Arnaud_F
(Arnaud F.)
March 14, 2025, 8:18pm
1
Hello
I just migrated from LXD to Incus this afternoon and faced several issues I’ve been able to tackle.
i.e: after migration none of the container went starting, I had to add the rule raw.lxc: lxc.apparmor.profile=unconfined in every container for them to start.
Now problem remains in VM in which I had docker installed previously in LXD.
Trying to start them results in
# incus start az-coe-microsoft
Error: Failed to run: forklimits limit=memlock:unlimited:unlimited fd=3 fd=4 fd=5 fd=6 fd=7 -- /opt/incus/bin/qemu-system-x86_64 -S -name az-coe-microsoft -uuid 70b35154-490f-400e-ba1e-0312ce2d15fd -daemonize -cpu host,hv_passthrough -nographic -serial chardev:console -nodefaults -no-user-config -sandbox on,obsolete=deny,elevateprivileges=allow,spawn=allow,resourcecontrol=deny -readconfig /run/incus/az-coe-microsoft/qemu.conf -spice unix=on,disable-ticketing=on,addr=/run/incus/az-coe-microsoft/qemu.spice -pidfile /run/incus/az-coe-microsoft/qemu.pid -D /var/log/incus/az-coe-microsoft/qemu.log -smbios type=2,manufacturer=LinuxContainers,product=Incus -runas incus: : exit status 1
Try `incus info --show-log az-coe-microsoft` for more info
root@server:~# incus info --show-log az-coe-microsoft
Status: STOPPED
Type: virtual-machine
Created: 2023/05/23 07:06 CEST
Last Used: 2025/03/14 18:16 CET
Log:
qemu-system-x86_64: Spice: ../server/dispatcher.cpp:89:Dispatcher: socketpair failed Permission denied
Any idea ?
incus --version
6.0.3
stgraber
(Stéphane Graber)
March 14, 2025, 9:20pm
2
Can you show the full incus info output as well as incus config show --expanded az-coe-microsoft?
That’s a rather unusual error which suggests something really weird is going on with the system this is running on (and could be linked to the apparmor issue you mentioned which is also not something we’ve really ever seen).
Arnaud_F
(Arnaud F.)
March 14, 2025, 9:39pm
3
stgraber:
incus info
Sure
# incus info
core.https_address: 192.168.2.1:8443
api_extensions:
- container_stop_priority
- container_syscall_filtering
- auth_pki
- container_last_used_at
- etag
- patch
- usb_devices
- https_allowed_credentials
- image_compression_algorithm
- directory_manipulation
- container_cpu_time
- storage_zfs_use_refquota
- storage_lvm_mount_options
- network
- profile_usedby
- container_push
- container_exec_recording
- certificate_update
- gpu_devices
- container_image_properties
- migration_progress
- id_map
- network_firewall_filtering
- network_routes
- storage
- file_delete
- file_append
- network_dhcp_expiry
- storage_lvm_vg_rename
- storage_lvm_thinpool_rename
- network_vlan
- image_create_aliases
- container_stateless_copy
- container_only_migration
- storage_zfs_clone_copy
- unix_device_rename
- storage_lvm_use_thinpool
- storage_rsync_bwlimit
- network_vxlan_interface
- storage_btrfs_mount_options
- entity_description
- image_force_refresh
- storage_lvm_lv_resizing
- id_map_base
- file_symlinks
- container_push_target
- network_vlan_physical
- storage_images_delete
- container_edit_metadata
- storage_driver_ceph
- storage_ceph_user_name
- resource_limits
- resources
- kernel_limits
- storage_api_volume_rename
- network_sriov
- console
- restrict_dev_incus
- migration_pre_copy
- infiniband
- dev_incus_events
- proxy
- network_dhcp_gateway
- file_get_symlink
- network_leases
- unix_device_hotplug
- operation_description
- clustering
- event_lifecycle
- nvidia_runtime
- container_mount_propagation
- container_backup
- dev_incus_images
- proxy_unix
- proxy_udp
- clustering_join
- network_state
