate_project
- network_ovn_acl
- projects_images_auto_update
- images_default_architecture
- network_ovn_acl_defaults
- gpu_mig
- project_usage
- network_bridge_acl
- warnings
- clustering_join_token
- clustering_description
- server_trusted_proxy
- clustering_update_cert
- storage_api_project
- resources_gpu_usb
- clustering_evacuation
- network_ovn_nat_address
- network_bgp
- network_forward
- custom_volume_refresh
- network_counters_errors_dropped
- metrics
- image_source_project
- clustering_config
- network_peer
- linux_sysctl
- network_dns
- ovn_nic_acceleration
- certificate_self_renewal
- instance_project_move
- storage_volume_project_move
- cloud_init
- network_dns_nat
- database_leader
- instance_all_projects
- clustering_groups
- ceph_rbd_du
- instance_get_full
- qemu_metrics
- gpu_mig_uuid
- event_project
- clustering_evacuation_live
- instance_allow_inconsistent_copy
- network_state_ovn
- storage_volume_api_filtering
- image_restrictions
- storage_zfs_export
- network_dns_records
- storage_zfs_reserve_space
- network_acl_log
- storage_zfs_blocksize
- metrics_cpu_seconds
- instance_snapshot_never
- certificate_token
- instance_nic_routed_neighbor_probe
- event_hub
- agent_nic_config
- projects_restricted_intercept
- metrics_authentication
- images_target_project
- images_all_projects
- cluster_migration_inconsistent_copy
- cluster_ovn_chassis
- container_syscall_intercept_sched_setscheduler
- storage_lvm_thinpool_metadata_size
- storage_volume_state_total
- instance_file_head
- instances_nic_host_name
- image_copy_profile
- container_syscall_intercept_sysinfo
- clustering_evacuation_mode
- resources_pci_vpd
- qemu_raw_conf
- storage_cephfs_fscache
- network_load_balancer
- vsock_api
- instance_ready_state
- network_bgp_holdtime
- storage_volumes_all_projects
- metrics_memory_oom_total
- storage_buckets
- storage_buckets_create_credentials
- metrics_cpu_effective_total
- projects_networks_restricted_access
- storage_buckets_local
- loki
- acme
- internal_metrics
- cluster_join_token_expiry
- remote_token_expiry
- init_preseed
- storage_volumes_created_at
- cpu_hotplug
- projects_networks_zones
- network_txqueuelen
- cluster_member_state
- instances_placement_scriptlet
- storage_pool_source_wipe
- zfs_block_mode
- instance_generation_id
- disk_io_cache
- amd_sev
- storage_pool_loop_resize
- migration_vm_live
- ovn_nic_nesting
- oidc
- network_ovn_l3only
- ovn_nic_acceleration_vdpa
- cluster_healing
- instances_state_total
- auth_user
- security_csm
- instances_rebuild
- numa_cpu_placement
- custom_volume_iso
- network_allocations
- zfs_delegate
- storage_api_remote_volume_snapshot_copy
- operations_get_query_all_projects
- metadata_configuration
- syslog_socket
- event_lifecycle_name_and_project
- instances_nic_limits_priority
- disk_initial_volume_configuration
- operation_wait
- image_restriction_privileged
- cluster_internal_custom_volume_copy
- disk_io_bus
- storage_cephfs_create_missing
- instance_move_config
- ovn_ssl_config
- certificate_description
- disk_io_bus_virtio_blk
- loki_config_instance
- instance_create_start
- clustering_evacuation_stop_options
- boot_host_shutdown_action
- agent_config_drive
- network_state_ovn_lr
- image_template_permissions
- storage_bucket_backup
- storage_lvm_cluster
- shared_custom_block_volumes
- auth_tls_jwt
- oidc_claim
- device_usb_serial
- numa_cpu_balanced
- image_restriction_nesting
- network_integrations
- instance_memory_swap_bytes
- network_bridge_external_create
- network_zones_all_projects
- storage_zfs_vdev
- container_migration_stateful
- profiles_all_projects
- instances_scriptlet_get_instances
- instances_scriptlet_get_cluster_members
- instances_scriptlet_get_project
- network_acl_stateless
- instance_state_started_at
- networks_all_projects
- network_acls_all_projects
- storage_buckets_all_projects
- resources_load
- instance_access
- project_access
- projects_force_delete
- resources_cpu_flags
