lxc.start.order
An integer used to sort the containers when auto-starting a series of containers at once.
AUTOSTART AND SYSTEM BOOT
... The startup will be in order of lxc.start.order.
The leaves one to guesswork of how the integer is interpreted, e.g. whether 0 is lowest or highest priority or even whether 0 might be a special value (like perhaps disabling)
My sentiments exactly, my logic would also have been that 0 is either the highest priority, or if representing a special value such as disable for instance than 1 being the highest priority and incrementing integer’s value is decreasing the priority but apparently it is the other way around.
Not sure if it warrants a clarification on Github really but rather a more expansive explanation at the man page. Have updated the previous post with the source of the information, being a blog of @stgraber.
Unless this changed over time from lxc 1, which the blog post from 2013 is based on, to today’s lxc 3 version
I am on mobile now. As far as I understand, the man pages are on the lxc git repository on GitHub. It should be GitHub.com/lxc/lxc
You can edit the manpage and submit a pull request to accept the change.
Thank you for the pointer! Prior editing though it would be good to know whether an interger of 0 serves a special purpose or is just the lowest priority.