- proxy_unix_dac_properties
- container_protection_delete
- unix_priv_drop
- pprof_http
- proxy_haproxy_protocol
- network_hwaddr
- proxy_nat
- network_nat_order
- container_full
- backup_compression
- nvidia_runtime_config
- storage_unmapped
- projects
- network_vxlan_ttl
- container_incremental_copy
- usb_optional_vendorid
- snapshot_scheduling
- snapshot_schedule_aliases
- container_copy_project
- clustering_server_address
- container_protection_shift
- snapshot_expiry
- snapshot_expiry_creation
- network_leases_location
- resources_cpu_socket
- resources_gpu
- resources_numa
- kernel_features
- id_map_current
- event_location
- network_nat_address
- container_nic_routes
- cluster_internal_copy
- seccomp_notify
- lxc_features
- container_nic_ipvlan
- network_vlan_sriov
- storage_cephfs
- container_nic_ipfilter
- resources_v2
- container_syscall_intercept
- container_disk_shift
- storage_shifted
- resources_infiniband
- daemon_storage
- instances
- image_types
- resources_disk_sata
- clustering_roles
- images_expiry
- resources_network_firmware
- ceph_data_pool_name
- compression_squashfs
- container_raw_mount
- container_nic_routed
- container_disk_ceph
- virtual-machines
- image_profiles
- clustering_architecture
- resources_disk_id
- storage_lvm_stripes
- vm_boot_priority
- unix_hotplug_devices
- api_filtering
- instance_nic_network
- clustering_sizing
- firewall_driver
- projects_limits
- limits_hugepages
- projects_restrictions
- volume_snapshot_scheduling
- trust_ca_certificates
- snapshot_disk_usage
- clustering_edit_roles
- resources_usb_pci
- resources_cpu_threads_numa
- resources_cpu_core_die
- api_os
- container_nic_ipvlan_mode
- resources_system
- images_push_relay
- network_dns_search
- container_nic_routed_limits
- instance_nic_bridged_vlan
- network_state_bond_bridge
- usedby_consistency
- custom_block_volumes
- clustering_failure_domains
- resources_gpu_mdev
- console_vga_type
- projects_limits_disk
- network_type_macvlan
- network_type_sriov
- network_type_ovn
- projects_networks
- custom_volume_backup
- backup_override_name
- storage_rsync_compression
- network_type_physical
- network_ovn_nat
- tpm_device_type
- gpu_mdev
- resources_pci_iommu
- resources_network_usb
- resources_disk_address
- network_ovn_dhcp
- projects_limits_instances
- network_state_vlan
- instance_bulk_state_change
- network_gvrp
- instance_pool_move
- gpu_sriov
- pci_device_type
- storage_volume_state
- network_acl
- migration_stateful
- disk_state_quota
- storage_ceph_features
- projects_compression
- certificate_project
- network_ovn_acl
- projects_images_auto_update
- images_default_architecture
- network_ovn_acl_defaults
- gpu_mig
- project_usage
- network_bridge_acl
- warnings
- clustering_join_token
- clustering_description
- server_trusted_proxy
- clustering_update_cert
- storage_api_project
- resources_gpu_usb
- clustering_evacuation
- network_ovn_nat_address
- network_bgp
- network_forward
- custom_volume_refresh
- network_counters_errors_dropped
- metrics
- image_source_project
- clustering_config
- network_peer
- linux_sysctl
- network_dns
- ovn_nic_acceleration
- certificate_self_renewal
- instance_project_move
- storage_volume_project_move
- cloud_init
- network_dns_nat
- database_leader
- instance_all_projects
- clustering_groups
- ceph_rbd_du
- instance_get_full
- qemu_metrics
- gpu_mig_uuid
- event_project
- clustering_evacuation_live
- instance_allow_inconsistent_copy
- network_state_ovn
- storage_volume_api_filtering
- image_restrictions
- storage_zfs_export
- network_dns_records