- disk_io_bus_cache_filesystem
- instance_oci
- clustering_groups_config
- instances_lxcfs_per_instance
- clustering_groups_vm_cpu_definition
- disk_volume_subpath
- projects_limits_disk_pool
- network_ovn_isolated
- qemu_raw_qmp
- network_load_balancer_health_check
- oidc_scopes
- network_integrations_peer_name
- qemu_scriptlet
- instance_auto_restart
- storage_lvm_metadatasize
- ovn_nic_promiscuous
- ovn_nic_ip_address_none
- instances_state_os_info
- network_load_balancer_state
- instance_nic_macvlan_mode
- storage_lvm_cluster_create
- network_ovn_external_interfaces
- instances_scriptlet_get_instances_count
- cluster_rebalance
- custom_volume_refresh_exclude_older_snapshots
- storage_initial_owner
- storage_live_migration
- instance_console_screenshot
- image_import_alias
- authorization_scriptlet
- console_force
- network_ovn_state_addresses
- network_bridge_acl_devices
- instance_debug_memory
- init_preseed_storage_volumes
- init_preseed_profile_project
- instance_nic_routed_host_address
- instance_smbios11
- api_filtering_extended
- acme_dns01
- security_iommu
api_status: stable
api_version: "1.0"
auth: trusted
public: false
auth_methods:
- tls
auth_user_name: root
auth_user_method: unix
environment:
  addresses:
  - 192.168.2.1:8443
  architectures:
  - x86_64
  - i686
  certificate: |
    -----BEGIN CERTIFICATE-----
    MIICBDCCAYmgAwIBAgIQQUm5u0bFVOisN4usRbQtzTAKBggqhkjOPQQDAzA0MRww
    GgYDVQQKExNsaW51eGNvbnRhaW5lcnMub3JnMRQwEgYDVQQDDAtyb290QHNlcnZl
    cjAeFw0yMTA4MTgwOTEwMzZaFw0zMTA4MTYwOTEwMzZaMDQxHDAaBgNVBAoTE2xp
    bnV4Y29udGFpbmVycy5vcmcxFDASBgNVBAMMC3Jvb3RAc2VydmVyMHYwEAYHKoZI
    zj0CAQYFK4EEACIDYgAE1yX1MOtOtvmgatZ8pUtCUb8OZEE+nQPtc2vIZXJicZ5j
    cG0x/ZeWUV6SJtAxkTDHTKEeVr1Ts2UpR4oqAY/cAgagI02Tj3Agwc4vzM8O6Vn5
    R8RxKmYtHw/enYGFvwLmo2AwXjAOBgNVHQ8BAf8EBAMCBaAwEwYDVR0lBAwwCgYI
    KwYBBQUHAwEwDAYDVR0TAQH/BAIwADApBgNVHREEIjAgggZzZXJ2ZXKHBH8AAAGH
    EAAAAAAAAAAAAAAAAAAAAAEwCgYIKoZIzj0EAwMDaQAwZgIxAOQolXuF74GJEFGI
    BCzmef6qtuMZzlEa1jxsQfPM/yr3bgJiqm+2GmMjWtmUmOXe1AIxAP2fxe9+tjga
    u+a8VCgCLtBtis1fxNsIghcVZBtmtoXO/8Z8HFIp80NC+ofcJCxR9Q==
    -----END CERTIFICATE-----
  certificate_fingerprint: a72974094e303ffd11ad32401fa957673b6e0715286eca53e75cba51133ebc14
  driver: lxc | qemu
  driver_version: 6.0.3 | 9.0.4
  firewall: nftables
  kernel: Linux
  kernel_architecture: x86_64
  kernel_features:
    idmapped_mounts: "true"
    netnsid_getifaddrs: "true"
    seccomp_listener: "true"
    uevent_injection: "true"
    unpriv_binfmt: "true"
    unpriv_fscaps: "true"
  kernel_version: 6.8.12-8-pve
  lxc_features:
    cgroup2: "true"
    core_scheduling: "true"
    devpts_fd: "true"
    idmapped_mounts_v2: "true"
    mount_injection_file: "true"
    network_ipvlan: "true"
    network_l2proxy: "true"
    network_veth_router: "true"
    pidfd: "true"
    seccomp_notify: "true"
  os_name: Debian GNU/Linux
  os_version: "12"
  project: default
  server: incus
  server_clustered: false
  server_event_mode: full-mesh
  server_name: server
  server_pid: 2204208
  server_version: 6.10.1
  storage: zfs | btrfs
  storage_version: 2.2.7-pve1 | 6.2
  storage_supported_drivers:
  - name: lvm
    version: 2.03.16(2) (2022-05-18) / 1.02.185 (2022-05-18) / 4.48.0
    remote: false
  - name: lvmcluster
    remote: true
  - name: zfs
    version: 2.2.7-pve1
    remote: false
  - name: btrfs
    version: "6.2"
    remote: false
  - name: ceph
    version: 16.2.15
    remote: true
  - name: cephfs
    version: 16.2.15
    remote: true
  - name: cephobject
    version: 16.2.15
    remote: true
  - name: dir
    version: "1"
    remote: false
Maybe look at dmesg for sign of specific denials?
I’ve rebooted the computer and the “unconfined” parameter magically disappeared and now showing expanded config for one container contains :
raw.lxc: lxc.cgroup.devices.allow = c 10:200 rwm
and that’s it, the container is starting correctly.
So after migration it’s worth a reboot