- storage_zfs_reserve_space
- network_acl_log
- storage_zfs_blocksize
- metrics_cpu_seconds
- instance_snapshot_never
- certificate_token
- instance_nic_routed_neighbor_probe
- event_hub
- agent_nic_config
- projects_restricted_intercept
- metrics_authentication
- images_target_project
- images_all_projects
- cluster_migration_inconsistent_copy
- cluster_ovn_chassis
- container_syscall_intercept_sched_setscheduler
- storage_lvm_thinpool_metadata_size
- storage_volume_state_total
- instance_file_head
- instances_nic_host_name
- image_copy_profile
- container_syscall_intercept_sysinfo
- clustering_evacuation_mode
- resources_pci_vpd
- qemu_raw_conf
- storage_cephfs_fscache
- network_load_balancer
- vsock_api
- instance_ready_state
- network_bgp_holdtime
- storage_volumes_all_projects
- metrics_memory_oom_total
- storage_buckets
- storage_buckets_create_credentials
- metrics_cpu_effective_total
- projects_networks_restricted_access
- storage_buckets_local
- loki
- acme
- internal_metrics
- cluster_join_token_expiry
- remote_token_expiry
- init_preseed
- storage_volumes_created_at
- cpu_hotplug
- projects_networks_zones
- network_txqueuelen
- cluster_member_state
- instances_placement_scriptlet
- storage_pool_source_wipe
- zfs_block_mode
- instance_generation_id
- disk_io_cache
- amd_sev
- storage_pool_loop_resize
- migration_vm_live
- ovn_nic_nesting
- oidc
- network_ovn_l3only
- ovn_nic_acceleration_vdpa
- cluster_healing
- instances_state_total
- auth_user
- security_csm
- instances_rebuild
- numa_cpu_placement
- custom_volume_iso
- network_allocations
- zfs_delegate
- storage_api_remote_volume_snapshot_copy
- operations_get_query_all_projects
- metadata_configuration
- syslog_socket
- event_lifecycle_name_and_project
- instances_nic_limits_priority
- disk_initial_volume_configuration
- operation_wait
- image_restriction_privileged
- cluster_internal_custom_volume_copy
- disk_io_bus
- storage_cephfs_create_missing
- instance_move_config
- ovn_ssl_config
- certificate_description
- disk_io_bus_virtio_blk
- loki_config_instance
- instance_create_start
- clustering_evacuation_stop_options
- boot_host_shutdown_action
- agent_config_drive
- network_state_ovn_lr
- image_template_permissions
- storage_bucket_backup
- storage_lvm_cluster
- shared_custom_block_volumes
- auth_tls_jwt
- oidc_claim
- device_usb_serial
- numa_cpu_balanced
- image_restriction_nesting
- network_integrations
- instance_memory_swap_bytes
- network_bridge_external_create
- network_zones_all_projects
- storage_zfs_vdev
- container_migration_stateful
- profiles_all_projects
- instances_scriptlet_get_instances
- instances_scriptlet_get_cluster_members
- instances_scriptlet_get_project
- network_acl_stateless
- instance_state_started_at
- networks_all_projects
- network_acls_all_projects
- storage_buckets_all_projects
- resources_load
- instance_access
- project_access
- projects_force_delete
- resources_cpu_flags
- disk_io_bus_cache_filesystem
- instance_oci
- clustering_groups_config
- instances_lxcfs_per_instance
- clustering_groups_vm_cpu_definition
- disk_volume_subpath
- projects_limits_disk_pool
- network_ovn_isolated
- qemu_raw_qmp
- network_load_balancer_health_check
- oidc_scopes
- network_integrations_peer_name
- qemu_scriptlet
- instance_auto_restart
- storage_lvm_metadatasize
- ovn_nic_promiscuous
- ovn_nic_ip_address_none
- instances_state_os_info
- network_load_balancer_state
- instance_nic_macvlan_mode
- storage_lvm_cluster_create
- network_ovn_external_interfaces
- instances_scriptlet_get_instances_count
- cluster_rebalance
- custom_volume_refresh_exclude_older_snapshots
- storage_initial_owner
- storage_live_migration
- instance_console_screenshot
- image_import_alias
- authorization_scriptlet
- console_force
- network_ovn_state_addresses
- network_bridge_acl_devices
- instance_debug_memory
- init_preseed_storage_volumes
- init_preseed_profile_project
- instance_nic_routed_host_address
- instance_smbios11
- api_filtering_extended
- acme_dns01
- security_iommu
api_status: stable
api_version: "1.0"
auth: trusted
public: false
auth_methods:
- tls
auth_user_name: root
auth_user_method: unix
environment:
addresses:
- 192.168.2.1:8443
architectures:
- x86_64
- i686
certificate: |
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
certificate_fingerprint: a72974094e303ffd11ad32401fa957673b6e0715286eca53e75cba51133ebc14
driver: lxc | qemu
driver_version: 6.0.3 | 9.0.4
firewall: nftables
kernel: Linux
kernel_architecture: x86_64
kernel_features:
idmapped_mounts: "true"
netnsid_getifaddrs: "true"
seccomp_listener: "true"
uevent_injection: "true"
unpriv_binfmt: "true"
unpriv_fscaps: "true"
kernel_version: 6.8.12-8-pve
lxc_features:
cgroup2: "true"
core_scheduling: "true"
devpts_fd: "true"
idmapped_mounts_v2: "true"
mount_injection_file: "true"
network_ipvlan: "true"
network_l2proxy: "true"
network_veth_router: "true"
pidfd: "true"
seccomp_notify: "true"
os_name: Debian GNU/Linux
os_version: "12"
project: default
server: incus
server_clustered: false
server_event_mode: full-mesh
server_name: server
server_pid: 2204208
server_version: 6.10.1
storage: zfs | btrfs
storage_version: 2.2.7-pve1 | 6.2
storage_supported_drivers:
- name: lvm
version: 2.03.16(2) (2022-05-18) / 1.02.185 (2022-05-18) / 4.48.0
remote: false
- name: lvmcluster
remote: true
- name: zfs
version: 2.2.7-pve1
remote: false
- name: btrfs
version: "6.2"
remote: false
- name: ceph
version: 16.2.15
remote: true
- name: cephfs
version: 16.2.15
remote: true
- name: cephobject
version: 16.2.15
remote: true
- name: dir
version: "1"
remote: false
and config expanded :
# incus config show --expanded az-coe-microsoft
boot.autostart: "true"
image.architecture: amd64
image.description: Debian bullseye amd64 (20220823_05:24)
image.os: Debian
image.release: bullseye
image.serial: "20220823_05:24"
image.type: disk-kvm.img
image.variant: default
limits.cpu: "8"
limits.memory: 20GB
security.nesting: "true"
security.privileged: "true"
security.secureboot: "true"
volatile.base_image: 60574a43a2cbe72ea3eeea3da7859dd913e6060781104ba11fb21f345f443b03
volatile.cloud-init.instance-id: 3fc2c65c-89b3-41b9-b7c6-b69dc60d8628
volatile.uuid: 70b35154-490f-400e-ba1e-0312ce2d15fd
volatile.uuid.generation: 64e98c4a-9daf-4d36-ae7f-ac640c403a1b
volatile.vmbr0.hwaddr: 00:16:3e:61:16:9e
volatile.vmbr3.hwaddr: 00:16:3e:cd:c3:02
volatile.vsock_id: "84"
azagent:
path: /home/azagent
shift: "true"
source: /disks/containers/az-coe-microsoft/azagent/
disks:
path: /disks
shift: "true"
source: /disks/www
docker:
path: /var/lib/docker
source: /disks/containers/az-coe-microsoft/docker/
pool: default
vmbr0:
nictype: bridged
parent: vmbr0
vmbr3:
nictype: bridged
parent: vmbr3
- apps
stgraber
(Stéphane Graber)
March 15, 2025, 2:58am
4
The container is privileged (security.privileged=true), do unprivileged containers behave better?
Arnaud_F
(Arnaud F.)
March 17, 2025, 8:11pm
5
I’ve reboot the whole server as I said in another post and it’s behave better.
VM is now starting but facing an error when launching docker.
With LXD as a lot of issues using VMs, will migrate them to containers as it’s seems to work better with incus.
